    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 526.2k Views 102 Watching
      dmorong
      I am having problems with the texture mapping gizmo in Thrupaint. When I click on a surface the gizmo appears for a moment, but then goes away before I can make any changes with it. I have reinstalled both Fredo6 Tools and LibFredo.
      Looking for any tips on getting the little gizmo to stick around long enough to be useful.
      Macbook Pro 16" (M1)
      Mac 12.1
      Sketchup 22.0.353
      • fredo6F Offline
        @dmorong
        Difficult for me to reproduce, as I don't have a Mac and I cannot reproduce the problem on Windows.
        Maybe a Mac user can help. But first time I hear about that problem.
          dmorong
          I tried the plugin in a computer lab over the weekend with Late 2015 4K iMacs running 10.11 and had the same issue.
          I am attaching a short screen capture showing what is happening. Sampling, painting into groups and mapping controls all work fine, but the single click on the surface to bring up the mapping adjustment tool results in just a flash of the gizmo and corresponding window, and then it goes away before any adjustments can be made.
          Let me know if I can provide you with any other information on the problem.
          David
          thrupaint.mov
          Mac 12.1
          Sketchup 22.0.353
          • fredo6F Offline
            Could you open the Ruby Console, when running ThruPaint, just in case there is an error message.
              dmorong
              Nothing shows up in the Ruby Console when running the Extension.
              David
              Mac 12.1
              Sketchup 22.0.353
              • fredo6F Offline
                David,
                When you hover over the painted surface, could you type Enter. This also goes into the Edition mode.
                  dmorong
                  Yes, anytime you hover over the surface, as long as you see the small postit that indicates the mapping (Front Quadmesh, Natural, or Projected) you can hit enter and the adjustment gizmo will come up and stay so it can be manipulated. Thanks for pointing out that key command. That solves the problem
                  David
                  Mac 12.1
                  Sketchup 22.0.353
                  • pbacotP Offline
                    I didn't realize it but that non-uniform scaling function does not work in the "natural" UV setting (it's "non-deforming")
                    • pep75P Offline
                      pep75
                      I was wondering if someone can tell me where the sliders are on the visual tool in ThruPaint? I used to scale(non uniform) textures in U and V direction seperately but cannot right now. What am I doing wrong?
                      Thanks in advance!
                      • pep75P Offline
                        pep75
                        Thanks Pbacot! ๐Ÿ˜„
                        • fredo6F Offline
                          This is correct. In Natural mode, the textures are never deformed, because the UV mapping is computed by propagation in all direction (so no real geometric reference to rely on, unlike the Projected or Quad modes)
                          • pep75P Offline
                            pep75
                            Thanks a lot Fredo!
                              rv1974
                              Hi Fredo, recently I was fantasizing about extra feature for Pantthru. Please take a look at attached. The idea is to jitter the UVW's of multiple objects according to user input (in %% for each dimention). And it should work regardless the context (as ThruPaint does).
                              In attached picture UVW's of 3 instances of one component were jittered in U/V dimention.
                              • E Offline
                                Einstein
                                Hi!
                                Is it possible to perform a single-face texture transformation (move, rotate, scale) after the texture was distributed onto a group of faces?
                                I applied a texture to a whole group, containing several faces. Then I changed Selection mode from "All faces" to "Face by Face" cuz I want to rotate texture on one particular face only. But this way it seems to impossible as I have already used "All faces" mode.
                                In this case the native tool "Texture > Position" is not preset in drop-down menu. Otherwise I would use it.
                                • fredo6F Offline
                                  @einstein said:
                                  Hi!
                                  ThruPaint precisely keeps track of face grouping, whatever is the original mode of selection.
                                  So, you need to re-apply the same texture to the single face, and then you can freely transform around the texture on this single face.
                                  • E Offline
                                    Einstein
                                    Right, that's simple. I didn't think about it at the beginning, thank you.
                                    • E Offline
                                      Einstein
                                      There's another problem now. I have a model which always crashes when I try to use Thru Paint. I click at the icon in Fredo Tools toolbar and boom! Bugsplat. Any other model won't do it (even more complex), only this particular one. The model had to be fixed once by SketchUp but now it doesn't call for fixing.
                                      It hasn't been like this at the beginning. Thru Paint was working fine, then I did something, don't know what, and it started triggering bugsplats. Perhaps it was that automatic fix?
                                      The material I'm trying to use is a texture that comes from In Model library, so it was already used in my model.
                                      What's more, if I copy any group or compo from this model and paste it to a new model, the same thing happens. I'm very sad about that ๐Ÿ˜ž
                                      Could somebody take a look if it also happens with their computer?
                                      /Win 7 64bit, SU 17
                                      hala sportowa wyciฤ…g.skp
                                        jkoll66
                                        Hi! Great plugin! I am having issues with Sketchup hanging when I use the Thrupaint plugin. Especially, with large or complex models. Any suggestions? Thanks in advance!
                                          amirmiked12
                                          i textured my model using one texture .but when i try to export it i have 145 textures exported.i think it exported textures for everyface
                                          how can i fix it?somebody plz help
                                          • fredo6F Offline
                                            @einstein said:
                                            Hi!
                                            Don't know why but I don't have these handles for non-uniform scaling. This is the screenshot of tutorial. I marked them with two white rectangles. I have just lines in this place.
                                            In Natural UV mode, only the uniform scaling can be supported. So use Projected UV or QuadMesh UV instead.
                                            • 16
                                            • 17
                                            • 6 / 17
