    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • DATAKASHD
      DATAKASH
      @filibis said:
      @datakash said:
      Please add 2 functions:
      1. Offset (without rounding)
      2. Offset with intersection (toggle)
      Those features exist in QuadFace Tools and it is advised here to use as well.
      Check below gif.
      QFT does not make the offset of the desired edge.
      • Offset uneven (See the screen)
      • What if you do not have a ring? If there is no ring, the offset is not done!
        Check below gif
      • fredo6F
        @DATAKASH
        There was another request for that and it makes perfect sense.
        This will come in due time, but no promise.
        • DATAKASHD
          DATAKASH
          @fredo6 said:
          @DATAKASH
          Yes Yes Yes! @cesaro36 @Hieru They say the same thing as I do! RoundCorner would be an ideal tool, having such such functions. At the moment everything has to be done manually, every day 😞
          • fredo6F
            Following up on the discussion about using RoundCorner for drawing the control mesh of a subdivision, I am interested to understand what would be the 'best' control mesh for the following shapes (also in the SKP file attached, SU2015).
            As you will notice, the offset lines do not cross on the edges at the same point.
            SubDiv Corner.skp
            • tuna1957T
              tuna1957
              Fredo, I'm no expert at the SubD stuff but had a go at the model you posted. Kept in mind the intent was for rounding corners. Posting your skip. file back so you can better look at what I did. Hope it's helpful in some way.
              SubDiv%20Corner copy.skp
              • DATAKASHD
                DATAKASH
                Such a grid would be quite appropriate
                The subdivision does not like n-gon, So some models have to be cut manually
                Yes, on some models, the bias lines do not intersect at the edges at the same point. I noticed this too. (screenshot 2)
                I corrected the offset manually
                SubD Corner SU2015.skp
                • fredo6F
                  @DATAKASH and @tuna1857
                  Thank you very much for quick answer. This confirms that's not a straight by-product of RoundCorner.
                  I am interested in getting the 'subdivided' version of the shapes. I don't have SubDiv myself and I am not familiar with subdivision, So, it will be helpful by the time I purchase it and get into it.
                  Thanks again
                  • tuna1957T
                    tuna1957
                    Fredo, Went back in and cleaned things up better than the first attempt. Posting zip of the model, shows proxies and after SubD.
                    For your information, the first attempt I just used the SU offset tool on all faces and connected things up at the corners with the line tool. This led to some angles in the corners and I think contributed to the not so great results. All the objects did pass the Quadface Tools analyze function.
                    On this second try pay strict attention to keeping all the loops running parallel to respective edges. It took a lot of hand work with the tape tool and line tool. A result of this is the offsets are not all the same distance from edges. All the shapes in the second go passed the Quadface tools analyze function except the wedge on the left, wedge on the right passed. Hope this makes sense and is somewhat helpful.
                    SubDiv%20Corner.skp.zip
                    • fredo6F
                      Charles,
                      Thank you very much. Very helpful.
                      However, are you sure that SubDivision is appropriate for rounding edges?
                      From what I see, the subdivision gives the following result:
                      After cleaning the coplanar edges, the subdivision appears to be more or less equivalent to an edge rounding with 2 segments.
                      But, then, I wonder why you do not prefer a more regular rounding with RoundCorner, here with 2 segments too.
                      Again, I have no experience with SubDivision. So I am just trying to clarify.
                      Sub Corner - Tuna 1957 with rounding - Compare.skp
                      • DATAKASHD
                        DATAKASH
                        Round Corner has minor problems with rendering. Subdivision is much smoother.
                        Subdivision can be turned off and mesh corrected.
