    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 415.3k Views 92 Watching
      There appear to have been a regression in V1.2. I have it logged. But no fix as of yet.
      • O Offline
        optimaforever
        Thomas, you mean it was possible earlier?
          You know what, I'm a little unsure to be honest. I might be confusing it with the non-gizmo Move tool...
          • HieruH Offline
            Hieru
            I'm fairly certain it was a feature a while back, but was then lost in an update.
            I've mentioned it before and seem to recall you saying that it was on your to-do list for Version 2, but I could be wrong.
            www.davidhier.co.uk
              Yea - that sounds familiar. The work on SUbD made me forget some of the details of existing Vertex Tools issues. Seeing how VT2 is taking longer to complete, I may have to do a bug patch to v1.2.
              • N Offline
                numerobis
                As i said earlier i would prefer a simple edge constraint toggle like in max instead of having to align the gizmo first every time i want to move a vertex along an edge...
                  MichaelSiggers
                  Hi @thomthom
                  This is a genius plugin!
                  Purchased a couple of days ago and I love it.
                  Only thing is, I second the comment about being able to type in a distance when moving a selection with the Gizmo.
                  Brilliant work though. Thankyou.
                  Kind regards
                  Mike
                    Version 1.2.11
                    Improvements
                    • Added Serbian translations.
                    • Added Albanian translations.
                    • Updated Spanish translations.
                    Fixes
                    • Fixed Gizmo VCB adjustments not working.
                      MichaelSiggers
                      Thank you Thomas πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                      Mike
                      • O Offline
                        optimaforever
                        Great!
                        To be sure:
                        1. select vertices
                        2. use VT's select mode (gizmo) and begin moving the vertices along red, green or blue axis.
                        3. WHILE keeping left mouse button down, type desired value in VCB. type enter.
                        4. the vertices gets moved along axis
                        5. RELEASE left mouse button.
                        Once you release the LMB, VCB awaits for soft select radius value, so it doesn't work like the move tool of Sketchup, where you can change your mind afterwards and tweak the move value.
                        Is it correct?
                        PS I realized that this behaviour works also for scale and rotate. Type value in VCB while keeping LMB pressed down. Once you press enter, the vertices gets modified according to the value.
                        It's just tricky for cases where I need to press Shift with my left hand while keeping the LMB pressed down. I noticed that you can release Shift after you began the scale movement and type a value in the VCB but you can't move the mouse otherwise the Shift indication gets lost.
                          With 1.2.11 you should be able to adjust after releasing LMB.
                          • O Offline
                            optimaforever
                            Thanks Thomas.
                            It works indeed as you said.
                            However I think I have a problem with the latest VT as it hangs SU at launch.
                            And second, when I try to Ctrl+move an edge AND type a value in the VCB afterwards, it bugs.
                            • Bob JamesB Offline
                              Bob James
                              Should I assume that "Make Planar to a custom plane" won't happen until V2?
                                SU freeze? Permanently? I see no reason for any change in startup. Minimal code was touched...
                                Is this a new bug?
                                • O Offline
                                  optimaforever
                                  I don't know if this is a new bug but it happens right after typing the value in the VCB. Your bug window appears and I have already sent the bug message to you.
                                    I'm able to reproduce. I think I have a fix, but I need to test if it breaks other stuff.
                                      Version 1.2.12
                                      Fixes
                                      • Fixes VCB adjustments for Gizmo Ctrl+Move.
                                      • O Offline
                                        optimaforever
                                        Cool. that was fast.
                                        • O Offline
                                          optimaforever
                                          About the hanging issue, it's very strange.
                                          It takes around 5-10 min after launching SU to be actually available (move in the viewport).
                                          Where can I check the launching log of SU?
                                            There is none...
                                            The lag goes away if you disable or remove VT?
                                            • 33
                                            • 34
                                            • 2 / 34
