    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      @tomaszdrgas said:
      I guess easiest would be interpolating date and hour seperately.
      Definitely.
      If the two dates are separated by less than 24 hours, then interpolate the dates
      Otherwise, interpolate the days, but keeping the same hour.
      • vaillyV
        vailly
        Nice job again Fredo6.
        Is it possible to animate the "sun" to see the shadow of a building moving from early in the morning through the night?
        Thanks,
        François
        • fredo6F
          This is possible with the Visual Effect "Shadow"
          In the timeline,
          • put a first one with the date/time of early morning
          • put a second one with the date/time of late evening at the end (based on your video duration)
          Shadow is a visual effect. So it can be combined with object and camera movements and with other visual effects (zoom, etc...).
          Note that if the two date/time are separated with more than 24h, then you'll get a Season shadow animation. This is how you can simulate the shadow across several days, months or years.
          • fredo6F
            New Release: Animator - v1.8a - 02 Nov 17
            Requirement: LibFredo6 v7.9a
            Minor release
            • bug fixing
            • First batch of Performance improvement for large models
            See main post for RBZ files
              Mike598601
              Hey Fredo, you are genius 😄 I love animator
              I tried rendering a clip in Twilight V2 pro, only 2 second duration (51 frames) - 30 hours in it had rendered 14 clips, so I decided to purchase V-Ray and upgraded LibFredo6 to 7.9 and animator to 1.8 as it says Vray is supported. Tried to render the same animation and it only took 1.5 hours - an amazing improvement!! I saw every frame rendering, However, the resulting movie, both MP4 and MOV were both only 1 frame long 😞 - Have I missed something? Can you advise me please?
              Keep up the brilliant work!!!
              • fredo6F
                For animation, I don't think you need super-rendering. If you have only 51 frames, with a rendering of 10 s, you should keep it under 10 minutes, whether Twilight or VRay.
                Could you post or PM your model, so that I see how it renders with Vray and Twilight.
                  mast1987
                  First: Big Thanks to FREDO for this Genius plugin.
                  Theres just 1 Thing I got a Problem with: Camera Fade out.
                  If I use more than 2 views/cameras the Animation stops at the second view/camera and doesnt fade to the third one.
                  what did I wrong?
                  • fredo6F
                    what did I wrong?
                    Could you please post or PM your model so that I have a look.
                    Maybe you simply disable fadeout for the second camera.
                      mast1987
                      ok I got a solution:
                      when i set the camera Position with the eye tool it doesnt works.
                      when I set it with the Orbit and Hand tool it works fine.....
                      thanks for the quick answer btw
                      • fredo6F
                        Glad to see it works.
                        Still, I don't see why you have a difference, since Animator does not really care HOW you set a view: it just capture the camera when it is set.
                        • fredo6F
                          New Release: Animator - v1.8b - 19 Nov 17
                          Requirement: LibFredo6 v8.0b
                          Maintenance release
                          • bug fixing
                          • Handling of cases where scenes which are part of an animation are deleted in Sketchup.
                          • improvement in circular camera interpolation (fadeout) if you also install LibFredo6 8.0b
                            Mike598601
                            Just upgraded VRay to 3.6 but it no longer appears in the 'Render with' options in animator - is this version of Vray supported by animator in SU 2018?
                            • fredo6F
                              Is Vray 3.6 installed in SU2018?
                              I will investigate on my side
                              • soloS
                                Go home Thea, you're drunk!
                                Why is Thea acting like a drunk uncle? see the animation in SU, this is what I want to render in Thea:
                                However, when I choose to render the animation I get this:
                                Is there a way to fix this? reset Thea in some way?
                                • ntxdaveN
                                  ntxdave
                                  I am assuming that when you went to create the animation using the Animator plugin you clicked the Thea button. I have not seen anything like that happen but I have not used Animator for a while
                                  Press F1...thank me later
                                  • soloS
                                    If I did not press the Thea button then it would not have rendered with Thea, I did what I always do, use Thea animation with the Animator plugin selected.
                                    Besides Thea, does Animator support other renderers? may be time to move on.
                                    • ntxdaveN
                                      ntxdave
                                      I remember for sure that it also supports Twilight Pro and Ambient Occlusion. Not sure which others.
                                      Yes, I thought that is what you did (clicked). I guess I was "grasping at a straw" for an explanation but I know you are much more of a sage that that. Dumb remark/question on my pattern. 😳
                                      Hope you get this sorted out.
                                      • fredo6F
                                        Solo,
                                        Did you generate the rendered animation from within Animator, or from Thea animation ?
                                        I guess the best to understand what could be going on is to send me the model.
                                        • soloS
                                          @fredo6 said:
                                          Solo,
                                          I tried with Animator but for some reason that failed to do anything, I interrupted after 10 minutes only to find an empty folder, no images were saved so I then rendered within the Thea window and got the messed up result.
                                          Here is the basic model with animation set up.
                                          sorril t.skp
                                          • ntxdaveN
                                            ntxdave
                                            It has been a while since I tried anything with Thea but so far all I am getting is a black screen. No content!!
                                            I am rendering it with Twilight though. I will share that when I am done rendering it (going pretty fast).
                                            • 11
                                            • 12
                                            • 13
                                            • 29
                                            • 30
                                            • 11 / 30