                        Roundcorner seen in the render
                        Offset the grid affects the result
                        The Subd has a toggle: on-off
                        • tuna1957T
                          tuna1957
                          Fredo, Agree with you that SubD to get round corners may not be the preferred approach for everybody. Referring back to DATAKASH's posts, I think the main point of DATAKASH'S request was to be able to use your Roundcorner plugin to help build the mesh in their proxy model prior to running SubD. I honestly don't know the first thing about writing these plug ins and really don't know if this is something that could be implemented into Roundcorner. At this point I think I'm going to quietly disappear and let you and DATAKASH kick this around, I was trying to help out some by posting example meshes for you to study......
                          • PixeroP
                            Pixero
                            A new version of round corner with all quads and an on/off switch (like subD has) would help tremendously.
                            • fredo6F
                              That's interesting! and it would be useful to understand why?
                              • Is it because the rounding is circular?
                              • or too regular?
                              • of for other reasons related to the Rendering parameters
                              What I see from DATAKASH examples (and yours), is that the shape should first be 'quadified' and have consistent 'loops'.
                              Can QuadFaceTools do this automatically, including when there are holes in faces?
                              For instance, this shape...
                              ...should first be 'quadified'...
                              ...and then, I guess this makes it easier to construct the offset control mesh.
                              Corners made of quads, as opposed to triangles (for tri-border corners) are possible. However, even in orthogonal cases, each quad may be triangulated. So this increases the number of facets.
                              For a Proxy of RoundCorner, this is independent. Actually, any script doing an object transformation could (or should) have a proxy to enable / disable. Sketchup does not provide a standard method for that, so I guess it has to be simulated, via copy, invisible layers or simply parameterization.
                              • PixeroP
                                Pixero
                                But it would make it possible to texture better with UV's as for example QuadFaceTools can interpret pairs of those triangles as a quad.
                                Maybe you could check with Thomthom how he does it in SubD?
                                When I have thought about this I was thinking of saving the original geometry information in an attribute, but that is perhaps a bad idea?
                                Or how does a modify stack work in for example Max?
                                I'm sure a system for history would benifit a lot of SU plugins.
                                If it would be possible with a on/off switch it would be a great addition to SU. πŸ‘
                                • DATAKASHD
                                  DATAKASH
                                  • or too regular?
                                  I think this is due to the fact that subdivision affects the whole object
                                  And yes, his grid is also triangulated.
                                  As I see, creating offset by selecting each face manually
                                  (If this is a reasonable solution?)
                                  • fredo6F
                                    What I see at least as a true difference is that, with SubDivision, the edges and corners are not rounded with circle (as in RoundCorner), but with other types of curves (Catmull-Clark splines). So the transition for the flat part to the rounding is different.
                                    The other difference in your example is that the flat face is also 'quadified' with co-planar facets, triangular. So here too, for rendering there may a difference between this set of facets versus a single big face, even if geometrically, the two situations are identical.
                                    I don't know if anyone has some opinions on all this, in relation with renering.
                                    • PixeroP
                                      Pixero
                                      Maybe this thinking is applicable?
                                      https://hackernoon.com/apples-icons-have-that-shape-for-a-very-good-reason-720d4e7c8a14
                                      • fredo6F
                                        Pixero,
                                        Interesting indeed.
                                        I made a few trials, which are illustrated in the attached model (SU2015), with 6 types of rounding, each generated with 6 segments. I also made a quick rendering with Thea.
                                        Could any one advise on what is the 'best' for Rendering.
                                        Corner iphone.skp
                                        • kimi kimiK
                                          kimi kimi
                                          Hi Fredo, hi everyone,
                                          I made an update to my Round Corner plugin this morning, and now I can't see the toolbar with all the options when I activate the command. Is this a problem only on my computer, or does someone else have it too?
                                          As you can see on screenshot, the command is active, there is text in bottom left and right, but I don't see the toolbar. I tried erasing it, erasing and reinstalling Fredo6 library, but still same result.
                                          • PixeroP
                                            Pixero
                                            @fredo:
                                            Thats a tough one... not number 2 or 2,5 but the rest I have a hard time deciding which look best when rendered. Maybe if you commented on what the difference between them are?
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 74
                                            • 75
                                            • 61 / 75
