    Toolbar Icon Size on 4K Monitor
    41 Posts 10 Posters 11.5k Views 10 Watching
      derei is correct. SketchUp has switched to using SVG icons to deal with high res displays. Some extension authors have followed suit. Not all have, however. I expect the icons will get updates one of these days. Considering most of these extensions are free, patience is called for. Or perhaps one could hire someone to make new SVG icons for these extensions.
      • PixeroP
        Pixero
        Does anyone know if there is something special that needs to be done in the scripts code to use SVG icons or can we just put SVG icons in the plugins directory?
          I think SketchUp will look first for SVG icons and use them if they exist.
          • Bob JamesB
            Bob James
            Many thanks to the three of you for taking the time to reply ❗
            It seems somewhat incredible that given the vast amount of plugins/extensions .jpg toolbar icons being used by every SU user that SU would be modified to only use svg icons.
            How in the world did this get past beta testing????
              SVG icons were chosen specifically because they can be scaled to compensate for high res screens. Open a PNG icon in your image editor and scale it up so you can see it. The quality will be crap. SVG just makes sense.
              • PixeroP
                Pixero
                Could we make a community effort to update all these icons to SVG if the authors don’t do it?
                  That sounds like a good idea. I would suggest offering the same icon packages to the authors so they can include them in updates of their extensions.
                    slbaumgartner
                    The icon files are given explicitly by the plugin code, which has to choose between the old png for SketchUp versions prior to 2016, and between svg and pdf for Windows vs Mac. It doesn't take a lot of code, but has to be changed, and no, simply dropping a svg file into the folder won't do the trick.
                    • fredo6F
                      ...in addition to the relevant comment by slbaumgartner, I would add that there is no automated way to generate a nice SVG from a PNG. Basically, the icon has be redrawn in SVG (via Inskape or similar drawing software).
                      • Bob JamesB
                        Bob James
                        Thank you, Dave.
                        Yes, it does make good sense, but only if there is an easy path for changing all of the hundreds of current plugin/extension icons. This is based on the assumption that as time goes on more and more people will upgrade to 4k. But, apparently, the consensus is that 4k will remain a niche.
                        • PixeroP
                          Pixero
                          Could someone post a code snippet that shows how to implement svg or pdf icons so I could start updating my own plugins at least.
                            slbaumgartner
                            Here's an example from one of my extensions:
                            if(not file_loaded?(__FILE__))
                              cmd = UI;;Command.new("RakeAndSplay") {Sketchup.active_model.select_tool(SLBPlugins;;RakeAndSplayTool.get_tool)}
                              cmd.menu_text = "Rake and Splay"
                              if(Sketchup.version.to_i >= 16)
                                if(RUBY_PLATFORM =~ /darwin/)
                                  cmd.small_icon = Sketchup.find_support_file("rake_and_splay.pdf", "Plugins/SB_rake_and_splay")
                                  cmd.large_icon = Sketchup.find_support_file("rake_and_splay.pdf", "Plugins/SB_rake_and_splay")
                                else
                                  cmd.small_icon = Sketchup.find_support_file("rake_and_splay.svg", "Plugins/SB_rake_and_splay")
                                  cmd.large_icon = Sketchup.find_support_file("rake_and_splay.svg", "Plugins/SB_rake_and_splay")
                              else
                                cmd.small_icon = Sketchup.find_support_file("rake_and_splay_16.png", "Plugins/SB_rake_and_splay")
                                cmd.large_icon = Sketchup.find_support_file("rake_and_splay_24.png", "Plugins/SB_rake_and_splay")
                              tb = UI;;Toolbar.new("Rake and Splay").add_item(cmd)
                              tb.restore if tb.get_last_state == 1
                              UI.menu("Tools").add_item cmd
                            file_loaded(__FILE__)
                            • PixeroP
                              Pixero
                              Thanks.
                              • Bob JamesB
                                Bob James
                                Thank you, slbaumgartner
                                Would you tell me how to use this for each plugin extension?
                                • Bob JamesB
                                  Bob James
                                  He's right!
                                  I converted and replaced the icons in SketchUcation to .svg at 300pixelsx300pixels at 300dpi but there was no change in SU2018
                                    slbaumgartner
                                    If you're not familiar with Ruby API programming for SketchUp, you might be in over your head as the code needs to be adapted to each specific extension, there is no universal drop-in-place form.
                                    You need to create the appropriate icon files (svg, pdf, and png) for the extension and put them in the extension's folder. Then you need to find where in the extension's code it creates and populates its toolbar and integrate my snippet with whatever the original code does there, which will almost surely vary from case to case.
                                    • fredo6F
                                      For inof, all my plugins can support PNG, SVG and PDF (as everything is managed by LibFredo6).
                                      I am just missing the icons in SVG / PDF
                                      That's just a matter to put the SVG / PDF file in:
                                      • subfolder IMAGES_Standards of the plugin folder (say Fredo6_FredoScale/IMAGES_standard)
                                      • respecting convention: same name as PNG but removing the trailing _24 (or _16 or _32). So FSC_icon_Scale_24.png would become FSC_icon_Scale.svg
                                      • PixeroP
                                        Pixero
                                        Question. Does the svg/PDF icons need to be made in a special size? (I know they are scaleable just wondering if the dokument size should be anything special.)
                                          slbaumgartner
                                          You can draw the icon artwork at whatever size you wish. The view of the contents will be scaled to fit the available space in the toolbar button, so the physical size you drew is irrelevant. But you do need to verify that you haven't put details into the artwork that won't be visible when scaled to a typical toolbar button on a particular size display. Since you probably don't have a lot of different displays available to test, the best practice is to keep your icons fairly simple.
                                          One precaution though: Whatever size you draw, you should keep the drawing canvas square. Otherwise SketchUp will scale it based on the larger dimension and it won't fill the full button in the other direction.
                                          • Bob JamesB
                                            Bob James
                                            Awesome!!
                                            Do I have to re-draw them? Can't I just continue converting them from jpg/png to svg?
                                            • 2 / 3
