    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • vaillyV
      vailly
      Nice job again Fredo6.
      Is it possible to animate the "sun" to see the shadow of a building moving from early in the morning through the night?
      Thanks,
      François
      • fredo6F
        This is possible with the Visual Effect "Shadow"
        In the timeline,
        • put a first one with the date/time of early morning
        • put a second one with the date/time of late evening at the end (based on your video duration)
        Shadow is a visual effect. So it can be combined with object and camera movements and with other visual effects (zoom, etc...).
        Note that if the two date/time are separated with more than 24h, then you'll get a Season shadow animation. This is how you can simulate the shadow across several days, months or years.
        • fredo6F
          New Release: Animator - v1.8a - 02 Nov 17
          Requirement: LibFredo6 v7.9a
          Minor release
          • bug fixing
          • First batch of Performance improvement for large models
          See main post for RBZ files
            Mike598601
            Hey Fredo, you are genius 😄 I love animator
            I tried rendering a clip in Twilight V2 pro, only 2 second duration (51 frames) - 30 hours in it had rendered 14 clips, so I decided to purchase V-Ray and upgraded LibFredo6 to 7.9 and animator to 1.8 as it says Vray is supported. Tried to render the same animation and it only took 1.5 hours - an amazing improvement!! I saw every frame rendering, However, the resulting movie, both MP4 and MOV were both only 1 frame long 😞 - Have I missed something? Can you advise me please?
            Keep up the brilliant work!!!
            • fredo6F
              For animation, I don't think you need super-rendering. If you have only 51 frames, with a rendering of 10 s, you should keep it under 10 minutes, whether Twilight or VRay.
              Could you post or PM your model, so that I see how it renders with Vray and Twilight.
                mast1987
                First: Big Thanks to FREDO for this Genius plugin.
                Theres just 1 Thing I got a Problem with: Camera Fade out.
                If I use more than 2 views/cameras the Animation stops at the second view/camera and doesnt fade to the third one.
                what did I wrong?
                • fredo6F
                  what did I wrong?
                  Could you please post or PM your model so that I have a look.
                  Maybe you simply disable fadeout for the second camera.
                    mast1987
                    ok I got a solution:
                    when i set the camera Position with the eye tool it doesnt works.
                    when I set it with the Orbit and Hand tool it works fine.....
                    thanks for the quick answer btw
                    • fredo6F
                      Glad to see it works.
                      Still, I don't see why you have a difference, since Animator does not really care HOW you set a view: it just capture the camera when it is set.
                      • fredo6F
                        New Release: Animator - v1.8b - 19 Nov 17
                        Requirement: LibFredo6 v8.0b
                        Maintenance release
                        • bug fixing
                        • Handling of cases where scenes which are part of an animation are deleted in Sketchup.
                        • improvement in circular camera interpolation (fadeout) if you also install LibFredo6 8.0b
                          Mike598601
                          Just upgraded VRay to 3.6 but it no longer appears in the 'Render with' options in animator - is this version of Vray supported by animator in SU 2018?
                          • fredo6F
                            Is Vray 3.6 installed in SU2018?
                            I will investigate on my side
                            • soloS
                              Go home Thea, you're drunk!
                              Why is Thea acting like a drunk uncle? see the animation in SU, this is what I want to render in Thea:
                              However, when I choose to render the animation I get this:
                              Is there a way to fix this? reset Thea in some way?
                              • ntxdaveN
                                ntxdave
                                I am assuming that when you went to create the animation using the Animator plugin you clicked the Thea button. I have not seen anything like that happen but I have not used Animator for a while
                                Press F1...thank me later
                                • soloS
                                  If I did not press the Thea button then it would not have rendered with Thea, I did what I always do, use Thea animation with the Animator plugin selected.
                                  Besides Thea, does Animator support other renderers? may be time to move on.
                                  • ntxdaveN
                                    ntxdave
                                    I remember for sure that it also supports Twilight Pro and Ambient Occlusion. Not sure which others.
                                    Yes, I thought that is what you did (clicked). I guess I was "grasping at a straw" for an explanation but I know you are much more of a sage that that. Dumb remark/question on my pattern. 😳
                                    Hope you get this sorted out.
                                    • fredo6F
                                      Solo,
                                      Did you generate the rendered animation from within Animator, or from Thea animation ?
                                      I guess the best to understand what could be going on is to send me the model.
                                      • soloS
                                        @fredo6 said:
                                        Solo,
                                        I tried with Animator but for some reason that failed to do anything, I interrupted after 10 minutes only to find an empty folder, no images were saved so I then rendered within the Thea window and got the messed up result.
                                        Here is the basic model with animation set up.
                                        sorril t.skp
                                        • ntxdaveN
                                          ntxdave
                                          It has been a while since I tried anything with Thea but so far all I am getting is a black screen. No content!!
                                          I am rendering it with Twilight though. I will share that when I am done rendering it (going pretty fast).
                                          • soloS
                                            You are getting a black screen because you do not have an HDRi in the illumination slot, the sun is switched off.
                                            • 11
                                            • 12
                                            • 13
                                            • 29
                                            • 30
                                            • 11 / 30
