    Welcome to FlexTools Beta
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    20 Posts 6 Posters 17.0k Views 6 Watching
      rafiky
      Thanks for let us to help you and improve the tool. Flextools is very useful!
      • halroachH
        halroach
        Thank you Rich for helping us out with this forum!
        Glad FlexTools is helping you guys 😄.
        [highlight=#ffff00:2wdy2ycq]New FlexTools v1.1.0 beta is out![/highlight:2wdy2ycq] (See first post above)
        The main highlight:
        • Add to favorites button
        • Search through favorites!!!
        Have a nice beta weekend 😉
        FlexTools - Super Quick Windows, Doors, Slats...
          Cool! 😎
          No top Arc Circles Windows?
          When you input a false degre inside a FlexTrapez that explode the model!
          • halroachH
            halroach
            So don't put a false degree? 😉.
            I might be able to limit from false degree input... I'll need to sit and think about it.
            If you enter a normal degree it goes back to normal?
            • halroachH
              halroach
              There will be a circular window!!! 😎
                Yes! ☀
                • halroachH
                  halroach
                  1. [highlight=#ffff00:1d0gmfot]FlexTools updated to v1.1.1 beta[/highlight:1d0gmfot] (See first post above)
                  The main highlights:
                  • New Planview tool to play around with 😄
                  • Bugfix
                    rafiky
                    Hi!
                    I inserted a door with flextools and there is something wrong. If I change the wall thickness and also the frame depth, alwais remain the old wall thickness.
                    The only way to solve it is changing the inset value and it works but not the first time you change the wall thickness.
                    Cheers,
                    P.D. Sorry for my english.
                    • halroachH
                      halroach
                      @rafiky said:
                      Hi!
                      I inserted a door with flextools and there is something wrong. If I change the wall thickness and also the frame depth, always remain the old wall thickness.
                      I'm not sure, but it seems like it's working fine 😄.
                      There are 4 thickness/depth settings that may need changing to get which ever wall thickness and desired placement you need:
                      Frame Depth / Wall Thickness / Inset / (Doorstop)
                      Currently:
                      1. The Framecan be any size you want, and it's placement, in relation to the wall (together with all the other door elements) is determined by the Insetvalue.
                      2. The wall thickness is determined by either the thickness you give it - OR - the sum of the frame depth + inset value. If the sum of frame depth and inset are larger than then the wall thickness, the wall get's thicker...
                      The reason is, that if the inset were deeper than the wall thickness, you'd have a floating door/window. Unless that's what you want!?
                        rafiky
                        Here is the problem
                        https://app.box.com/s/1pf10ays1lu2s0azhliounexot7j99ra
                        • halroachH
                          halroach
                          @rafiky said:
                          Here is the problem
                          Ok, I think that's the doorstop depth that needs adjusting.
                          Currently the doorstop is positioned according to the door panel thickness, and extrudes according to the input value. After you adjusted the frame the doorstop is just too long.
                          Maybe the calculation should be different? like maybe a minus value from the frame edge?
                            rafiky
                            I don't think so. Only changing the inset value from 0 to 0,00 on the first options it works.
                            • halroachH
                              halroach
                              Can you send me the model when it's acting odd?
                                rafiky
                                here it is
                                error.skp
                                • halroachH
                                  halroach
                                  @rafiky said:
                                  here it is
                                  Ok, now I see the problem. I must have done something wrong with the wall thickness calculation. If the frame is thicker than the wall, then the wall doesn't change, which is not right. I'll need to fix that!
                                  Thanks man!
                                  • halroachH
                                    halroach
                                    Fixed the wall thickness issue!
                                    Please see the post on the main thread:
