    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.9k Views 122 Watching
      Areczan
      Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
      Error: #<ArgumentError: wrong number of arguments (0 for 1)>
      c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in initialize' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
      c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
      c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in block in after_startup' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in call'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
      C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in register_extension'
      C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in <top (required)>'
      • fredo6F
        Do you have the problem if you disable VRay?
          Areczan
          No. But there's also no problem when I only disable Fredo Tools.
          • fredo6F
            It's probably a conflict between Plugin (although I don't have it on my machine with VRay 3.6). So removing one or the other should eliminate the issue.
            • B
              bharralure
              Bonjour Fredo
              Je viens de découvrir un petit problème avec les outils "Volume Solides" et "Étiqueter les Surfaces"(SketchUp Pro 2018).
              Je ne peut plus sélectionner les valeurs affichées dans la boite de dialogue, pour les copier (Ctrl + C). Il me semble que le problème soit lié à la dernière mise à jour de Lib Fredo6 (v8.4d). En effet, je ne rencontre pas le problème dans SU Make 2017 que je n'ai mis à jour.
              C'est un problème mineur, mais si il existe une solution pour y remédier, je vous en serais très reconnaissant.
              • fredo6F
                @bharralure said:
                Bonjour Fredo
                Thanks for signaling. I identified it and will publish an update to fix it.
                • X
                  xroo2
                  When I download the .rbz file...it comes in as a PDF. What's up wtih that?
                  • G
                    Gábor
                    Where did you download it from? Try from here: https://sketchucation.com/pluginstore?pln=FredoTools
                    • PixeroP
                      Pixero
                      Maybe you have accidently chosen that rbz files shall open with Acrobat? In that case right click and open with and set it to always open .rbz with SketchUp instead.
                      • X
                        xroo2
                        ..found out that it is just my computer which inserts Adobe icon and suffix for 'whatever' reason. The .rbz file opens find through Extension Manager 😕
                        • fredo6F
                          NEW RELEASE: FredoTools v3.3a - 21 Oct 18
                          Requirement: LibFredo6 v8.6i or above
                          FredoTools 3.3a fixes bugs in FredoTools::ReportLabelArea.
                          See FredoTools plugin home page for Download.
                          See also main post of this thread for User Discussion.
                          • P
                            Pascalou54
                            Bonjour,
                            J'ai toujours une erreur sur SU2017,
                            "erreur de chargement du fichier Fredo6_FredoTools/__loader__FredoTools
                            Could not find included file 'Fredo6_FredoTools/_loader__FredoTools"
                            Dans quel répertoire doit on mettre \Fredo6_FredoTools
                            -_v1.8c ?
                            merci
                              Il vaut mieux utiliser le Ruby rouge pour installer les plugins, comme cela aucun problème de savoir où il faut les installer, dans quels répetoires etc...dans cette jungle de windose! 💚 (bouton rouge [highlight=#ff4040:1j6ys88t]"Installer l'Extension"[/highlight:1j6ys88t] (bas de page)
                              Il faut installer aussi la dernière Fredo Lib avant! 🤓 (avec le même Ruby rouge! 😉
                              Toujours avec le Ruby rouge, il vaut mieux dé-installer les anciennes versions des plugins à venir avec la section "Gérer"! (haut de page)
                              https://i.postimg.cc/GhZ8S2tW/red_ruby.jpg
                                dedmin
                                See the video. Windows 10, SU Pro - all up to date.
                                https://imgur.com/a/jyUEA0P
                                • fredo6F
                                  This is fixed in [url=https://sketchucation.com/pluginstore?pln=LibFredo6:3fes6yqn]LibFredo6 8.6n[/url:3fes6yqn], just published.
                                    dedmin
                                    Thanks, Fredo.
                                      masloprojekt
                                      First of all, a great plugin, the reporting part is probably the only one and the best one available. However, I encountered a problem while using it. I generated a space report sorted by Container. Group of components, components are simple planes. The report looks good and contains correct data, but unfortunately when I try to export to CSV I get a file containing only some kind of the header. There is also no popup confirming the correct export. Has anyone encountered such a problem?
                                      • fredo6F
                                        I guess you talk about the ReportLabelAreatool.
                                        There is a small bug, which exists only for the views by Container and by Layer.
                                        I have fixed them and will republish soon.
                                        PS: this should only happen when the unit contains a square exponent.
                                        • fredo6F
                                          NEW RELEASE: FredoTools v3.3b - 14 Mar 19
                                          FredoTools 3.3b fixes bugs in FredoTools::ReportLabelArea for CSV export, as signaled by masloprojekt.
                                          • fredo6F
                                            NEW RELEASE: FredoTools v3.3c - 24 Mar 19
                                            FredoTools 3.3c fixes bugs in FredoTools::EdgeInspector preneting it to work in SU2019.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 23
                                            • 24
                                            • 16 / 24
