    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      @jgb said:
      NEW RELEASE: Curviloft v1.6a - 13 Aug 17
      This is Sunday. Don't you ever take a day off???
      Precisely, ...I work on the other days...
        @SWills
        Please upload a SKP displaying this issue.
        It need not be a big file, just the part with the problem...
          deezprez
          I recently started to have a problem with curviloft lofting along a path. When I choose the two shapes and path it doesnt work, the part outlines change color and nothing happens. This just started two days ago but I have been having issues for a while were it waits for a path to be made and never finishes. I could fix this by closing and reopening sketchup. I really dont know what is happening. I will post the file were im triying to loft the specific shape that just wont work.
          lofting test.skp
            I expect it has to do with the small size of your geometry. SketchUp won't create the faces needed at the size of your model. Try scaling it up before running Curviloft. You can scale up and back down or use the method shown by Box here.
            • jgbJ Offline
              jgb
              Part of your problem, and one that is difficult to control, is the number of segments in the top to bottom and left to right curves are not equal. Curviloft will create extra vertices on opposing curves to line up with vertices on the other side. Therefore you get extra segments on both sides.
              You can minimize the problem if both opposing sides are true curves, not segmented lines, by making both curves contain the same number of segments. Select each curve and use Entity Info to adjust the number of segments.
              But be aware, 3 sided perimeters will not loft smoothly to adjacent 4 side curves.
              Your top drawing has a 3 sided perimeter (on the left) adjacent to a 4 sided perimeter, the way Curviloft will see it.
              Even after I do this, I still usually have a lot of cleaning up to do by pulling intersection end points in the mesh to adjacent intersections to reduce the close spaced curves and other errors that creep in.
              But Curviloft does 95++% of the work. πŸ‘ πŸ‘ πŸ‘ Can't live without it.
              jgb
              • E Offline
                Einstein
                Yes, tkanks, I'm aware that the numbers of segments should match. But actually my problem is different. I still don't know why I cannot UNDO (in the second case) and why I cannot MATCH VERTICES (in the first case). Looks like something's missing in the plugin's core, with all the respect to Fredo.
                • fredo6F Offline
                  Could you post your model so that I have a look.
                  As far as I remember, I did not implement an UNDO for manual vertex matching.
                  • E Offline
                    Einstein
                    Looks like you did but it doesn't always work πŸ˜‰ Because usually when I add a forced pair I can Undo last action. In some cases I cannot. Also, after cancelling all changes some of them don't cancel. All I do is adding forced pairs, nothing more. I cannot distinguish when I perform an operation which is impossible to undo.
                    SU file attached in the next post
                    • E Offline
                      Einstein
                      The model showing the problem
                      problem.skp
                      • sketchartist023S Offline
                        sketchartist023
                        This plugin is ESSENTIAL for me πŸ˜„ THank you much. I will donate as long as I can get my idea to work πŸ˜›. May I have assistance? I will post up anything you need to know.
                        Basic Concept: Taking a letter on a plane (non-3D) and forming it around an arc into a poly(preferably a simple rectangle).
                        I have yet to do this successfully without overlapping and issues with turning it into a solid for 3d printing using this plugin plus a paid version of SUSolid πŸ˜•
                        • pbacotP Offline
                          Maybe you can start a post with your specific task. An image of the result you want and a model of what you are starting with --and the result you have so far. Also Curviloft has a lot of features: What process are you using and what seems to be failing?
                          It could also be that another approach is suggested, not involving Curviloft.
                          • E Offline
                            Einstein
                            I have another problem with this plugin.
                            I'm trying to perform Loft by Spline based on 3 curves. I went Contour Selection and I dictated contour order: 1st, 2nd, 3rd. Proceeded to loft. And it didn't apply my choice. Did I do something wrong?
                            • E Offline
                              Einstein
                              "Generate the juntions as SU curves" in Skinning (the icon of blue horizontal line and 3 vertical lines) - what does it do?
                              • E Offline
                                Einstein
                                Hi! I'm having some problems with Skin Contours:
                                I am trying to interpolate a face with Skin Contours but the tool didn’t detect the edges perfectly. Changing Vertex Matching or Simplify didn’t help. Usually when I click on created surface, there appears additional floating window showing the connections and I can add some forced pairs. But sometimes, like in this case, I cannot change the geometry.
                                (the upper screen)
                                Another issue with adding forced pairs is that sometimes when I succeed with adding but I don’t like the result, I want to β€œRedo last change” and that change doesn’t redo.
                                (the lower screen)
                                So the problem is actually double, within Skin Contours. In the first case I’d like to do exactly what I’m doing in the second one. Is it possible to fix this?
                                • fredo6F Offline
                                  • E Offline
                                    Einstein
                                    Is it possible to generate real quads with this tool?
                                    I mean, not to smooth newly-created edges "perpendicular" and "parallel" to given path and only smooth/ soften diagonals?
                                    • E Offline
                                      Einstein
                                      I already worked out that I should have first picked the tool, only then choose contours. Now it works fine πŸ˜‰ Thank you.
                                      • fredo6F Offline
                                        I think this is the option "generate Pseudoquads" in the Geometry section of the palette.
                                        • E Offline
                                          Einstein
                                          Almost, because it softens every edge πŸ˜‰
                                          Referring to a problem I had earlier:
                                          I discovered that Skin Contours doesn't allow to add forced pairs when input contours embrace a flat surface. I quite often use Curviloft for interpolating flat areas and making organic mesh out of them, like in the screenshot. Normally we can manually match vertices only when output mesh is not planar.
                                          So I'd politely make an improvement idea - to enable manual vertex matching for planar input-output.
                                            rv1974
                                            Is there a way to set a new default value
                                            1 for #Seg for example?
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 65
                                            • 66
                                            • 48 / 66
