    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.1k Views 102 Watching
      Try this link (just register yourself - free)
      http://sketchucation.com/pluginstore?pln=FredoTools
      • soloS
        A silly question I'm sure the answer is here someplace but I'll ask anyway.
        How do I stop Thru paint from opening every time I use SU material editor?
        I have tried disabling it in extension manager but that does not stop it from still being enabled.
          There's a setting in the ThruPaint parameters that toggles it on/off. By default it's off so at some point you turned it on.
          • soloS
            I unchecked that option but still pops up when I use SU material editor
            edit F9 worked. Doh!
              Is that on or off?
                mwm5053
                A question. Would someone look at these settings and tell me why I can't seem to rotate or otherwise scale this texture? When I rotate or scale the texture with the gizmo nothing happens.
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                  mwm5053
                  Dah I had the faces reversed didn't realize that and ThruPaint settings were set to front face.
                  2011 iMac
                  V2 Twilight
                  • jujuJ
                    juju
                    Another D'oh book entry? 😉
                    • tuna1957T
                      tuna1957
                      Been back at trying to get better with SubD and Quadface Tools and ran into this situation with Thru Paint. Modeled a pillow with above mentioned tools. The model passed the Quad Tools analyze function. Tried to texture the model with Thru Paint using the "paint quads" function. Piping textured fine, tried for the rest of the model and get error message there is problem with models quads. Don't know why it's doing this. Something I did wrong or am I asking Thru Paint to do something it really can't do ? Still in the learning stages with quad modeling. Attached a screen shot showing what happened. Thru Paint highlighted the row of quads in all four corners.
                        dmorong
                        I am having problems with the texture mapping gizmo in Thrupaint. When I click on a surface the gizmo appears for a moment, but then goes away before I can make any changes with it. I have reinstalled both Fredo6 Tools and LibFredo.
                        Looking for any tips on getting the little gizmo to stick around long enough to be useful.
                        Macbook Pro 16" (M1)
                        Mac 12.1
                        Sketchup 22.0.353
                        • fredo6F
                          @dmorong
                          Difficult for me to reproduce, as I don't have a Mac and I cannot reproduce the problem on Windows.
                          Maybe a Mac user can help. But first time I hear about that problem.
                            dmorong
                            I tried the plugin in a computer lab over the weekend with Late 2015 4K iMacs running 10.11 and had the same issue.
                            I am attaching a short screen capture showing what is happening. Sampling, painting into groups and mapping controls all work fine, but the single click on the surface to bring up the mapping adjustment tool results in just a flash of the gizmo and corresponding window, and then it goes away before any adjustments can be made.
                            Let me know if I can provide you with any other information on the problem.
                            David
                            thrupaint.mov
                            Mac 12.1
                            Sketchup 22.0.353
                            • fredo6F
                              Could you open the Ruby Console, when running ThruPaint, just in case there is an error message.
                                dmorong
                                Nothing shows up in the Ruby Console when running the Extension.
                                David
                                Mac 12.1
                                Sketchup 22.0.353
                                • fredo6F
                                  David,
                                  When you hover over the painted surface, could you type Enter. This also goes into the Edition mode.
                                    dmorong
                                    Yes, anytime you hover over the surface, as long as you see the small postit that indicates the mapping (Front Quadmesh, Natural, or Projected) you can hit enter and the adjustment gizmo will come up and stay so it can be manipulated. Thanks for pointing out that key command. That solves the problem
                                    David
                                    Mac 12.1
                                    Sketchup 22.0.353
                                    • pbacotP
                                      I didn't realize it but that non-uniform scaling function does not work in the "natural" UV setting (it's "non-deforming")
                                      • pep75P
                                        pep75
                                        I was wondering if someone can tell me where the sliders are on the visual tool in ThruPaint? I used to scale(non uniform) textures in U and V direction seperately but cannot right now. What am I doing wrong?
                                        Thanks in advance!
                                        • pep75P
                                          pep75
                                          Thanks Pbacot! 😄
                                          • fredo6F
                                            This is correct. In Natural mode, the textures are never deformed, because the UV mapping is computed by propagation in all direction (so no real geometric reference to rely on, unlike the Projected or Quad modes)
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
