    [Plugin] Edge Tools
    211 Posts 74 Posters 310.9k Views 74 Watching
      rv1974
      @thomthom said:
      Because one click is nicer than many. 😉
      It should be a permanent headline in the ruby sub-forum.
      • JQLJ Offline
        JQL
        Thomthom,
        Since Sketchup 2013 the inspect tool in Edgetools2 has been very unstable.
        Split faces is working fine, erase stray edges is perfect as ever and I can also use align vertices. However most of the time I try the inspect tool Sketchup crashes sometimes it's only when I press the circles, but it also happens just for executing the tool. The strange thing is that it actually inspects correctly but then SU stops responding.This is happening with both complex and simple models.
        I have the most recent version installed and also TT Library. I erased both folders and reinstalled from Sketchucation Plugin Store.
        As I don't see anyone saying the same thing I suppose it might be my problem, but would you have some kind of guidelines for figuring out what I can do?
        Thanks and best regards,
        EDIT: I just isolated both TTLib and Edgetools and removed every other plugin from plugins folder and it crashed again...
        JQL
        www.casca.pt
        Visit us on facebook!
        • halroachH Offline
          halroach
          I've got an idea for a nice feature that could make this plugin even more powerful.
          Having the option to limit the "edge gap closing" to points that are on the same Z. Any chance for that?
          FlexTools - Super Quick Windows, Doors, Slats...
            calvin200001
            does this work for mac? I get an error:
            Error Loading File /Users/****/Library/Application Support/SketchUp 2013/SketchUp/Plugins/TT_EdgeTools/core.rb
            no such file to load -- TT_Lib2/core.rb
            Error Loading File tt_edgetools.rb
              Have you installed the latest version of the TT_Lib2 and restarted SketchUp ?
              http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                calvin200001
                SO sorry, I didnt see that. Works amazingly now.
                • halroachH Offline
                  halroach
                  Hi Thomthom,
                  I've been using edge tools for a long time. It's great!
                  A little idea that could be a great time saver.
                  It would be nice if you could add to the 'Inspect & Close' function, an option of dragging the mouse over a bunch of edges to have them all fixed at once.
                  (... Like when there is a long staircase imported from dwg where all of the steps aren't connecting... drag a selection all around them... and viola - all taken care of).
                  • pbacotP Offline
                    I find that with "Split faces into multiple pieces" the "X" key is not recognized to create more multiple edges. The * key on the 10-key pad is recognized however. This is on a Mac. Is that intended?
                    • JQLJ Offline
                      JQL
                      Duh! I didn't know one could do that. It works (though my "X" is assigned to other function and I always use "*" for that sort of stuff)
                      www.casca.pt
                      • pbacotP Offline
                        did you know you could place the line on many other faces in context, not just the contingent face? I am not sure what decides which faces apply, but probably has something to do with having an edge that is a parallel to the contingent face. I just found that out today.
                        • cottyC Offline
                          cotty
                          I would like to get a line at the next vertex (see animation) and not only in between the vertices, is it possible?
                          my SketchUp gallery
                          • JQLJ Offline
                            JQL
                            Yes that I knew already! We are tied! The only thing needed is coplanar faces...
                            That only happens when the edge hits two simultaneous vertexes.
                            I never split faces but sometimes that happens if I use split faces around a box. I can split 3 faces but the last only works if I draw a line. I used to think it had something to do with that final edge generating a face but it has to do with joining two END vertexes.
                            It can split if the vertexes are in the middle.
                            www.casca.pt
                            • pbacotP Offline
                              Yep, The faces don't need to be coplanar. They can be parallel faces and perpendicular but parallel to edge, plus more--but I haven't figured out what and probably cannot
                                alamin
                                any pdf tutorial ?
                                  AMena
                                  @thomhom
                                  Hi, i installed Edge tools² in my sketchup pro 2017, but i'm not able to find it in the menu "View » Toolbars » Edge Tools²" or in "Tools » Edge Tools²" , i've tried to reinstal it, but it did't work.
                                  Pd: i already installed the TT_Lib² — 2.7.0 before instal the Edge tools²
                                  Thanks for the help
                                    Assuming you installed it from its RBZ using the Install Extension tool...
                                    Check under the Extension Manager dialog that it is activated - if it's not, then no menu items or toolbars will appear...
                                    • F Offline
                                      filatelik
                                      Hi Thomthom, first of all many thanks for this useful plugin.
                                      Just would like to ask you if exist or you plan to make its equivalent for newer versions of Sketchup? I mean *.rbz suffix of file. Many thanks in advance for your answer.
                                      Filip
                                        Filip
                                        The rbz file is already available and has been for a long time. Look in the PluginStore by clicking on the button at the top of this page. Or better, install the Sketchucation Extension Store tool (look under Resources at the top of this page.) and use it to install Edge Tools. Don't forget to also install the current TT_Lib as well.
                                        • E Offline
                                          Einstein
                                          Very handy tool, thank you 😄
                                          I'd have a little upgrade suggestion - the first tool "Split faces into multiple pieces" could remember the last distance used and snap cursor to it 😄
                                          • E Offline
                                            Einstein
                                            Hi!
                                            I use these tools a lot but unfortunately I cannot set a key shortcut for any of them because thery're not listed in SketchUp's tools list in Preferences > Shortcuts. Please, if you could, make some upgrade that would include them into the list.
                                            Also remembering last distance in the first tool: "Split faces into multiple pieces" would be a great feature. With these two things Edge Tools would be not only cool and handy, but also very fast to use.
                                            • 11
                                            • 10 / 11
