    [Plugin] QuadFaceTools
    673 Posts 116 Posters 543.8k Views 116 Watching
    • OxerO Offline
      Oxer
      Hi, is QuadFaceTools compatible with Sketchup 2018?
      I don't know what plugins are or not compatible with Sketchup 2018, for this reason I will wait to update to SU2018.
      • HornOxxH Offline
        HornOxx
        @oxer said:
        ...for this reason I will wait to update to SU2018.
        ...nevertheless you could always install any new version in parallel, as long as you didn't make the mistake of deinstalling an existing and running version ๐Ÿ˜‰
        hopefully I'm not wrong - there will be no more SU 2018 Make version (??) - so better keep your SU 2017 Make.
        never trust a skinny cook
        • OxerO Offline
          Oxer
          Thanks for the info!!
          • O Offline
            optimaforever
            Hello Thomas,
            I can't find a good value for quadding a helix staircase made thanks to Eneroth's Upright extruder.
            Do you know a solution? I tried max angles of 1-10ยฐ but this produces awkward triangulated meshes.
            I already asked Julia if she could update her plugin to automatically generate QFT quads but I'm in a hurry (as usual)... ๐Ÿ˜„
            Thanks in advance,
            upright extruder (eneroth)
            • HornOxxH Offline
              HornOxx
              ...even though I can't say anything constructive about your interesting question - this staircase is so amazing! ๐Ÿ‘
              • BoxB Offline
                Have you tried Convert Triangulated mesh to quads?
                • HornOxxH Offline
                  HornOxx
                  ๐Ÿ‘ ๐Ÿ˜ฎ that's impressive again Box - how did you get the "triangled mesh to quad's" operation work on the entire model after selecting these few entries only then? I try to reproduce this but unfortunately without success so far
                  • O Offline
                    optimaforever
                    @box said:
                    That is how it works, you need to only select to faces and an edge then hit the button and wait. It should work through all connected faces. Look in the bottom left corner and watch it do its job. How long depends on your pc and the complexity of the model.
                    ahah I didnโ€™t know that. I was wondering how the script worked but your explanation makes sense, thanks!
                    What max angle value do you use?
                    • BoxB Offline
                      That is how it works, you need to only select two faces and an edge then hit the button and wait. It should work through all connected faces. Look in the bottom left corner and watch it do its job. How long depends on your pc and the complexity of the model.
                      • O Offline
                        optimaforever
                        Jeez I can't get it to work right...
                        Is there a trick? I always end up with some diamond shapes instead of rectangles... even though my geometry is perfectly rational...
                        I tried the one diagonal edge + 2 adjacent triangles selection technique (once on the border, next in the middle, then on the upperface) but without luck.
                        Is there a video explaining how the make quad function works?
                        • HornOxxH Offline
                          HornOxx
                          First - thank you Box for demonstrating this Quad Face Tool feature - I've never understood how it works so far ๐Ÿ˜ณ ( just like some other buttons here as well ๐Ÿ˜ณ ๐Ÿ˜ณ )
                          @ Optimaforever - Like you, I couldn't get it to work. But now I've found a way to do it too - with one more simple step than in Boxยดs demonstration. Before I use QFT like Box did, I unsmoothed the entire geometry first. This worked !! ๐Ÿ˜„ so please give this way a try as well ...
                          ( not a video though but my very first GIF here ๐Ÿ˜‰ )
                          TriToQuad Test Gif
                          • O Offline
                            optimaforever
                            Ok I've found the problem.
                            I was using "convert wireframes to quads" instead of "convert triangulated mesh to quads"
                            Jeeez... doh!
                            • gudio83G Offline
                              gudio83
                              Hi everybody,
                              is anyone else who have a problem with importing .obj files?
                              When I convert .obj to skp with simlab composer, this take me a seconds. When I try with SU (Quad FaceTools) take me over 30min. I've tried on my laptop too, but the same result. Is it normal?
                                Have you tried with an another OBJ Importer like the Tig One ?
                                And there is not native Import OBJ file with the SU Pro version ?
                                Can you post your OBJ file ?
                                • gudio83G Offline
                                  gudio83
                                  No, I've never tried Tig One, but will try.
                                  I have the same problem with all obj files. I've downloaded a lot of models, created on max or cinema4d and i've tried to convert them directly in sketchup, but its very slow.
                                  • HieruH Offline
                                    Hieru
                                    Isn't that just softening the triangulation? Box's demo seems to be removing the triangulation altogether and that's certainly something I can't replicate.
                                    www.davidhier.co.uk
                                    • gudio83G Offline
                                      gudio83
                                      How and where you unsmooth the geometry, when the problem its loading model?
                                      With simlab composer its easy, but out of sketchup
                                      • HornOxxH Offline
                                        HornOxx
                                        Hi All - I can't get the two functions Build Corners and Build Ends to run.
                                        Hopefully someone can tell me what I'm doing wrong โ“ ๐Ÿ˜• Thanks!
                                        cklick to run GIF
                                          Works for me! ๐Ÿ˜„
                                          in any orientations of the "plane"! (your is vertical) mine horizontal ๐Ÿ˜„
                                          Post your file! (V6) for a more large audience! ๐Ÿ˜‰
                                          I suspect some overlaped lines or hidden lines trimed or not or...
                                          • HornOxxH Offline
                                            HornOxx
                                            thanks Pilou - itยดs running like yours on my SkUp 2016 Pro (in the company) but sadly not on my private SkUp 2015, 2016 or 2017 Make which is my Quad-SubD-things computer ๐Ÿ˜• ...
                                            • 33
                                            • 34
                                            • 7 / 34
