    HELP please. can't get my Shadows Settings panel to appear
    13 Posts 8 Posters 4.6k Views 8 Watching
    • JClementsJ
      JClements
      Thanks for the suggestion Jeff, but it didn't do anything.
      • jeff hammondJ
        bummer.. I know a way to coax it back on a Mac but windows-- I have no clue.
        the Europeans should be waking up soon.. they'll be able to figure it out.
          I'm a bit fuzzy but I thinks this is what you have to do....
          Activate Shadows under windows menu.
          Press Alt-Space
          Press 'm'
          Use arrow keys to move window back on screen
            With Sketchup closed... Start > Regedit
            Find HKEY_CURRENT_USER\Software\Google\SketchUp8\SnappyShadows
            Edit its contents, set x=0 and y=0, then close.
            This will put the dialog top left of the screen when Sketchup reopens.
            [Useful when you mess up using Rich's trick and put the dialog on the Moon! πŸ˜‰ ]
            • BoxB
              Also check with the secondary monitor that you have looked all around, it can be to the left, right, above or below.
              • JClementsJ
                JClements
                Hi TIG, something else must be broken in the registry for my Laptop PC (win 7).
                I also tried the registry entry on my win 7 Desktop and it worked.
                  Have you tried reinstalling Sketchup ?
                  • Dan RathbunD
                    Dan Rathbun
                    Try repairing the installation, through the installer, first.. (before reinstalling.)
                    I'm not here much anymore.
                    • JClementsJ
                      JClements
                      The problem was resolved by reinstalling SU over the existing installaton.
                      Thank you to all for your help.
                      • B
                        beverx
                        I just had similar issue, try this (worked for me):
                        drag out the shadows bar from the icons bar and close it with the X button (available when the shadows box is floating outside bars and panels) then go to Window->Tray (default or other)-> enable Shadows.
                        After this I got my shadows settings back on the tray on the right of the SU window.
                        Hope this works for you πŸ˜‰ Greetings from Poland!
                          Welcome to Sketchucation neverx.
                          One would hope that John got his issue with the Shadows window fixed a long time ago. Otherwise he's been without shadow control for 5-1/2 years and numerous SketchUp version changes. πŸ˜‰
