    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 883.3k Views 166 Watching
    • PixeroP
      Pixero
      Bought it. Now off to try it out....
      Edit: Wohooo! It's soo fun.
      How will I ever get any work done anymore. ๐Ÿ˜†
      • BoxB
        @faust07 said:
        Hi, Anton. Impressive result.The dream would be to have such flexible surfaces also in MSPhysics... ๐Ÿ‘
        My thoughts exactly, I look forward to the day when I can drop my balls into soft leather.
        Here's a quick example of combining MSPhysics with Clothworks and a bit of SUbD hiding underneath.
          ๐Ÿ˜ฎ You should write romantic novels
          • BoxB
            Let me know Rich if you need me to scribble a valentines or anniversary card for you.
            • PixeroP
              Pixero
              Possible BUG: In the Time step drop down there are two 1/840.
              • C
                cowboyathome
                I'm trying to do some curtains and am not seeing the grab handles to converge the pins.
                Is that a licensed option?
                  Read the instructions PDF. You'll see what is not enabled if you haven't licensed it yet.
                  Pins require a license.
                  • C
                    cowboyathome
                    Ok. Thanks.
                    • alvisA
                      alvis
                      Wow. Impressive. Big thanks.
                      • FrederikF
                        Frederik
                        ๐Ÿคฃ
                        You two love birds...! ๐Ÿคฃ
                        Cheers
                        Kim Frederik
                        • OxerO
                          Oxer
                          Incredible plugin!! ๐Ÿ‘
                          I'll test it on Mac, if it works, I'll never come back to Blender to make clothes simulation.
                            The only issue on Mac is the on reboot the license needs validating each time. We'll issue a fix for that next week.
                            • OxerO
                              Oxer
                              Thanks for the info Rich.
                              • HornOxxH
                                HornOxx
                                ๐Ÿ˜ณ ๐Ÿ˜ณ
                                OMG it is so embarrassing for me to post this question in the forum - I can not understand how an activation or a license purchase work, more precisely neither how nor where. My lack of English does not allow me to understand what is explained in the manual PDF ๐Ÿ˜ณ
                                Since this tool is again such a milestone obviously I also want to try and use it and can hardly wait - please help me (btw - the plugin installation worked perfectly)
                                never trust a skinny cook
                                  Use Extensions > ClothWorks > License...
                                  Click Obtain License...
                                  Sign in to your SketchUcation account and purchase with PayPal.
                                  License unlocks all the features mentioned in the manual.
                                  • fredo6F
                                    @hornoxx said:
                                    :oops: ๐Ÿ˜ณ
                                    You can test the license workflow with my Plugin Souvenir, which uses the same SCF License, but is completely FREE. So you can try as many times as you wish.
                                    • dereiD
                                      derei
                                      I played a bit with ClothWorks and I can say it blew my panties off ๐Ÿ’š
                                      Anyway, I would have some suggestions:
                                      • quick reset button for sliders (for example, to quickly reset gravity to default, or wind to zero, etc). This is because while simulation is running, sliders may be have a lag in response time, but one click button would be much faster.
                                      • some sliders (drag, viscosity, etc) could use a non-linear variation, because as they are now, the slightest move of the cursor can jump the value a lot. Probably at the left end of the slider, the increase should be slower and increase the value following a exponential curve (or other function, should be tested)
                                      • like Fredo's Animator, this plugin could make use of automatic video exporting, using FFMPEG, for example.
                                      Thanks for a wonderful plugin!
                                      the clip speed had to be increased 5x, because the animation was incredibly slow in SketchUp
                                      DESIGNER AND ARTIST DEREI.UK
                                      • Bob JamesB
                                        Bob James
                                        An amazing tool!!
                                        Is it possible to adapt it to drape a flag vertically at rest on a pole? For example, a flag standing on pole inside a room.
                                        • boofredlayB
                                          boofredlay
                                          Yep
                                          Click image to see gif.
                                            alpro
                                            Looks awesome.....off to get it now
                                            • 35
                                            • 36
                                            • 2 / 36
