    [Plugin] Slender - Baking textures in Sketchup with Blender
    29 Posts 7 Posters 14.4k Views 7 Watching
    • Q Offline
      qpik
      @jql said:
      And how will you make the material assignement?
      Material code names? Like Glass, Metal, Wood and the likes? Or you won't get into material properties?
      I don't know yet, maybe. Or a class for managing materials in SU and exported to COLLADA. Probably the first solution would be easier to extend with external material libraries.
      Specularity/bump etc. are worth supporting but reflections/refraction can't be really baked, so its no use going too much into detail.
      • JQLJ Offline
        JQL
        Well, I think it'll be nice if you pull it off. I wish you good luck and I'm following the thread.
        www.casca.pt
        Visit us on facebook!
          gio
          +1
          Ciao,
          Gio
          • filibisF Offline
            filibis
            Hi qpik, this will definetely be a useful plugin and worth developing i believe.
            Couple of things to note; i didn't know how to load a plugin via SU Console (assuming you meant Ruby Console?) and i found out i needed to type this with inverted commas: Load 'slender.rb'
            You may consider to add info considering newbies to plugin world like me πŸ™‚ even at this stage to be able to test.
            @qpik said:
            @jql said:
            So tell me one thing. Slender exports to blender does it all by itself and imports it back baked?
            Exactly.
            That just didn't work for me.
            I opened your file and run the plugin via Ruby console and received the 'true' result but there is no COLLADA (.dae) file in the folder (there are textures exported though). And seems nothing happened.
            Am i doing something wrong? If you could demonstrate with .gif or video, that would be great.
            • Q Offline
              qpik
              Have you unpacked the whole 'slender' folder from the zip file?
              Do you have blender installed? Maybe the installation path is different than mine (C:\Program Files\Blender Foundation\Blender\blender.exe), check slender.bat in the 'slender' folder.
              In sketchup open Ruby Console and type
              load 'C;/../../slender/slender.rb'
              with the actual path.
              • filibisF Offline
                filibis
                load 'C;/../..slender/slender.rb'
                Yes, unpacked, have Blender (2.78c) on default location.
                But i found out that .dae and .log files are in my default plugin location (...\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins). So appearently my problem was copying 'slender.rb' file to that location in order to make the command (load 'slender.rb') work.
                Now i tried your new code line with my path and it did some CMD stuff and received 'true' result on Ruby Console. But seems there is no imported result in SU. I tried importing that 'overwritten' .dae file but they seem identical. What should i expect at this point? Is it going to import baked result to side of the original model (as you show in first post)?
                • Q Offline
                  qpik
                  The result should be the same as after importing COLLADA, a model ready to be placed in SU, but with shadows baked.
                  If you add
                  pause
                  at the end of slender.bat you should be able to see any blender errors.
                  • filibisF Offline
                    filibis
                    Well, i got home and i tried on my laptop, it worked like a charm!
                    I will see tomorrow what causes problem in the office computer (only difference is that's Windows 7 64-bit).
                    Then i created my own scene, it worked pretty well too.
                    Except when i tried to experiment with some interior scenes. See attachment for faulty result. It's completely dark inside (with some light artifacts).
                    Original Model vs Baked Result
                    baked_result_comparison_v2013.skp
                    • Q Offline
                      qpik
                      Simple triangulation issue in slender.rb (you should see HOLES NOT SUPPORTED in Blender console).
                      triangulated_faces => true
                      Fixed and reuploaded whole package. Result:
                      baked_result_comparison_v2013_qpik.skp
                      After tweaking slender.blend scene (Environment Lighting Raytrace -> Approximate) which you can try with your own settings:
                      baked_result_comparison_v2013_qpik_1.skp
                      • filibisF Offline
                        filibis
                        Hmm, i see now better.
                        So, can we say it's not that suitable for interior stuff? Or is it possible to add other light types in addition to sun into baking process?
                        • Q Offline
                          qpik
                          It's all a matter of translating objects from SU to Blender, then everything is possible.
                          • JQLJ Offline
                            JQL
                            qpik, you're using cycles or is this blender internal?
                            www.casca.pt
                            • Rich O BrienR Online
                              @qp
                              fantastic idea. Can't get it going yet so subscribing so I can flag updates
                              • Q Offline
                                qpik
                                So far internal, why do you ask?
                                • JQLJ Offline
                                  JQL
                                  Out of curiosity. I've seen great things coming from cycles and heard it's improving very fast.
                                  Who knows where this plugin will lead so, maybe cycles would be a good bet.
                                  www.casca.pt
                                  • filibisF Offline
                                    filibis
                                    I tried again in the office today, i noticed this code was missing in slender.bat
                                    %~dp0\slender.blend
                                    (see attachment) I don't remember deleting it, maybe downloaded the .zip yesterday before you update or something idk 🀣
                                    So i downloaded .zip again today, it worked fine. πŸ‘
                                    • PixeroP Offline
                                      Pixero
                                      A couple of question.
                                      How does the geometry look when imported back into SketchUp?
                                      Is it grouped the same?
                                      Are the components intact?
                                      Is the geometry triangulated or as it was originally in SU?
                                      • filibisF Offline
                                        filibis
                                        Seems it imports one component that contains the whole geometry and everything inside exploded. Also triple clicking only select ones that shares the same material. See below for gif demonstrations.
                                        Triangulation and other export features are optional (see attachment). (But making "preserve_instancing => true" doesn't seem to be working)
                                        https://gifyu.com/images/slender_demonstration.gif
                                        https://gifyu.com/images/slender_demonstration_tripleclick.gif
                                        • Q Offline
                                          qpik
                                          Unless I'm missing something there's no combination of COLLADA import/export settings in SU and Blender that would keep components. It's just how those exporters/importers work.
                                          Triangulation solves issue with holes in faces, which are not supported, as far as I learned, in Blender.
                                          The real question is whether keeping component structure is really necessary, I doubt it.
                                          • N Offline
                                            n8phu
                                            I am getting the same result as qpik, I put the pause i nthe bat file and this is the error it is giving me:
                                            TypeError: Converting py args to operator properties: : keyword "include_material_textures" unrecognized
                                            • 2 / 2
