    [Plugin] Slender - Baking textures in Sketchup with Blender
    29 Posts 7 Posters 16.1k Views 7 Watching
    • JQLJ Offline
      JQL
      Well, I think it'll be nice if you pull it off. I wish you good luck and I'm following the thread.
      www.casca.pt
      Visit us on facebook!
        gio
        +1
        Ciao,
        Gio
        • filibisF Offline
          filibis
          Hi qpik, this will definetely be a useful plugin and worth developing i believe.
          Couple of things to note; i didn't know how to load a plugin via SU Console (assuming you meant Ruby Console?) and i found out i needed to type this with inverted commas: Load 'slender.rb'
          You may consider to add info considering newbies to plugin world like me πŸ™‚ even at this stage to be able to test.
          @qpik said:
          @jql said:
          So tell me one thing. Slender exports to blender does it all by itself and imports it back baked?
          Exactly.
          That just didn't work for me.
          I opened your file and run the plugin via Ruby console and received the 'true' result but there is no COLLADA (.dae) file in the folder (there are textures exported though). And seems nothing happened.
          Am i doing something wrong? If you could demonstrate with .gif or video, that would be great.
          • Q Offline
            qpik
            Have you unpacked the whole 'slender' folder from the zip file?
            Do you have blender installed? Maybe the installation path is different than mine (C:\Program Files\Blender Foundation\Blender\blender.exe), check slender.bat in the 'slender' folder.
            In sketchup open Ruby Console and type
            load 'C;/../../slender/slender.rb'
            with the actual path.
            • filibisF Offline
              filibis
              load 'C;/../..slender/slender.rb'
              Yes, unpacked, have Blender (2.78c) on default location.
              But i found out that .dae and .log files are in my default plugin location (...\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins). So appearently my problem was copying 'slender.rb' file to that location in order to make the command (load 'slender.rb') work.
              Now i tried your new code line with my path and it did some CMD stuff and received 'true' result on Ruby Console. But seems there is no imported result in SU. I tried importing that 'overwritten' .dae file but they seem identical. What should i expect at this point? Is it going to import baked result to side of the original model (as you show in first post)?
              • Q Offline
                qpik
                The result should be the same as after importing COLLADA, a model ready to be placed in SU, but with shadows baked.
                If you add
                pause
                at the end of slender.bat you should be able to see any blender errors.
                • filibisF Offline
                  filibis
                  Well, i got home and i tried on my laptop, it worked like a charm!
                  I will see tomorrow what causes problem in the office computer (only difference is that's Windows 7 64-bit).
                  Then i created my own scene, it worked pretty well too.
                  Except when i tried to experiment with some interior scenes. See attachment for faulty result. It's completely dark inside (with some light artifacts).
                  Original Model vs Baked Result
                  baked_result_comparison_v2013.skp
                  • Q Offline
                    qpik
                    Simple triangulation issue in slender.rb (you should see HOLES NOT SUPPORTED in Blender console).
                    triangulated_faces => true
                    Fixed and reuploaded whole package. Result:
                    baked_result_comparison_v2013_qpik.skp
                    After tweaking slender.blend scene (Environment Lighting Raytrace -> Approximate) which you can try with your own settings:
                    baked_result_comparison_v2013_qpik_1.skp
                    • filibisF Offline
                      filibis
                      Hmm, i see now better.
                      So, can we say it's not that suitable for interior stuff? Or is it possible to add other light types in addition to sun into baking process?
                      • Q Offline
                        qpik
                        It's all a matter of translating objects from SU to Blender, then everything is possible.
                        • JQLJ Offline
                          JQL
                          qpik, you're using cycles or is this blender internal?
                          www.casca.pt
                            @qp
                            fantastic idea. Can't get it going yet so subscribing so I can flag updates
                            • Q Offline
                              qpik
                              So far internal, why do you ask?
                              • JQLJ Offline
                                JQL
                                Out of curiosity. I've seen great things coming from cycles and heard it's improving very fast.
                                Who knows where this plugin will lead so, maybe cycles would be a good bet.
                                www.casca.pt
                                • filibisF Offline
                                  filibis
                                  I tried again in the office today, i noticed this code was missing in slender.bat
                                  %~dp0\slender.blend
                                  (see attachment) I don't remember deleting it, maybe downloaded the .zip yesterday before you update or something idk 🀣
                                  So i downloaded .zip again today, it worked fine. πŸ‘
                                  • PixeroP Offline
                                    Pixero
                                    A couple of question.
                                    How does the geometry look when imported back into SketchUp?
                                    Is it grouped the same?
                                    Are the components intact?
                                    Is the geometry triangulated or as it was originally in SU?
                                    • filibisF Offline
                                      filibis
                                      Seems it imports one component that contains the whole geometry and everything inside exploded. Also triple clicking only select ones that shares the same material. See below for gif demonstrations.
                                      Triangulation and other export features are optional (see attachment). (But making "preserve_instancing => true" doesn't seem to be working)
                                      https://gifyu.com/images/slender_demonstration.gif
                                      https://gifyu.com/images/slender_demonstration_tripleclick.gif
                                      • Q Offline
                                        qpik
                                        Unless I'm missing something there's no combination of COLLADA import/export settings in SU and Blender that would keep components. It's just how those exporters/importers work.
                                        Triangulation solves issue with holes in faces, which are not supported, as far as I learned, in Blender.
                                        The real question is whether keeping component structure is really necessary, I doubt it.
                                        • N Offline
                                          n8phu
                                          I am getting the same result as qpik, I put the pause i nthe bat file and this is the error it is giving me:
                                          TypeError: Converting py args to operator properties: : keyword "include_material_textures" unrecognized
                                          • N Offline
                                            n8phu
                                            I should have also included I am using win 10, blender 2.79c, sketchup 17
