    1.5k Posts 478 Posters 4.3m Views 478 Watching
      I'm unable to duplicate that in SU2018. Can you show the settings you are using when you get it?
      • jujuJ
        juju
        I've seen this before, when there's a bit of smoove going on. Not always desirable.
        • E
          Einstein
          Hi!
          I cannot get to a certain softening result exampled in the manual. Both Borders and Corners are sharp edges there, only Inner Edges are soft and smooth. In my case, Corners are also soft and smooth even though I didn't check them as soft and smooth.
          • fredo6F
            @einstein said:
            Hi!
            Thanks for signaling. Strange that nobody did before, because it is likely dated 207, when SU2017 introduced a change of the API (related to IDs and Explode Group) that screwed up a lot of plugins.
            I fixed it in v3.2f.
            • fredo6F
              NEW RELEASE: RoundCorner v3.2f - 18 Mar 18
              RoundCorner 3.2f is a maintenance release. It fixes an old problem for SU2017 and SU2018 related to the configuration of edge properties.
              Home Page of RoundCorner for information and Download.
              Main post of this thread.
              • E
                Einstein
                Thanks for the fix!
                I was also wondering if Round Corner could work woth groups and compos (not only loose geometry), so that we don't have to open a group to chamfer its edges. It would make work much faster with e.g. multiple boxes at once.
                • fredo6F
                  Not planned with RoundCorner unfortunately.
                  • L
                    lema
                    https://html5book.ru/wp-content/uploads/2014/10/border-radius1.png
                    such a rounding is possible? (right 2 pictures)
                    • fredo6F
                      Correct. RoundCorner can only perform symmetrical rounding.
                        alexanor
                        Hello everybody!
                        I support lema. Too often this feature is missing.
                        There is also a need to build such corners.
                        I understand that this operation can be done using the Curviloft plug-in, but still, it would be easier and faster.
                        Thank you very much Fredo6 for his work !!!
                          dnassif
                          hi
                          I have make 17 and have downloaded fred 06 and round corner but I am having issues with getting into sketch up need advice place. I have enabled both in sketch up but it doesn't show in tools what do I need to do?
                          • fredo6F
                            @dnassif said:
                            hi
                            How did you install the plugins?
                            • Sketchup Extension manager, after downloading the RBZ files?
                            • or Sketchucation PluginStore tool?
                            • uwesketchU
                              uwesketch
                              Rounding an edge excluding the corners generates the arc as connected segments, not a curve/arc.
                              is it possible that along edges an arc/curve is generated?
                              That would help a lot in technical drawings where I need to know the radius of the rounding arc.
                              The corners are generated perfectly.
                              • fredo6F
                                @uwesketch said:
                                This is actually not so easy, because Arc / Curve is a transient property (think of an Arc when deformed by non-uniform scaling).
                                There are plugins to retrieve the center of an arc, as far I as remember.
                                  SEANHOLMES
                                  I am having this new error can anyone help me out its not allowing me to continue use of this product.
                                  not working
                                    Why not follow the instructions in the message and get the newest version of LibFredo ?
                                    It's available from the PluginStore, just like the related extensions which use that Lib...
                                    Your version is very out of date !
                                    After installing the Lib restart SketchUp to ensure everything gets synced...
                                      josegara
                                      You are god my friend. A brutal tool
                                        josegara
                                        Sketchup owes you
                                        • I
                                          ITman496
                                          Hello, I've been a loyal user of this tool for a very long time, great work!
                                          I've been trying for a long time to get it to sort of.. maintain a radius when rounding a corner. For example, I'm trying to set up a part and calculate pocket cuts of a CNC machine's endmill, when it can't accurately do an interior corner because of the size of the endmill. When I round with say a 1/8" radius, it seems to do a non-circular rounding when doing anything other then 90 degrees. Is there a solution for this? Doing it manually sucks πŸ˜ƒ
                                          Here is a picture for an example. I want the right's inner bends, but the plugin instead gives me what's on the left.
                                            I've never noticed that but you're right.
                                            At least for now you could use TIG's 2D Fillet from his 2D Tools set.
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 74
                                            • 75
                                            • 64 / 75
