    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 625.0k Views 102 Watching
    • soloS
      @rich o brien said:
      There's a setting in the ThruPaint parameters that toggles it on/off. By default it's off so at some point you turned it on.
      I unchecked that option but still pops up when I use SU material editor
      edit F9 worked. Doh!
        Is that on or off?
          mwm5053
          A question. Would someone look at these settings and tell me why I can't seem to rotate or otherwise scale this texture? When I rotate or scale the texture with the gizmo nothing happens.
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
            mwm5053
            Dah I had the faces reversed didn't realize that and ThruPaint settings were set to front face.
            2011 iMac
            V2 Twilight
            • jujuJ
              juju
              Another D'oh book entry? 😉
              • tuna1957T
                tuna1957
                Been back at trying to get better with SubD and Quadface Tools and ran into this situation with Thru Paint. Modeled a pillow with above mentioned tools. The model passed the Quad Tools analyze function. Tried to texture the model with Thru Paint using the "paint quads" function. Piping textured fine, tried for the rest of the model and get error message there is problem with models quads. Don't know why it's doing this. Something I did wrong or am I asking Thru Paint to do something it really can't do ? Still in the learning stages with quad modeling. Attached a screen shot showing what happened. Thru Paint highlighted the row of quads in all four corners.
                  dmorong
                  I am having problems with the texture mapping gizmo in Thrupaint. When I click on a surface the gizmo appears for a moment, but then goes away before I can make any changes with it. I have reinstalled both Fredo6 Tools and LibFredo.
                  Looking for any tips on getting the little gizmo to stick around long enough to be useful.
                  Macbook Pro 16" (M1)
                  Mac 12.1
                  Sketchup 22.0.353
                  • fredo6F
                    @dmorong
                    Difficult for me to reproduce, as I don't have a Mac and I cannot reproduce the problem on Windows.
                    Maybe a Mac user can help. But first time I hear about that problem.
                      dmorong
                      I tried the plugin in a computer lab over the weekend with Late 2015 4K iMacs running 10.11 and had the same issue.
                      I am attaching a short screen capture showing what is happening. Sampling, painting into groups and mapping controls all work fine, but the single click on the surface to bring up the mapping adjustment tool results in just a flash of the gizmo and corresponding window, and then it goes away before any adjustments can be made.
                      Let me know if I can provide you with any other information on the problem.
                      David
                      thrupaint.mov
                      Mac 12.1
                      Sketchup 22.0.353
                      • fredo6F
                        Could you open the Ruby Console, when running ThruPaint, just in case there is an error message.
                          dmorong
                          Nothing shows up in the Ruby Console when running the Extension.
                          David
                          Mac 12.1
                          Sketchup 22.0.353
                          • fredo6F
                            David,
                            When you hover over the painted surface, could you type Enter. This also goes into the Edition mode.
                              dmorong
                              Yes, anytime you hover over the surface, as long as you see the small postit that indicates the mapping (Front Quadmesh, Natural, or Projected) you can hit enter and the adjustment gizmo will come up and stay so it can be manipulated. Thanks for pointing out that key command. That solves the problem
                              David
                              Mac 12.1
                              Sketchup 22.0.353
                              • pbacotP
                                I didn't realize it but that non-uniform scaling function does not work in the "natural" UV setting (it's "non-deforming")
                                • pep75P
                                  pep75
                                  I was wondering if someone can tell me where the sliders are on the visual tool in ThruPaint? I used to scale(non uniform) textures in U and V direction seperately but cannot right now. What am I doing wrong?
                                  Thanks in advance!
                                  • pep75P
                                    pep75
                                    Thanks Pbacot! 😄
                                    • fredo6F
                                      This is correct. In Natural mode, the textures are never deformed, because the UV mapping is computed by propagation in all direction (so no real geometric reference to rely on, unlike the Projected or Quad modes)
                                      • pep75P
                                        pep75
                                        Thanks a lot Fredo!
                                          rv1974
                                          Hi Fredo, recently I was fantasizing about extra feature for Pantthru. Please take a look at attached. The idea is to jitter the UVW's of multiple objects according to user input (in %% for each dimention). And it should work regardless the context (as ThruPaint does).
                                          In attached picture UVW's of 3 instances of one component were jittered in U/V dimention.
                                          • E
                                            Einstein
                                            Hi!
                                            Is it possible to perform a single-face texture transformation (move, rotate, scale) after the texture was distributed onto a group of faces?
                                            I applied a texture to a whole group, containing several faces. Then I changed Selection mode from "All faces" to "Face by Face" cuz I want to rotate texture on one particular face only. But this way it seems to impossible as I have already used "All faces" mode.
                                            In this case the native tool "Texture > Position" is not preset in drop-down menu. Otherwise I would use it.
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
