    Welcome to FlexTools Beta
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    20 Posts 6 Posters 17.0k Views 6 Watching
    • halroachH
      halroach
      So don't put a false degree? 😉.
      I might be able to limit from false degree input... I'll need to sit and think about it.
      If you enter a normal degree it goes back to normal?
      FlexTools - Super Quick Windows, Doors, Slats...
      • halroachH
        halroach
        There will be a circular window!!! 😎
          Yes! ☀
          • halroachH
            halroach
            1. [highlight=#ffff00:1d0gmfot]FlexTools updated to v1.1.1 beta[/highlight:1d0gmfot] (See first post above)
            The main highlights:
            • New Planview tool to play around with 😄
            • Bugfix
              rafiky
              Hi!
              I inserted a door with flextools and there is something wrong. If I change the wall thickness and also the frame depth, alwais remain the old wall thickness.
              The only way to solve it is changing the inset value and it works but not the first time you change the wall thickness.
              Cheers,
              P.D. Sorry for my english.
              • halroachH
                halroach
                @rafiky said:
                Hi!
                I inserted a door with flextools and there is something wrong. If I change the wall thickness and also the frame depth, always remain the old wall thickness.
                I'm not sure, but it seems like it's working fine 😄.
                There are 4 thickness/depth settings that may need changing to get which ever wall thickness and desired placement you need:
                Frame Depth / Wall Thickness / Inset / (Doorstop)
                Currently:
                1. The Framecan be any size you want, and it's placement, in relation to the wall (together with all the other door elements) is determined by the Insetvalue.
                2. The wall thickness is determined by either the thickness you give it - OR - the sum of the frame depth + inset value. If the sum of frame depth and inset are larger than then the wall thickness, the wall get's thicker...
                The reason is, that if the inset were deeper than the wall thickness, you'd have a floating door/window. Unless that's what you want!?
                  rafiky
                  Here is the problem
                  https://app.box.com/s/1pf10ays1lu2s0azhliounexot7j99ra
                  • halroachH
                    halroach
                    @rafiky said:
                    Here is the problem
                    Ok, I think that's the doorstop depth that needs adjusting.
                    Currently the doorstop is positioned according to the door panel thickness, and extrudes according to the input value. After you adjusted the frame the doorstop is just too long.
                    Maybe the calculation should be different? like maybe a minus value from the frame edge?
                      rafiky
                      I don't think so. Only changing the inset value from 0 to 0,00 on the first options it works.
                      • halroachH
                        halroach
                        Can you send me the model when it's acting odd?
                          rafiky
                          here it is
                          error.skp
                          • halroachH
                            halroach
                            @rafiky said:
                            here it is
                            Ok, now I see the problem. I must have done something wrong with the wall thickness calculation. If the frame is thicker than the wall, then the wall doesn't change, which is not right. I'll need to fix that!
                            Thanks man!
                            • halroachH
                              halroach
                              Fixed the wall thickness issue!
                              Please see the post on the main thread:
