    How to Model Rubbish
    21 Posts 12 Posters 3.7k Views 12 Watching
      And Protrude by Jim for some many forms and levels!
      Taper can be also applied!
      • JQLJ
        JQL
        You didnt create rubish pilou... Thats a city. Godzilla needs a meaner look. You'll get there with some work.
        www.casca.pt
        Visit us on facebook!
          It's a city of rubish compressed! ๐Ÿ˜„
          http://www.3drivers.com/upload/iblock/33a/cube_03.jpg
          • HornOxxH
            HornOxx
            @rich o brien said:
            ...Or even Thom's Bitmap to Height...
            ...which is what I tried - and it worked quite well even.
            With Bitmap to Height I made some proxys which could be replaced then within the renderer (similar to scatter which I donยดt have so far however).
            This way is good for detailed views and should be complemented by scattered detail-rubbish additionally where needed.
            In any case - all the methods mentioned here are useful in combination...
            I would like to see any picture impression, which visuall result is striven by Bulbangs?
            never trust a skinny cook
            • B
              bulbangs
              Thank you to all who responded. You've all helped immensely with your suggestions. Here is the first pass of the render. Still have a few adjustments to make but the client expressed satisfaction with the output. ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
              • HornOxxH
                HornOxx
                @bulbangs said:
                ... Here is the first pass of the render...
                ... I canยดt see anything โ“ ๐Ÿ˜„
                • soloS
                  Neither can I, I was anticipating saying "it's rubbish" ๐Ÿ’š
                  • B
                    bulbangs
                    • HornOxxH
                      HornOxx
                      ๐Ÿ‘ wow - a great and "terrible" scene at the same time.
                      How did you proceed now?
                      • B
                        bulbangs
                        Modeled the huge pile using sand box and textured it with a map. I then used skatter to add thousands of objects to litter the surface to create the top layer trash.
                        • genma saotomeG
                          genma saotome
                          Create rubbish? There are a few of my earliest models.... ๐Ÿ˜Ž
                          Seriously, it's going to be the textures that solve your problem. I did a model of a recycling metals company and I found some very useful (free) textures at textures.com. I suggest you check there.
