    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.9k Views 122 Watching
    • Mousa_SAM
      Mousa_SA
      @fredo6 said:
      I know there is this random bugsplat, but I am unable to reproduce it in my own environment.
      If you have it, could you send a report to Sketchup in the bugsplat window, note the bugsplat record number and post or send this crash number to me.
      I thought this update has a fix for these random bugsplat. The Bugsplat record number is #37782
      I have sent the bugsplat report to you as a PM.
      • fredo6F
        NEW RELEASE: FredoTools v3.2c - 12 Mar 18
        FredoTools 3.2c fixes a major bug in the calculation of volume in SolidVolume
        See FredoTools plugin home page for Download.
        See also main post of this thread for User Discussion.
          rv1974
          Fredo, in this particular model reverse\ orient tool fails to exit with savedresult. could you take a look? Thanks!
          kkk.rar
          • fredo6F
            I tried on your model but AutoOrientFaces does the job and performs correctly the reversing.
            The issue with your model is that each of the 12 subgroups have a quite large number of faces. In particular the two wheels which have 3,218 faces. The whole model would probably need a rework, because the number of faces seems oversized for a rather boxy shape.
            I would probably need to optimize the algorithm. The white screen is just when processing the two wheels.
            • JQLJ
              JQL
              Hi Fredo,
              I've noticed that your tools don't follow the convention for selecting a surface with a single click.
              The selection method is assuming two or more faces connected by a hidden edge to be a surface, while sketchup convention assumes a surface to be at least two faces connected by a soft edge.
              Is this by design?
              Thanks,
              João
              www.casca.pt
              Visit us on facebook!
              • fredo6F
                @jql said:
                Hi Fredo,
                Is this by design?
                Thanks,
                João
                In general I assume that if you don't see the edge on the screen, the bounding faces are part of the same click-selection. When Geometry Hidden is turned on, then faces behave as separate.
                This may not be what the user wants in some occasions; this is why I also have explicit options with palette buttons.
                Which tool of FredoTools are you referring to ?
                • JQLJ
                  JQL
                  I'm referring to every tool I guess. I was convinced it had to do with a global selection method defined by LibFredo.
                  I often require the use of surfaces and treat them as such in Sketchup. But for JPP, reverse/orient faces, or thrupaint, I often had problems and didn't understand why. So I started selectin the surfaces first, with regular sketchup selection tool. So I only recently found out what was happening...
                  www.casca.pt
                  • fredo6F
                    Is this now as you expect?
                      Fredo,
                      Is it possible to add Cast Shadows On/Off to the Face Triangulator tool?
                      • JQLJ
                        JQL
                        Not quite. What I would expect is that only with soft edges, two or more faces would be considered surfaces, as in sketchup.
                        www.casca.pt
                        • fredo6F
                          Never noticed for the Hidden?
                          Can be done, but this impacts everyone that is used to or prefer the current behavior. Indeed, the strng argument is that this is how Sketchup does the selection.
                          • JQLJ
                            JQL
                            Well... That's a tough one. Make it coherent with Sketchup or keep it as it is for every user sake?
                            What if people do what I did and don't use the option as they don't quite understand it?
                            Or what if, following the hidden preferences you have, you would have an option of surface selection method?
                            www.casca.pt
                            • P
                              PAragao
                              Hi all,
                              I think this tool will be my savior since I keep finding mismatches on the edges of my sketch. However, when I try to tell it to fix the edges it gives the error "Cannot create unit vector from zero length vector"
                              Anyone has an idea how to solve this?
                              Thanks.
                              Date: 08-Apr-18 14:45:11
                              An error occurred in Edge Inspector
                              Error during Inspection
                              body_fredotools__edgeinspector.rbe: 3286 -- axes
                              body_fredotools__edgeinspector.rbe: 3286 -- zero_edge_disolve_edge
                              body_fredotools__edgeinspector.rbe: 3269 -- block in zero_edge_absorb_final
                              body_fredotools__edgeinspector.rbe: 3249 -- each
                              body_fredotools__edgeinspector.rbe: 3249 -- zero_edge_absorb_final
                              body_fredotools__edgeinspector.rbe: 3379 -- block in zero_edge_resolve
                              body_fredotools__edgeinspector.rbe: 3367 -- each
                              body_fredotools__edgeinspector.rbe: 3367 -- each_with_index
                              body_fredotools__edgeinspector.rbe: 3367 -- zero_edge_resolve
                              body_fredotools__edgeinspector.rbe: 2706 -- call
                              body_fredotools__edgeinspector.rbe: 2706 -- block in execute_fixing
                              body_fredotools__edgeinspector.rbe: 2703 -- each
                              body_fredotools__edgeinspector.rbe: 2703 -- each_with_index
                              body_fredotools__edgeinspector.rbe: 2703 -- execute_fixing
                              body_fredotools__edgeinspector.rbe: 1713 -- robot_fixing_execute_single
                              body_fredotools__edgeinspector.rbe: 1703 -- robot_fixing_exec
                              body_fredotools__edgeinspector.rbe: 1686 -- robot_fixing
                              body_fredotools__edgeinspector.rbe: 1573 -- block in resolver_fixing
                              lib6operation.rbe: 332 -- call
                              lib6operation.rbe: 332 -- step_geometry
                              lib6operation.rbe: 374 -- start_execution
                              body_fredotools__edgeinspector.rbe: 1573 -- resolver_fixing
                              body_fredotools__edgeinspector.rbe: 1924 -- block in palette_floating
                              body_lib6palette.rbe: 3754 -- call
                              body_lib6palette.rbe: 3754 -- execute_button
                              body_lib6palette.rbe: 3559 -- onLButtonUp
                              lib6palette.rbe: 91 -- onLButtonUp
                              body_fredotools__edgeinspector.rbe: 786 -- onLButtonUp
                              • fredo6F
                                @paragao said:
                                Hi all,
                                This looks like a bug (I fixed it). It does mean that you seem to have zero-length edges in your model.
                                By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
                                • fredo6F
                                  NEW RELEASE: FredoTools v3.2d - 09 Apr 18
                                  FredoTools 3.2d is about bug fixing in EdgeInspector.
                                  • JQLJ
                                    JQL
                                    What exactly are we supposed to find in these models?
                                    www.casca.pt
                                    • fredo6F
                                      @jql said:
                                      Tiny edges, needle eyes, etc....
                                        Areczan
                                        Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
                                        Error: #<ArgumentError: wrong number of arguments (0 for 1)>
                                        c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in initialize' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
                                        c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
                                        c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in block in after_startup' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in call'
                                        C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require'
                                        C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in register_extension'
                                        C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in <top (required)>'
                                        • fredo6F
                                          Do you have the problem if you disable VRay?
                                            Areczan
                                            No. But there's also no problem when I only disable Fredo Tools.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 23
                                            • 24
                                            • 15 / 24
