    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 171 Watching
    • arqcovaA
      arqcova
      Amazing tool! just got it and paid for it! Thanks!
        Jorgensen
        how do we use the material editor?
        i'm trying to create a curtain that stays almost strait - like a textile with almost no elasticity.
        but it seems that the cloth keeps behaving like it's silk - the curtain extends very much, and 'feels' very light when i push it.
        i have messed around with the material editor, but it does not seem to have any influence on the behavior of the cloth.
        jorgensen
          marvsweden
          I don't think converging pins works on MacOS. The handles change while holding the control-key but I can't actually converge them. Anton can you check?
            Anton_S
            This has been fixed. Update to version 1.1.1, and use the SHIFT key for converging/diverging.
              Anton_S
              jorgensen
              The material manager is just another way to adjust cloth properties and doesn't have any special things to it other than it can be saved and then used as a preset.
              Does increasing shear stiffness not help? If so, try reducing update timestep, to like 1/520. Reducing update timestep makes cloth stiffer.
                marvsweden
                Hey, I'm trying to understand all the settings. I can't see anything about it in the manual. I'm talking about thickness, bend, damper, shear and all that. Am I missing something?
                I'm trying to drape an object with a silk cloth and either it falls through the colliders or the thickness makes it sit up above the colliders too much. Also from what I understand there is an interplay between the grid size and some of the settings for cloth/collider. Is that right? It would be great if that could be covered in some way. Also, tooltips would be welcome for the settings. What are the numbers really, are they linked to the used unit or are they percentage? It's a little unclear. Don't get me wrong, I love it. I just don't understand it. I wanna learn more. πŸ˜„
                  Anton_S
                  If you assume that each edge is a linear spring and each two linked edges are an angular spring, then the shearcontrols the linear spring stiffness and bend controls the angular spring stiffness. As for the damping, it controls the drag factor for both type of springs.
                  Cloth/collider thickness denotes an offset in mm. Other parameters are more associated to cloth mass ratio.
                  Increase simulation viscosity, before draping, to allow the cloth settle in a less impactive way. That way you can avoid most overlaps.
                  Yes. The smaller the grid spacing, the better is the result, but the less stiffer the cloth becomes. This is something that I have to consider improving in next version.
                  To sum it up, the object is to release new version with improved physics and then make tutorials about other ClothWorks options.
                    sofie9536
                    Hello Anton, maybe I missed something, why does ClothWorks ask for the license number every time? (Windows 10)
                    Thank you for your help
                    • K
                      kugelfisch
                      Hallo Anton!
                      I bought you plugin "Clothworks" today (2 hours ago). How long does it usually take for the license to arrive?
                        Anton_S
                        @kugelfisch said:
                        Hallo Anton!
                        It should arrive right away unless you entered a wrong email. I will send you a private message regarding this.
                          Anton_S
                          Hi, Sofie,
                          If you're referring to your licence constantly deactivating, there is an issue with the current version of SketchUcationTools, which I presume would be fixed upon next release cumming soon. We'll see if the issue is fixed then. Other than that, in the meantime, if your licensing seats fill up, let me know via a private message and I will reset them.
                          Anton
                          • V
                            valerostudio
                            This is a fun one! Having a great time playing with it and V-Ray Fur. TAKE MY MONEY!!!
                            • BoxB
                              A little inspiration for all the scifi modelers out there.
                              A flexible hatch.
                              https://i.imgur.com/YIYGvX9.gif
                                rv1974
                                IS animated calculation a mandatoty thing?.
                                May we get a simple 'show end (balanced) result' button?
                                It will also help to understand the influence of the settings. Currently it's close to impossible. Apropo it'd be fantastic to have an auto update mode (on end result) while tweaking those parameters
                                • BoxB
                                  I know I'm doing things it's not really designed for but I like the simplicity of clothworks.
                                  • majidM
                                    majid
                                    Seems stunning and I have an eye on it, does it also have "preventing self collision" option?
                                    • FrederikF
                                      Frederik
                                      @majid said:
                                      ...does it also have "preventing self collision" option?
                                      Of course... πŸ˜„
                                      Cheers
                                      Kim Frederik
                                      • HornOxxH
                                        HornOxx
                                        @valerostudio said:
                                        ...Having a great time playing with it and V-Ray Fur...
                                        πŸ‘ πŸ‘ looks really fantastic - is this fur here is a V-Ray internal feature?
                                        @box said:
                                        A little inspiration for all the scifi modelers out there...
                                        πŸ‘ πŸ‘ not only for the scifis out there πŸ˜„ again magic - a great elastic simulation πŸ‘
                                        never trust a skinny cook
                                        • V
                                          valerostudio
                                          Yes, what you are seeing is V-Ray Fur.
                                          • V
                                            valerostudio
                                            Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
                                            • 11
                                            • 12
                                            • 13
                                            • 36
                                            • 37
                                            • 11 / 37
