    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • fredo6F Offline
      @steuart said:
      It does not happen if I have had a crash and relaunch SU and straight away start using RoundCorner. On this occasion i was using an existing drawing and worked for about 20/30 mins, then clicked on round corner and it instantly crashed. If I save first then click on Round Corner it is less likely to crash.
      If you get another bugsplat, could you please fill the report dalogbox, send it and send me the Crash report number.
      Many thanks
        ModelMayhem
        Hi Fredo
        Amazing plugins! I use Round corner all the time however since upgrading to any version from 2016 onwards, every time I run the plugin, it appears to effect the faces of the geometry where I get this strange grey to white gradient on the face, then when I try to render it in Keyshot the geometry behaves as if the object was slightly concave, I dont have this issue in version 2015 and earlier, any thoughts as to what this could be? Ive attached some screen shots
        Thanks in advance
        SU 2018
        SU 2016
        rendered example
          I'm unable to duplicate that in SU2018. Can you show the settings you are using when you get it?
          • jujuJ Offline
            juju
            I've seen this before, when there's a bit of smoove going on. Not always desirable.
            • E Offline
              Einstein
              Hi!
              I cannot get to a certain softening result exampled in the manual. Both Borders and Corners are sharp edges there, only Inner Edges are soft and smooth. In my case, Corners are also soft and smooth even though I didn't check them as soft and smooth.
              • fredo6F Offline
                @einstein said:
                Hi!
                Thanks for signaling. Strange that nobody did before, because it is likely dated 207, when SU2017 introduced a change of the API (related to IDs and Explode Group) that screwed up a lot of plugins.
                I fixed it in v3.2f.
                • fredo6F Offline
                  NEW RELEASE: RoundCorner v3.2f - 18 Mar 18
                  RoundCorner 3.2f is a maintenance release. It fixes an old problem for SU2017 and SU2018 related to the configuration of edge properties.
                  Home Page of RoundCorner for information and Download.
                  Main post of this thread.
                  • E Offline
                    Einstein
                    Thanks for the fix!
                    I was also wondering if Round Corner could work woth groups and compos (not only loose geometry), so that we don't have to open a group to chamfer its edges. It would make work much faster with e.g. multiple boxes at once.
                    • fredo6F Offline
                      Not planned with RoundCorner unfortunately.
                        lema
                        https://html5book.ru/wp-content/uploads/2014/10/border-radius1.png
                        such a rounding is possible? (right 2 pictures)
                        • fredo6F Offline
                          Correct. RoundCorner can only perform symmetrical rounding.
                            alexanor
                            Hello everybody!
                            I support lema. Too often this feature is missing.
                            There is also a need to build such corners.
                            I understand that this operation can be done using the Curviloft plug-in, but still, it would be easier and faster.
                            Thank you very much Fredo6 for his work !!!
                              dnassif
                              hi
                              I have make 17 and have downloaded fred 06 and round corner but I am having issues with getting into sketch up need advice place. I have enabled both in sketch up but it doesn't show in tools what do I need to do?
                              • fredo6F Offline
                                @dnassif said:
                                hi
                                How did you install the plugins?
                                • Sketchup Extension manager, after downloading the RBZ files?
                                • or Sketchucation PluginStore tool?
                                • uwesketchU Offline
                                  uwesketch
                                  Rounding an edge excluding the corners generates the arc as connected segments, not a curve/arc.
                                  is it possible that along edges an arc/curve is generated?
                                  That would help a lot in technical drawings where I need to know the radius of the rounding arc.
                                  The corners are generated perfectly.
                                  • fredo6F Offline
                                    @uwesketch said:
                                    This is actually not so easy, because Arc / Curve is a transient property (think of an Arc when deformed by non-uniform scaling).
                                    There are plugins to retrieve the center of an arc, as far I as remember.
                                      SEANHOLMES
                                      I am having this new error can anyone help me out its not allowing me to continue use of this product.
                                      not working
                                        Why not follow the instructions in the message and get the newest version of LibFredo ?
                                        It's available from the PluginStore, just like the related extensions which use that Lib...
                                        Your version is very out of date !
                                        After installing the Lib restart SketchUp to ensure everything gets synced...
                                          josegara
                                          You are god my friend. A brutal tool
                                            josegara
                                            Sketchup owes you
                                            • 73
                                            • 74
                                            • 4 / 74
