    [Plugin] Edge Tools
    211 Posts 74 Posters 328.1k Views 74 Watching
    • pbacotP
      I find that with "Split faces into multiple pieces" the "X" key is not recognized to create more multiple edges. The * key on the 10-key pad is recognized however. This is on a Mac. Is that intended?
      • JQLJ
        JQL
        Duh! I didn't know one could do that. It works (though my "X" is assigned to other function and I always use "*" for that sort of stuff)
        www.casca.pt
        Visit us on facebook!
        • pbacotP
          did you know you could place the line on many other faces in context, not just the contingent face? I am not sure what decides which faces apply, but probably has something to do with having an edge that is a parallel to the contingent face. I just found that out today.
          • cottyC
            cotty
            I would like to get a line at the next vertex (see animation) and not only in between the vertices, is it possible?
            my SketchUp gallery
            • JQLJ
              JQL
              Yes that I knew already! We are tied! The only thing needed is coplanar faces...
              That only happens when the edge hits two simultaneous vertexes.
              I never split faces but sometimes that happens if I use split faces around a box. I can split 3 faces but the last only works if I draw a line. I used to think it had something to do with that final edge generating a face but it has to do with joining two END vertexes.
              It can split if the vertexes are in the middle.
              www.casca.pt
              • pbacotP
                Yep, The faces don't need to be coplanar. They can be parallel faces and perpendicular but parallel to edge, plus more--but I haven't figured out what and probably cannot
                  alamin
                  any pdf tutorial ?
                    AMena
                    @thomhom
                    Hi, i installed Edge tools² in my sketchup pro 2017, but i'm not able to find it in the menu "View » Toolbars » Edge Tools²" or in "Tools » Edge Tools²" , i've tried to reinstal it, but it did't work.
                    Pd: i already installed the TT_Lib² — 2.7.0 before instal the Edge tools²
                    Thanks for the help
                      Assuming you installed it from its RBZ using the Install Extension tool...
                      Check under the Extension Manager dialog that it is activated - if it's not, then no menu items or toolbars will appear...
                      • F
                        filatelik
                        Hi Thomthom, first of all many thanks for this useful plugin.
                        Just would like to ask you if exist or you plan to make its equivalent for newer versions of Sketchup? I mean *.rbz suffix of file. Many thanks in advance for your answer.
                        Filip
                          Filip
                          The rbz file is already available and has been for a long time. Look in the PluginStore by clicking on the button at the top of this page. Or better, install the Sketchucation Extension Store tool (look under Resources at the top of this page.) and use it to install Edge Tools. Don't forget to also install the current TT_Lib as well.
                          • E
                            Einstein
                            Very handy tool, thank you 😄
                            I'd have a little upgrade suggestion - the first tool "Split faces into multiple pieces" could remember the last distance used and snap cursor to it 😄
                            • E
                              Einstein
                              Hi!
                              I use these tools a lot but unfortunately I cannot set a key shortcut for any of them because thery're not listed in SketchUp's tools list in Preferences > Shortcuts. Please, if you could, make some upgrade that would include them into the list.
                              Also remembering last distance in the first tool: "Split faces into multiple pieces" would be a great feature. With these two things Edge Tools would be not only cool and handy, but also very fast to use.
                              • BoxB
                                Look for them under Tools/edge...
                                  @einstein said:
                                  Hi!
                                  C'mon Einstein. As Box wrote...
                                  Filter for 'edge' to shorten the list.
                                  • E
                                    Einstein
                                    Thank you.
                                    I was confused because the tool called "Split faces into multiple pieces" stood in the list as "Divide faces" and I firstly didn't come up it's the same thing.
                                      maszka
                                      THe plugin Egde and Lib are installed properly but I cannot find anything in tools/ view toolbars to swich on. I cannot find this pludins in interface of sketchup anywhere.
                                      Anybody could help me?
                                        Are you still using SketchUp 8 as indicated in your profile?
                                        How exactly did you install them?
                                          asder
                                          thank
                                          • C
                                            ct103stu0
                                            When I use "Find all edge gaps", I see the circles. And I can click each one and repair. But, due the large number, I then use "Close all edge gaps", and none of the gaps are closed. Should "Close all edge gaps" close all gaps identified by the "Find all edge gaps"?
                                            • 11
                                            • 10 / 11
