    1.5k Posts 476 Posters 3.6m Views 476 Watching
      Steuart
      often when I use Round Corner it crashes Sketchup. If I am working and then click on round corner it almost always crashes. Then when I re-open SU and try using Round Corner it works fine. I have the same problem in SU17 and SU18. I am using a mac on the latest MacOS. (it has been happening for a long time in various versions of MacOS) Any solution to this? The only solution i have found is to close SU and reopen it, which is very frustrating if I am doing a lot of Round Corner. Thanks
      • fredo6F Offline
        Actually, first time I hear about these crashes from users, and also that this has happened before.
        I would suggest you give the list of the other plugins you run in your environment, as some are known to be in conflict with RoundCorner (and other plugins).
          Steuart
          Hi Fredo, Thanks for fast reply. I have: Advanced Camera Tools, Dynamic Components, Sandbox, Trimble Connect (no idea what any of those do), plus your LibFredo6, Curviloft (looks great - only downloaded it yesterday, not tried it out yet), Round Corner. I used to have pipe along, which I think caused similar issues, but have not installed that in SU18. I am running the latest version of everything and Mac OS10.13.3 on a 2013 MacBook pro retina. (new iMac arriving tomorrow)
            Steuart
            @99hash said:
            Hi Fredo,
            Absolutely amazing plugin, I am new to Sketchup and am busy playing with some designs to see if it is worth buying a 3d printer, no point in getting a printer if I cannot create designs to print. This plugin works perfectly for external corners but I cannot seem to get this to work on internal shapes. For example I have cube with a hole through it and would like the edge of the hole rounded. When I use this tool it just erases the hole completely. Is this normal behavior or am I being stupid?
            Thank you for all this work you have put in your tool
            Nick
            Hi Nick, I have printed a number of things from sketchup drawings and it works very well. Good luck! (and I am far from being an expert!!) Steuart
              Steuart
              Hi Fredo, (sorry - did not reply directly to your first reply - just learning the system) Thanks for fast reply. I have: Advanced Camera Tools, Dynamic Components, Sandbox, Trimble Connect (no idea what any of those do), plus your LibFredo6, Curviloft (looks great - only downloaded it yesterday, not tried it out yet), Round Corner. I used to have pipe along, which I think caused similar issues, but have not installed that in SU18. I am running the latest version of everything and Mac OS10.13.3 on a 2013 MacBook pro retina.
              (love the plugin by the way!)
              Steuart
              • fredo6F Offline
                Steuart,
                I suggest you install the latest version of LibFredo6 (v8.1d) and tell me if you get crashes any longer. I fixed some problems of random bugsplats for Curviloft, and it might well be the same origin as for RoundCorner.
                By curiosity,
                1. do you have Souvenir also installed?
                2. Does the crash happens when you launch RoundCorner right after you save the model
                  Steuart
                  @fredo6 said:
                  Steuart,
                  By curiosity,
                  Hi Fredo,
                  Thanks for your reply.
                  I dont have souvenir.
                  If SU crashed and then I re-launched it Round Corner usually worked fine.
                  Last few days I have not had a crash, but I have been regularly saving before trying round corner.
                  I have LibFredo6 8.1, but will try re-installing it, and update you.
                  Steuart
                    Steuart
                    @fredo6 said:
                    Steuart,
                    By curiosity,
                    Hi Fredo,
                    Update.
                    Just updated the libFredo6 to 8.1d (I had not realised there were variations of the 8.1), and restarted the computer, but unfortunately it has not helped as I have just crashed again.
                    Recap:
                    No Souvenir installed.
                    It does not happen if I have had a crash and relaunch SU and straight away start using RoundCorner. On this occasion i was using an existing drawing and worked for about 20/30 mins, then clicked on round corner and it instantly crashed. If I save first then click on Round Corner it is less likely to crash.
                    I have still not used Curviloft and don't know if that would cause the same problem. I dont have any other forms of rendering packages and the only plugins I have are yours and the Tremble ones listed above.
                    A mystery!
                    Steuart
                    • fredo6F Offline
                      If you get another bugsplat, could you please fill the report dalogbox, send it and send me the Crash report number.
                      Many thanks
                        ModelMayhem
                        Hi Fredo
                        Amazing plugins! I use Round corner all the time however since upgrading to any version from 2016 onwards, every time I run the plugin, it appears to effect the faces of the geometry where I get this strange grey to white gradient on the face, then when I try to render it in Keyshot the geometry behaves as if the object was slightly concave, I dont have this issue in version 2015 and earlier, any thoughts as to what this could be? Ive attached some screen shots
                        Thanks in advance
                        SU 2018
                        SU 2016
                        rendered example
                          I'm unable to duplicate that in SU2018. Can you show the settings you are using when you get it?
                          • jujuJ Offline
                            juju
                            I've seen this before, when there's a bit of smoove going on. Not always desirable.
                            • E Offline
                              Einstein
                              Hi!
                              I cannot get to a certain softening result exampled in the manual. Both Borders and Corners are sharp edges there, only Inner Edges are soft and smooth. In my case, Corners are also soft and smooth even though I didn't check them as soft and smooth.
                              • fredo6F Offline
                                @einstein said:
                                Hi!
                                Thanks for signaling. Strange that nobody did before, because it is likely dated 207, when SU2017 introduced a change of the API (related to IDs and Explode Group) that screwed up a lot of plugins.
                                I fixed it in v3.2f.
                                • fredo6F Offline
                                  NEW RELEASE: RoundCorner v3.2f - 18 Mar 18
                                  RoundCorner 3.2f is a maintenance release. It fixes an old problem for SU2017 and SU2018 related to the configuration of edge properties.
                                  Home Page of RoundCorner for information and Download.
                                  Main post of this thread.
                                  • E Offline
                                    Einstein
                                    Thanks for the fix!
                                    I was also wondering if Round Corner could work woth groups and compos (not only loose geometry), so that we don't have to open a group to chamfer its edges. It would make work much faster with e.g. multiple boxes at once.
                                    • fredo6F Offline
                                      Not planned with RoundCorner unfortunately.
                                        lema
                                        https://html5book.ru/wp-content/uploads/2014/10/border-radius1.png
                                        such a rounding is possible? (right 2 pictures)
                                        • fredo6F Offline
                                          Correct. RoundCorner can only perform symmetrical rounding.
                                            alexanor
                                            Hello everybody!
                                            I support lema. Too often this feature is missing.
                                            There is also a need to build such corners.
                                            I understand that this operation can be done using the Curviloft plug-in, but still, it would be easier and faster.
                                            Thank you very much Fredo6 for his work !!!
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 74
                                            • 75
                                            • 63 / 75
