[Plugin] FredoTools - v4.5a - 02 Apr 24
@jql said:
Hi Fredo,
I've noticed that your tools don't follow the convention for selecting a surface with a single click.
The selection method is assuming two or more faces connected by a hidden edge to be a surface, while sketchup convention assumes a surface to be at least two faces connected by a soft edge.
Is this by design?
Thanks,
João
In general I assume that if you don't see the edge on the screen, the bounding faces are part of the same click-selection. When Geometry Hidden is turned on, then faces behave as separate.
This may not be what the user wants in some occasions; this is why I also have explicit options with palette buttons.
Which tool of FredoTools are you referring to ?
I'm referring to every tool I guess. I was convinced it had to do with a global selection method defined by LibFredo.
I often require the use of surfaces and treat them as such in Sketchup. But for JPP, reverse/orient faces, or thrupaint, I often had problems and didn't understand why. So I started selectin the surfaces first, with regular sketchup selection tool. So I only recently found out what was happening...
Is this now as you expect?
Fredo,
Is it possible to add Cast Shadows On/Off to the Face Triangulator tool?
Not quite. What I would expect is that only with soft edges, two or more faces would be considered surfaces, as in sketchup.
Never noticed for the Hidden?
Can be done, but this impacts everyone that is used to or prefer the current behavior. Indeed, the strng argument is that this is how Sketchup does the selection.
Well... That's a tough one. Make it coherent with Sketchup or keep it as it is for every user sake?
What if people do what I did and don't use the option as they don't quite understand it?
Or what if, following the hidden preferences you have, you would have an option of surface selection method?
Hi all,
I think this tool will be my savior since I keep finding mismatches on the edges of my sketch. However, when I try to tell it to fix the edges it gives the error "Cannot create unit vector from zero length vector"
Anyone has an idea how to solve this?
Thanks.
Date: 08-Apr-18 14:45:11
An error occurred in Edge Inspector
Error during InspectionCannot create unit vector from zero length vector
body_fredotools__edgeinspector.rbe: 3286 -- axes
body_fredotools__edgeinspector.rbe: 3286 -- zero_edge_disolve_edge
body_fredotools__edgeinspector.rbe: 3269 -- block in zero_edge_absorb_final
body_fredotools__edgeinspector.rbe: 3249 -- each
body_fredotools__edgeinspector.rbe: 3249 -- zero_edge_absorb_final
body_fredotools__edgeinspector.rbe: 3379 -- block in zero_edge_resolve
body_fredotools__edgeinspector.rbe: 3367 -- each
body_fredotools__edgeinspector.rbe: 3367 -- each_with_index
body_fredotools__edgeinspector.rbe: 3367 -- zero_edge_resolve
body_fredotools__edgeinspector.rbe: 2706 -- call
body_fredotools__edgeinspector.rbe: 2706 -- block in execute_fixing
body_fredotools__edgeinspector.rbe: 2703 -- each
body_fredotools__edgeinspector.rbe: 2703 -- each_with_index
body_fredotools__edgeinspector.rbe: 2703 -- execute_fixing
body_fredotools__edgeinspector.rbe: 1713 -- robot_fixing_execute_single
body_fredotools__edgeinspector.rbe: 1703 -- robot_fixing_exec
body_fredotools__edgeinspector.rbe: 1686 -- robot_fixing
body_fredotools__edgeinspector.rbe: 1573 -- block in resolver_fixing
lib6operation.rbe: 332 -- call
lib6operation.rbe: 332 -- step_geometry
lib6operation.rbe: 374 -- start_execution
body_fredotools__edgeinspector.rbe: 1573 -- resolver_fixing
body_fredotools__edgeinspector.rbe: 1924 -- block in palette_floating
body_lib6palette.rbe: 3754 -- call
body_lib6palette.rbe: 3754 -- execute_button
body_lib6palette.rbe: 3559 -- onLButtonUp
lib6palette.rbe: 91 -- onLButtonUp
body_fredotools__edgeinspector.rbe: 786 -- onLButtonUp -
@paragao said:
Hi all,
This looks like a bug (I fixed it). It does mean that you seem to have zero-length edges in your model.
By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
NEW RELEASE: FredoTools v3.2d - 09 Apr 18
FredoTools 3.2d is about bug fixing in EdgeInspector.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
What exactly are we supposed to find in these models?
Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
Error: #<ArgumentError: wrong number of arguments (0 for 1)>
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:ininitialize' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in
new'
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:inshow' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in
time_for_check?'
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:inblock in after_startup' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in
call'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in
require'
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in
require'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:inload' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in
register_extension'
C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in<module:VRay>' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in
<top (required)>' -
Do you have the problem if you disable VRay?
No. But there's also no problem when I only disable Fredo Tools.
It's probably a conflict between Plugin (although I don't have it on my machine with VRay 3.6). So removing one or the other should eliminate the issue.
Bonjour Fredo
Je viens de découvrir un petit problème avec les outils "Volume Solides" et "Étiqueter les Surfaces"(SketchUp Pro 2018).
Je ne peut plus sélectionner les valeurs affichées dans la boite de dialogue, pour les copier (Ctrl + C). Il me semble que le problème soit lié à la dernière mise à jour de Lib Fredo6 (v8.4d). En effet, je ne rencontre pas le problème dans SU Make 2017 que je n'ai mis à jour.
C'est un problème mineur, mais si il existe une solution pour y remédier, je vous en serais très reconnaissant. -
@bharralure said:
Bonjour Fredo
C'est un problème mineur, mais si il existe une solution pour y remédier, je vous en serais très reconnaissant.Thanks for signaling. I identified it and will publish an update to fix it.
When I download the .rbz file...it comes in as a PDF. What's up wtih that?
Where did you download it from? Try from here: https://sketchucation.com/pluginstore?pln=FredoTools
