    Toolbar Icon Size on 4K Monitor
    41 Posts 10 Posters 9.6k Views 10 Watching
      slbaumgartner
      @pixero said:
      Does anyone know if there is something special that needs to be done in the scripts code to use SVG icons or can we just put SVG icons in the plugins directory?
      The icon files are given explicitly by the plugin code, which has to choose between the old png for SketchUp versions prior to 2016, and between svg and pdf for Windows vs Mac. It doesn't take a lot of code, but has to be changed, and no, simply dropping a svg file into the folder won't do the trick.
      • fredo6F Offline
        ...in addition to the relevant comment by slbaumgartner, I would add that there is no automated way to generate a nice SVG from a PNG. Basically, the icon has be redrawn in SVG (via Inskape or similar drawing software).
        • Bob JamesB Offline
          Bob James
          @dave r said:
          SVG icons were chosen specifically because they can be scaled to compensate for high res screens. Open a PNG icon in your image editor and scale it up so you can see it. The quality will be crap. SVG just makes sense.
          Thank you, Dave.
          Yes, it does make good sense, but only if there is an easy path for changing all of the hundreds of current plugin/extension icons. This is based on the assumption that as time goes on more and more people will upgrade to 4k. But, apparently, the consensus is that 4k will remain a niche.
          • PixeroP Offline
            Pixero
            Could someone post a code snippet that shows how to implement svg or pdf icons so I could start updating my own plugins at least.
              slbaumgartner
              Here's an example from one of my extensions:
              if(not file_loaded?(__FILE__))
                cmd = UI;;Command.new("RakeAndSplay") {Sketchup.active_model.select_tool(SLBPlugins;;RakeAndSplayTool.get_tool)}
                cmd.menu_text = "Rake and Splay"
                if(Sketchup.version.to_i >= 16)
                  if(RUBY_PLATFORM =~ /darwin/)
                    cmd.small_icon = Sketchup.find_support_file("rake_and_splay.pdf", "Plugins/SB_rake_and_splay")
                    cmd.large_icon = Sketchup.find_support_file("rake_and_splay.pdf", "Plugins/SB_rake_and_splay")
                  else
                    cmd.small_icon = Sketchup.find_support_file("rake_and_splay.svg", "Plugins/SB_rake_and_splay")
                    cmd.large_icon = Sketchup.find_support_file("rake_and_splay.svg", "Plugins/SB_rake_and_splay")
                else
                  cmd.small_icon = Sketchup.find_support_file("rake_and_splay_16.png", "Plugins/SB_rake_and_splay")
                  cmd.large_icon = Sketchup.find_support_file("rake_and_splay_24.png", "Plugins/SB_rake_and_splay")
                tb = UI;;Toolbar.new("Rake and Splay").add_item(cmd)
                tb.restore if tb.get_last_state == 1
                UI.menu("Tools").add_item cmd
              file_loaded(__FILE__)
              • PixeroP Offline
                Pixero
                Thanks.
                  Bob James
                  Thank you, slbaumgartner
                  Would you tell me how to use this for each plugin extension?
                    Bob James
                    He's right!
                    I converted and replaced the icons in SketchUcation to .svg at 300pixelsx300pixels at 300dpi but there was no change in SU2018
                      slbaumgartner
                      If you're not familiar with Ruby API programming for SketchUp, you might be in over your head as the code needs to be adapted to each specific extension, there is no universal drop-in-place form.
                      You need to create the appropriate icon files (svg, pdf, and png) for the extension and put them in the extension's folder. Then you need to find where in the extension's code it creates and populates its toolbar and integrate my snippet with whatever the original code does there, which will almost surely vary from case to case.
                      • fredo6F Offline
                        For inof, all my plugins can support PNG, SVG and PDF (as everything is managed by LibFredo6).
                        I am just missing the icons in SVG / PDF
                        That's just a matter to put the SVG / PDF file in:
                        • subfolder IMAGES_Standards of the plugin folder (say Fredo6_FredoScale/IMAGES_standard)
                        • respecting convention: same name as PNG but removing the trailing _24 (or _16 or _32). So FSC_icon_Scale_24.png would become FSC_icon_Scale.svg
                        • PixeroP Offline
                          Pixero
                          Question. Does the svg/PDF icons need to be made in a special size? (I know they are scaleable just wondering if the dokument size should be anything special.)
                            slbaumgartner
                            You can draw the icon artwork at whatever size you wish. The view of the contents will be scaled to fit the available space in the toolbar button, so the physical size you drew is irrelevant. But you do need to verify that you haven't put details into the artwork that won't be visible when scaled to a typical toolbar button on a particular size display. Since you probably don't have a lot of different displays available to test, the best practice is to keep your icons fairly simple.
                            One precaution though: Whatever size you draw, you should keep the drawing canvas square. Otherwise SketchUp will scale it based on the larger dimension and it won't fill the full button in the other direction.
                              Bob James
                              Awesome!!
                              Do I have to re-draw them? Can't I just continue converting them from jpg/png to svg?
                                slbaumgartner
                                You can convert png or jpg to svg or pdf, but since the content is a raster image it most likely won't look good when scaled. The contents need to be vector to scale cleanly.
                                • Paul RussamP Offline
                                  Paul Russam
                                  PNG and JPG are raster images whilst SVG is a vector, Whilst you can save a raster image as an SVG its a complete waste of time as it will remain a raster image but it'll be encoded in XML and be substantially larger (file size) than the original.
                                  To create proper SVG's you need a vector app such as Adobe Illustrator, Affinity Designer etc. Photoshop (raster app) will NOT create proper SVG's
                                  SVG's are size independent, they will look no better or worse if you create them on a 10000x10000px canvas or a 100x100 one and dpi is irrelevant outside of the paper print industry for any image be it JPG, PNG or especially SVG.
                                  I've attached a zip file containing 2 SVG's, one is a logo I did recently (lei-logo-pt1-colour.svg) in Affinity Designer. If you look at it in a text editor you'll see its just a simple set of instructions in XML defining an elements shape/fill/border etc.
                                  The other is an SVG I hand wrote for fun (SolarSys-V4.svg), as it's handwritten it's far clearer to see the XML structure ... and it's animated ๐Ÿ˜„
                                  TL;DR
                                  Don't convert PNG/JPG to SVG, make them from scratch.
                                  sample svgs.zip
                                  Paul Russam
                                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                  • dereiD Offline
                                    derei
                                    Inkscape has a feature to vectorize a bitmap (Trace Bitmap) and it can be used to quickly convert some icons, provided you have a decent quality of the raster image.
                                    You can try with small icons, but I doubt there will be enough resolution in them to get a decent result. See attached.
                                    However, with a decent quality image, the results can be impressive.
                                      Bob James
                                      Miracle ๐Ÿ˜ฎ
                                      With the latest Win10 update all icons are now full size!!! Not to look a gift horse in the mouth but now I wish I could make them a bit smaller ๐Ÿ˜Ž
                                      Has this happened to anyone else?
                                        Bob James
                                        UPDATE
                                        Updated Nvidia driver from 391.35 to 397.31 and all of the non-svg icons went back to tiny. ๐Ÿ˜ž
                                        • jujuJ Offline
                                          juju
                                          @bob james said:
                                          UPDATE
                                          Are you sure the screen resolution was set correctly by the previous driver when you did that update?
                                            Bob James
                                            No way to know now unless I go back to 391.35. Resolution is set at its recommended value.
                                            • 2 / 3
