    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
      Mike598601
      Hey Fredo, you are genius πŸ˜„ I love animator
      I tried rendering a clip in Twilight V2 pro, only 2 second duration (51 frames) - 30 hours in it had rendered 14 clips, so I decided to purchase V-Ray and upgraded LibFredo6 to 7.9 and animator to 1.8 as it says Vray is supported. Tried to render the same animation and it only took 1.5 hours - an amazing improvement!! I saw every frame rendering, However, the resulting movie, both MP4 and MOV were both only 1 frame long 😞 - Have I missed something? Can you advise me please?
      Keep up the brilliant work!!!
      • fredo6F
        For animation, I don't think you need super-rendering. If you have only 51 frames, with a rendering of 10 s, you should keep it under 10 minutes, whether Twilight or VRay.
        Could you post or PM your model, so that I see how it renders with Vray and Twilight.
          mast1987
          First: Big Thanks to FREDO for this Genius plugin.
          Theres just 1 Thing I got a Problem with: Camera Fade out.
          If I use more than 2 views/cameras the Animation stops at the second view/camera and doesnt fade to the third one.
          what did I wrong?
          • fredo6F
            what did I wrong?
            Could you please post or PM your model so that I have a look.
            Maybe you simply disable fadeout for the second camera.
              mast1987
              ok I got a solution:
              when i set the camera Position with the eye tool it doesnt works.
              when I set it with the Orbit and Hand tool it works fine.....
              thanks for the quick answer btw
              • fredo6F
                Glad to see it works.
                Still, I don't see why you have a difference, since Animator does not really care HOW you set a view: it just capture the camera when it is set.
                • fredo6F
                  New Release: Animator - v1.8b - 19 Nov 17
                  Requirement: LibFredo6 v8.0b
                  Maintenance release
                  • bug fixing
                  • Handling of cases where scenes which are part of an animation are deleted in Sketchup.
                  • improvement in circular camera interpolation (fadeout) if you also install LibFredo6 8.0b
                  See main post for RBZ files
                    Mike598601
                    Just upgraded VRay to 3.6 but it no longer appears in the 'Render with' options in animator - is this version of Vray supported by animator in SU 2018?
                    • fredo6F
                      Is Vray 3.6 installed in SU2018?
                      I will investigate on my side
                      • soloS
                        Go home Thea, you're drunk!
                        Why is Thea acting like a drunk uncle? see the animation in SU, this is what I want to render in Thea:
                        However, when I choose to render the animation I get this:
                        Is there a way to fix this? reset Thea in some way?
                        • ntxdaveN
                          ntxdave
                          I am assuming that when you went to create the animation using the Animator plugin you clicked the Thea button. I have not seen anything like that happen but I have not used Animator for a while
                          Press F1...thank me later
                          • soloS
                            If I did not press the Thea button then it would not have rendered with Thea, I did what I always do, use Thea animation with the Animator plugin selected.
                            Besides Thea, does Animator support other renderers? may be time to move on.
                            • ntxdaveN
                              ntxdave
                              I remember for sure that it also supports Twilight Pro and Ambient Occlusion. Not sure which others.
                              Yes, I thought that is what you did (clicked). I guess I was "grasping at a straw" for an explanation but I know you are much more of a sage that that. Dumb remark/question on my pattern. 😳
                              Hope you get this sorted out.
                              • fredo6F
                                Solo,
                                Did you generate the rendered animation from within Animator, or from Thea animation ?
                                I guess the best to understand what could be going on is to send me the model.
                                • soloS
                                  @fredo6 said:
                                  Solo,
                                  I tried with Animator but for some reason that failed to do anything, I interrupted after 10 minutes only to find an empty folder, no images were saved so I then rendered within the Thea window and got the messed up result.
                                  Here is the basic model with animation set up.
                                  sorril t.skp
                                  • ntxdaveN
                                    ntxdave
                                    It has been a while since I tried anything with Thea but so far all I am getting is a black screen. No content!!
                                    I am rendering it with Twilight though. I will share that when I am done rendering it (going pretty fast).
                                    • soloS
                                      You are getting a black screen because you do not have an HDRi in the illumination slot, the sun is switched off.
                                      • ntxdaveN
                                        ntxdave
                                        Still working on it Pete. Creating an MP4 with Thea did not work correctly and I had a problem trying to create a GIF. In the process again.........
                                        • ntxdaveN
                                          ntxdave
                                          I did not do a good job but at least you can see that both of these render engines will work correctly with Animator (if you know how to user the renderers).
                                          Thea
                                          Twilight
                                          • soloS
                                            Interesting, I had someone on the Thea forums test it out and they also got an abnormal result, now I'm more confused.
                                            • 11
                                            • 12
                                            • 13
                                            • 29
                                            • 30
                                            • 11 / 30
