    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.3k Views 166 Watching
      @box said:
      I look forward to the day when I can drop my balls into soft leather.
      ๐Ÿ˜ฎ You should write romantic novels
      • BoxB
        Let me know Rich if you need me to scribble a valentines or anniversary card for you.
        • PixeroP
          Pixero
          Possible BUG: In the Time step drop down there are two 1/840.
          • C
            cowboyathome
            I'm trying to do some curtains and am not seeing the grab handles to converge the pins.
            Is that a licensed option?
              Read the instructions PDF. You'll see what is not enabled if you haven't licensed it yet.
              Pins require a license.
              • C
                cowboyathome
                Ok. Thanks.
                • alvisA
                  alvis
                  Wow. Impressive. Big thanks.
                  • FrederikF
                    Frederik
                    ๐Ÿคฃ
                    You two love birds...! ๐Ÿคฃ
                    Cheers
                    Kim Frederik
                    • OxerO
                      Oxer
                      Incredible plugin!! ๐Ÿ‘
                      I'll test it on Mac, if it works, I'll never come back to Blender to make clothes simulation.
                        The only issue on Mac is the on reboot the license needs validating each time. We'll issue a fix for that next week.
                        • OxerO
                          Oxer
                          Thanks for the info Rich.
                          • HornOxxH
                            HornOxx
                            ๐Ÿ˜ณ ๐Ÿ˜ณ
                            OMG it is so embarrassing for me to post this question in the forum - I can not understand how an activation or a license purchase work, more precisely neither how nor where. My lack of English does not allow me to understand what is explained in the manual PDF ๐Ÿ˜ณ
                            Since this tool is again such a milestone obviously I also want to try and use it and can hardly wait - please help me (btw - the plugin installation worked perfectly)
                            never trust a skinny cook
                              Use Extensions > ClothWorks > License...
                              Click Obtain License...
                              Sign in to your SketchUcation account and purchase with PayPal.
                              License unlocks all the features mentioned in the manual.
                              • fredo6F
                                @hornoxx said:
                                :oops: ๐Ÿ˜ณ
                                You can test the license workflow with my Plugin Souvenir, which uses the same SCF License, but is completely FREE. So you can try as many times as you wish.
                                • dereiD
                                  derei
                                  I played a bit with ClothWorks and I can say it blew my panties off ๐Ÿ’š
                                  Anyway, I would have some suggestions:
                                  • quick reset button for sliders (for example, to quickly reset gravity to default, or wind to zero, etc). This is because while simulation is running, sliders may be have a lag in response time, but one click button would be much faster.
                                  • some sliders (drag, viscosity, etc) could use a non-linear variation, because as they are now, the slightest move of the cursor can jump the value a lot. Probably at the left end of the slider, the increase should be slower and increase the value following a exponential curve (or other function, should be tested)
                                  • like Fredo's Animator, this plugin could make use of automatic video exporting, using FFMPEG, for example.
                                  Thanks for a wonderful plugin!
                                  the clip speed had to be increased 5x, because the animation was incredibly slow in SketchUp
                                  DESIGNER AND ARTIST DEREI.UK
                                  • Bob JamesB
                                    Bob James
                                    An amazing tool!!
                                    Is it possible to adapt it to drape a flag vertically at rest on a pole? For example, a flag standing on pole inside a room.
                                    • boofredlayB
                                      boofredlay
                                      Yep
                                      Click image to see gif.
                                        alpro
                                        Looks awesome.....off to get it now
                                          Anton_S
                                          Here is a higher resolution simulation of an American Flag.
                                          A roughly 100cm X 170cm rectangle was drawn for the flag and applied a grid with spacing of 4cm.
                                          The pole was assigned a collider state. Pins were attached at upper and lower right corners of the flag.
                                          Using ClothWorks UI, flag thickness was increased to 20mm to prevent self-overlaps.
                                          After simulation, I applied loop subdivision and followed with 2 Laplacian smoothing iteration to eliminate rounded corners formed by loop subdivision.
                                          A texture was assigned at the end, utilizing the Toggle Draped option.
                                          UnitedStatesFlag.skp
                                            More play
                                            • 35
                                            • 36
                                            • 2 / 36
