    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • JQLJ Offline
      JQL
      Painter is used to directly paint materials (colors, height, roughness, normal, etc...) into a correctly UV unwrap mesh. You can also use ready made materials, with special effects that are affected by the shape of your mesh. You can also import textures and paint your mesh and there are other more advanced options. It's incredibly powerful at that but it really requires a UV unwrapped mesh without it it won't work.
      Designer is a material creation sofware that is also capable of texture your model. You can create materials procedurally or based on images, you can combine materials and texture your model. You can also apply effects that react to your model's geometry but you cannot handpaint your model.
      The materials used in painter are created with designer, but designer allows you to create materials for any software that uses bitmap textures for materials.
      Bitmap to Material is a very very "simplified version of Designer" where you can create materials from base textures for any render engine or software.
      Without knowing what you do, Rich cannot recommend any of the above. I would recommend designer for people that use sketchup and render software for stuff like architecture where you need to create materials even if you will eventually texture some of it using UV unwrap meshes.
      I would recommend painter for people that use sketchup for isolated objects as it's more likely that they are able to UV unwrap them. If you know that your texture process will eventually lead you to a UV unwrapped mesh, painter is definetelly worth it as you can see in the raygun above.
      I would recommend Bitmap to Material for people that will only search for images and convert them to materials.
      www.casca.pt
      Visit us on facebook!
        Carto
        Hello JQL,
        Thank you for the thorough explanation.
        Regards
          @carto said:
          Just a quick FYI...Substance Painter and associated software is on sale. That being said would you recommend just Painter or the entire Substance Pack?
          JQL answered for me.
          If Node based material creation is something you want to add to your skillset then Bundling Painter and Designer is a must.
          As with all software considerations trials are the best way to decide. For Designer, you need to clear your workload to really see the benefits.
          I recommend watching Sharpstance tutorials on YouTube.
          But if you can source Substance materials online then the Substance Player is all you need.
          Horses for courses.
          • BoxB Offline
            That is indeed a very impressive first post. Well done.
              tengel07
              My first post here 😎
              I'm working on the B194 - Schueys first WC-Racer in Formula 1:
              http://www.scaleautofactory.com/3dDesign/b194_001_quad.jpg
              http://www.scaleautofactory.com/3dDesign/b194_002_quad.jpg
              Based on a rough poly-model i redraw the car with QFT, SubD and VT.
              Great tools.
                Nice!
                That's the one that was first to have that double-decker front nose wing, right?
                  At this step the front recalls old Bugati! πŸ˜‰
                  • N Offline
                    nlipovac
                    Impressive, RichΒ΄s gun and B194. WOW! Can wait to see B194 textured.
                      tengel07
                      More progress pics:
                      http://www.scaleautofactory.com/3dDesign/b194_003_quad.jpg
                      http://www.scaleautofactory.com/3dDesign/b194_004_quad.jpg
                      http://www.scaleautofactory.com/3dDesign/b194_005_quad.jpg
                      At least: Rear-Wing and Front-Suspension needs to be "Quaded"
                      Then UV-Wrapping and Texturing with WrapR-Beta...
                      • BoxB Offline
                        Coming along Nicely Tengel07
                        • BoxB Offline
                          I found my Grandpa's old Oiler in the back shed and gave it a bit of a clean up, do you think it would be a suitable candidate for SUbDing?
                            So you are from Aladin's family! πŸ˜„
                            • BoxB Offline
                              I gave it a go, what do you think, is it close?
                              http://i.imgur.com/p8zSlNY.gif
                                This is look VERY good!
                                  Did you share the original pic of the oiler somewhere?
                                  • BoxB Offline
                                    Not as far as I remember, but apparently someone did on farsebook.
                                    • vanpiV Offline
                                      vanpi
                                      Bottle
                                      Bottle
                                      • HornOxxH Offline
                                        HornOxx
                                        @vanpi said:
                                        Bottle
                                        πŸ‘ this is a so cool bottle design! could you please add a picture of your control mesh as well?
                                        (btw: nice avatar picture πŸ˜„)
                                        never trust a skinny cook
                                        • HornOxxH Offline
                                          HornOxx
                                          @box said:
                                          ...Thought I would throw it in here if anyone wants to use ... and see what you can make of it...
                                          Thanks to Box for sharing his most lovely and cuddly figure - I love it ❗ πŸ˜„
                                          This is my scenes idea
                                          Box_CartoonMan_Dancers Proxy.skp
                                          • boofredlayB Offline
                                            boofredlay
                                            @vanpi said:
                                            Bottle
                                            Stellar!
                                            • 82
                                            • 83
                                            • 4 / 83
