    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] QuadFaceTools
    673 Posts 116 Posters 499.3k Views 116 Watching
    • O Offline
      optimaforever
      Hello Thomas,
      I can't find a good value for quadding a helix staircase made thanks to Eneroth's Upright extruder.
      Do you know a solution? I tried max angles of 1-10ยฐ but this produces awkward triangulated meshes.
      I already asked Julia if she could update her plugin to automatically generate QFT quads but I'm in a hurry (as usual)... ๐Ÿ˜„
      Thanks in advance,
      upright extruder (eneroth)
      • HornOxxH Offline
        HornOxx
        ...even though I can't say anything constructive about your interesting question - this staircase is so amazing! ๐Ÿ‘
        never trust a skinny cook
        • BoxB Offline
          Have you tried Convert Triangulated mesh to quads?
          • HornOxxH Offline
            HornOxx
            ๐Ÿ‘ ๐Ÿ˜ฎ that's impressive again Box - how did you get the "triangled mesh to quad's" operation work on the entire model after selecting these few entries only then? I try to reproduce this but unfortunately without success so far
            • O Offline
              optimaforever
              @box said:
              That is how it works, you need to only select to faces and an edge then hit the button and wait. It should work through all connected faces. Look in the bottom left corner and watch it do its job. How long depends on your pc and the complexity of the model.
              ahah I didnโ€™t know that. I was wondering how the script worked but your explanation makes sense, thanks!
              What max angle value do you use?
              • BoxB Offline
                That is how it works, you need to only select two faces and an edge then hit the button and wait. It should work through all connected faces. Look in the bottom left corner and watch it do its job. How long depends on your pc and the complexity of the model.
                • O Offline
                  optimaforever
                  Jeez I can't get it to work right...
                  Is there a trick? I always end up with some diamond shapes instead of rectangles... even though my geometry is perfectly rational...
                  I tried the one diagonal edge + 2 adjacent triangles selection technique (once on the border, next in the middle, then on the upperface) but without luck.
                  Is there a video explaining how the make quad function works?
                  • HornOxxH Offline
                    HornOxx
                    First - thank you Box for demonstrating this Quad Face Tool feature - I've never understood how it works so far ๐Ÿ˜ณ ( just like some other buttons here as well ๐Ÿ˜ณ ๐Ÿ˜ณ )
                    @ Optimaforever - Like you, I couldn't get it to work. But now I've found a way to do it too - with one more simple step than in Boxยดs demonstration. Before I use QFT like Box did, I unsmoothed the entire geometry first. This worked !! ๐Ÿ˜„ so please give this way a try as well ...
                    ( not a video though but my very first GIF here ๐Ÿ˜‰ )
                    TriToQuad Test Gif
                    • O Offline
                      optimaforever
                      Ok I've found the problem.
                      I was using "convert wireframes to quads" instead of "convert triangulated mesh to quads"
                      Jeeez... doh!
                      • gudio83G Offline
                        gudio83
                        Hi everybody,
                        is anyone else who have a problem with importing .obj files?
                        When I convert .obj to skp with simlab composer, this take me a seconds. When I try with SU (Quad FaceTools) take me over 30min. I've tried on my laptop too, but the same result. Is it normal?
                          Have you tried with an another OBJ Importer like the Tig One ?
                          And there is not native Import OBJ file with the SU Pro version ?
                          Can you post your OBJ file ?
                          • gudio83G Offline
                            gudio83
                            No, I've never tried Tig One, but will try.
                            I have the same problem with all obj files. I've downloaded a lot of models, created on max or cinema4d and i've tried to convert them directly in sketchup, but its very slow.
                            • HieruH Offline
                              Hieru
                              Isn't that just softening the triangulation? Box's demo seems to be removing the triangulation altogether and that's certainly something I can't replicate.
                              www.davidhier.co.uk
                              • gudio83G Offline
                                gudio83
                                How and where you unsmooth the geometry, when the problem its loading model?
                                With simlab composer its easy, but out of sketchup
                                • HornOxxH Offline
                                  HornOxx
                                  Hi All - I can't get the two functions Build Corners and Build Ends to run.
                                  Hopefully someone can tell me what I'm doing wrong โ“ ๐Ÿ˜• Thanks!
                                  cklick to run GIF
                                    Works for me! ๐Ÿ˜„
                                    in any orientations of the "plane"! (your is vertical) mine horizontal ๐Ÿ˜„
                                    Post your file! (V6) for a more large audience! ๐Ÿ˜‰
                                    I suspect some overlaped lines or hidden lines trimed or not or...
                                    • HornOxxH Offline
                                      HornOxx
                                      thanks Pilou - itยดs running like yours on my SkUp 2016 Pro (in the company) but sadly not on my private SkUp 2015, 2016 or 2017 Make which is my Quad-SubD-things computer ๐Ÿ˜• ...
                                        If you are sure of your drawings that is a big mystery! ๐Ÿ˜ฒ
                                        • O Offline
                                          optimaforever
                                          Hornoxx, what's sure is you only need to preselect an edge, not the surfaces along the edge.
                                          You also need to be sure that the rim edges are continuous and not splitted, otherwise the quad making is impossible.
                                          • O Offline
                                            optimaforever
                                            hi Thom!
                                            Is there a neat way of doing a offset of a loop towards the outside of a mesh?
                                            I know your "hidden" offset loop function indeed offset loops but only inside an alreay defined mesh.
                                            So long I use R Wilson's "extrude along path" and then delete the unneeded faces but it can quickly become a mess if the path is complex and not in an horizontal plane.
                                            Is it difficult to program an offset of a loop along a predefined XY/YZ/XZ plane (each point of the loop is offset along a horizontal or vertical plane and then relinked to form an offset loop) ?
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
