    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.9k Views 122 Watching
    • P
      PAragao
      Hi all,
      I think this tool will be my savior since I keep finding mismatches on the edges of my sketch. However, when I try to tell it to fix the edges it gives the error "Cannot create unit vector from zero length vector"
      Anyone has an idea how to solve this?
      Thanks.
      Date: 08-Apr-18 14:45:11
      An error occurred in Edge Inspector
      Error during Inspection
      body_fredotools__edgeinspector.rbe: 3286 -- axes
      body_fredotools__edgeinspector.rbe: 3286 -- zero_edge_disolve_edge
      body_fredotools__edgeinspector.rbe: 3269 -- block in zero_edge_absorb_final
      body_fredotools__edgeinspector.rbe: 3249 -- each
      body_fredotools__edgeinspector.rbe: 3249 -- zero_edge_absorb_final
      body_fredotools__edgeinspector.rbe: 3379 -- block in zero_edge_resolve
      body_fredotools__edgeinspector.rbe: 3367 -- each
      body_fredotools__edgeinspector.rbe: 3367 -- each_with_index
      body_fredotools__edgeinspector.rbe: 3367 -- zero_edge_resolve
      body_fredotools__edgeinspector.rbe: 2706 -- call
      body_fredotools__edgeinspector.rbe: 2706 -- block in execute_fixing
      body_fredotools__edgeinspector.rbe: 2703 -- each
      body_fredotools__edgeinspector.rbe: 2703 -- each_with_index
      body_fredotools__edgeinspector.rbe: 2703 -- execute_fixing
      body_fredotools__edgeinspector.rbe: 1713 -- robot_fixing_execute_single
      body_fredotools__edgeinspector.rbe: 1703 -- robot_fixing_exec
      body_fredotools__edgeinspector.rbe: 1686 -- robot_fixing
      body_fredotools__edgeinspector.rbe: 1573 -- block in resolver_fixing
      lib6operation.rbe: 332 -- call
      lib6operation.rbe: 332 -- step_geometry
      lib6operation.rbe: 374 -- start_execution
      body_fredotools__edgeinspector.rbe: 1573 -- resolver_fixing
      body_fredotools__edgeinspector.rbe: 1924 -- block in palette_floating
      body_lib6palette.rbe: 3754 -- call
      body_lib6palette.rbe: 3754 -- execute_button
      body_lib6palette.rbe: 3559 -- onLButtonUp
      lib6palette.rbe: 91 -- onLButtonUp
      body_fredotools__edgeinspector.rbe: 786 -- onLButtonUp
      • fredo6F
        @paragao said:
        Hi all,
        This looks like a bug (I fixed it). It does mean that you seem to have zero-length edges in your model.
        By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
        • fredo6F
          NEW RELEASE: FredoTools v3.2d - 09 Apr 18
          FredoTools 3.2d is about bug fixing in EdgeInspector.
          See FredoTools plugin home page for Download.
          See also main post of this thread for User Discussion.
          • JQLJ
            JQL
            What exactly are we supposed to find in these models?
            www.casca.pt
            Visit us on facebook!
            • fredo6F
              @jql said:
              Tiny edges, needle eyes, etc....
                Areczan
                Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
                Error: #<ArgumentError: wrong number of arguments (0 for 1)>
                c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in initialize' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
                c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
                c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in block in after_startup' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in call'
                C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require'
                C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in register_extension'
                C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in <top (required)>'
                • fredo6F
                  Do you have the problem if you disable VRay?
                    Areczan
                    No. But there's also no problem when I only disable Fredo Tools.
                    • fredo6F
                      It's probably a conflict between Plugin (although I don't have it on my machine with VRay 3.6). So removing one or the other should eliminate the issue.
                      • B
                        bharralure
                        Bonjour Fredo
                        Je viens de découvrir un petit problème avec les outils "Volume Solides" et "Étiqueter les Surfaces"(SketchUp Pro 2018).
                        Je ne peut plus sélectionner les valeurs affichées dans la boite de dialogue, pour les copier (Ctrl + C). Il me semble que le problème soit lié à la dernière mise à jour de Lib Fredo6 (v8.4d). En effet, je ne rencontre pas le problème dans SU Make 2017 que je n'ai mis à jour.
                        C'est un problème mineur, mais si il existe une solution pour y remédier, je vous en serais très reconnaissant.
                        • fredo6F
                          @bharralure said:
                          Bonjour Fredo
                          Thanks for signaling. I identified it and will publish an update to fix it.
                          • X
                            xroo2
                            When I download the .rbz file...it comes in as a PDF. What's up wtih that?
                            • G
                              Gábor
                              Where did you download it from? Try from here: https://sketchucation.com/pluginstore?pln=FredoTools
                              • PixeroP
                                Pixero
                                Maybe you have accidently chosen that rbz files shall open with Acrobat? In that case right click and open with and set it to always open .rbz with SketchUp instead.
                                • X
                                  xroo2
                                  ..found out that it is just my computer which inserts Adobe icon and suffix for 'whatever' reason. The .rbz file opens find through Extension Manager 😕
                                  • fredo6F
                                    NEW RELEASE: FredoTools v3.3a - 21 Oct 18
                                    Requirement: LibFredo6 v8.6i or above
                                    FredoTools 3.3a fixes bugs in FredoTools::ReportLabelArea.
                                    • P
                                      Pascalou54
                                      Bonjour,
                                      J'ai toujours une erreur sur SU2017,
                                      "erreur de chargement du fichier Fredo6_FredoTools/__loader__FredoTools
                                      Could not find included file 'Fredo6_FredoTools/_loader__FredoTools"
                                      Dans quel répertoire doit on mettre \Fredo6_FredoTools
                                      -_v1.8c ?
                                      merci
                                        Il vaut mieux utiliser le Ruby rouge pour installer les plugins, comme cela aucun problème de savoir où il faut les installer, dans quels répetoires etc...dans cette jungle de windose! 💚 (bouton rouge [highlight=#ff4040:1j6ys88t]"Installer l'Extension"[/highlight:1j6ys88t] (bas de page)
                                        Il faut installer aussi la dernière Fredo Lib avant! 🤓 (avec le même Ruby rouge! 😉
                                        Toujours avec le Ruby rouge, il vaut mieux dé-installer les anciennes versions des plugins à venir avec la section "Gérer"! (haut de page)
                                        https://i.postimg.cc/GhZ8S2tW/red_ruby.jpg
                                          dedmin
                                          See the video. Windows 10, SU Pro - all up to date.
                                          https://imgur.com/a/jyUEA0P
                                          • fredo6F
                                            This is fixed in [url=https://sketchucation.com/pluginstore?pln=LibFredo6:3fes6yqn]LibFredo6 8.6n[/url:3fes6yqn], just published.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 23
                                            • 24
                                            • 16 / 24
