    HELP please. can't get my Shadows Settings panel to appear
    13 Posts 8 Posters 4.4k Views 8 Watching
    • jeff hammondJ
      bummer.. I know a way to coax it back on a Mac but windows-- I have no clue.
      the Europeans should be waking up soon.. they'll be able to figure it out.
        I'm a bit fuzzy but I thinks this is what you have to do....
        Activate Shadows under windows menu.
        Press Alt-Space
        Press 'm'
        Use arrow keys to move window back on screen
          With Sketchup closed... Start > Regedit
          Find HKEY_CURRENT_USER\Software\Google\SketchUp8\SnappyShadows
          Edit its contents, set x=0 and y=0, then close.
          This will put the dialog top left of the screen when Sketchup reopens.
          [Useful when you mess up using Rich's trick and put the dialog on the Moon! πŸ˜‰ ]
          • BoxB
            Also check with the secondary monitor that you have looked all around, it can be to the left, right, above or below.
            • JClementsJ
              JClements
              Hi TIG, something else must be broken in the registry for my Laptop PC (win 7).
              I also tried the registry entry on my win 7 Desktop and it worked.
                Have you tried reinstalling Sketchup ?
                • Dan RathbunD
                  Dan Rathbun
                  Try repairing the installation, through the installer, first.. (before reinstalling.)
                  I'm not here much anymore.
                  • JClementsJ
                    JClements
                    The problem was resolved by reinstalling SU over the existing installaton.
                    Thank you to all for your help.
                    • B
                      beverx
                      I just had similar issue, try this (worked for me):
                      drag out the shadows bar from the icons bar and close it with the X button (available when the shadows box is floating outside bars and panels) then go to Window->Tray (default or other)-> enable Shadows.
                      After this I got my shadows settings back on the tray on the right of the SU window.
                      Hope this works for you πŸ˜‰ Greetings from Poland!
                        Welcome to Sketchucation neverx.
                        One would hope that John got his issue with the Shadows window fixed a long time ago. Otherwise he's been without shadow control for 5-1/2 years and numerous SketchUp version changes. πŸ˜‰
