    How to Model Rubbish
    21 Posts 12 Posters 3.7k Views 12 Watching
    • B
      blackdogsketch
      You might want to experiment with the extension "CLF Greeble".
      Greebles are random bumpiness in models. Think of large starships in sci-fi movies. All that crazy bumpiness and detail, from afar, is often created with greebles. A lot of apparent detail without large amounts of geometry. If your flyover is graphically conceptual, you can apply some random materializing. If it's photo-realistic, apply actual detailed aerial imagery of landfills.
      • Collage ArchitectureC
        You can use skatter to scatter garbage on any area in your control.
        I love Sketchup
          And Protrude by Jim for some many forms and levels!
          Taper can be also applied!
          • JQLJ
            JQL
            You didnt create rubish pilou... Thats a city. Godzilla needs a meaner look. You'll get there with some work.
            www.casca.pt
            Visit us on facebook!
              It's a city of rubish compressed! ๐Ÿ˜„
              http://www.3drivers.com/upload/iblock/33a/cube_03.jpg
              • HornOxxH
                HornOxx
                @rich o brien said:
                ...Or even Thom's Bitmap to Height...
                ...which is what I tried - and it worked quite well even.
                With Bitmap to Height I made some proxys which could be replaced then within the renderer (similar to scatter which I donยดt have so far however).
                This way is good for detailed views and should be complemented by scattered detail-rubbish additionally where needed.
                In any case - all the methods mentioned here are useful in combination...
                I would like to see any picture impression, which visuall result is striven by Bulbangs?
                never trust a skinny cook
                • B
                  bulbangs
                  Thank you to all who responded. You've all helped immensely with your suggestions. Here is the first pass of the render. Still have a few adjustments to make but the client expressed satisfaction with the output. ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                  • HornOxxH
                    HornOxx
                    @bulbangs said:
                    ... Here is the first pass of the render...
                    ... I canยดt see anything โ“ ๐Ÿ˜„
                    • soloS
                      Neither can I, I was anticipating saying "it's rubbish" ๐Ÿ’š
                      • B
                        bulbangs
                        • HornOxxH
                          HornOxx
                          ๐Ÿ‘ wow - a great and "terrible" scene at the same time.
                          How did you proceed now?
                          • B
                            bulbangs
                            Modeled the huge pile using sand box and textured it with a map. I then used skatter to add thousands of objects to litter the surface to create the top layer trash.
                            • genma saotomeG
                              genma saotome
                              Create rubbish? There are a few of my earliest models.... ๐Ÿ˜Ž
                              Seriously, it's going to be the textures that solve your problem. I did a model of a recycling metals company and I found some very useful (free) textures at textures.com. I suggest you check there.
