    1.5k Posts 471 Posters 3.3m Views 470 Watching
      Gábor
      @hamodat said:
      why can't i download it no download to click on!!!!!!help please
      http://sketchucation.com/pluginstore?pln=RoundCorner
      You have to be logged in to the site to see the download button at the above link.
        san5475
        這個工具很棒,用了好多年喇
          rdea
          i laready download this plugins and the libfredo buy plugins doesnt show on the extentions toolbar ? i'm using sketchup 2015. can someone help me ?
            What did you do with the files after you downloaded them?
              In the V15 you have Round Corner as
              • Icon
              • Menu Tools / Fredo 6 Collection / Round Corner
                You will have already downloaded twp RBZ archives [probably now in your Downloads folder??].
                These need to be properly installed, one after the other [Lib first is best, but not essential].
                In v2015 the installation is done using [PC=Window >] Preferences > Extensions > Install button [in v2017 this is now found under Window > Extension Manager [dialog button]
                Click that button, find the RBZ and install it...
                After both RBZ files are installed you will need to restart SketchUp to ensure that the Lib methods are fully set up and the tool is available.
                Under the Extensions dialog ensure the LibFredo is enabled, also ensure that the RoundCorner extension is enabled.
                That extension should now have a Tools submenu menu entry and a matching Toolbar available...
                As @Pilou explained above...
                  Banda
                  Thank you.It's all I need.
                  • V Offline
                    valerostudio
                    First, this plugin is one of the best. Thanks for all of your hard work. Second, any chance that we can expect a parametric option in the future? I would love to be able to turn off the corners, work, than turn back on, similar to how SubD works. Thanks again!!!
                      Ricardo Marquez
                      Es muy util, gracias
                        Denisferragut
                        Hi im new in this, and i dont know where to click and download de plug in...somo help please!
                        • jujuJ Offline
                          juju
                          scroll to the top of the page, click on "Pluginstore", search for it there, select download
                            lilywater
                            hope it would be helpful,thanks!
                            • fredo6F Offline
                              NEW RELEASE: RoundCorner v3.2a - 03 Jun 17
                              RoundCorner 3.2a is a maintenance release. It is now certified for SU2017 and also comply with a new publishing model where the Plugin information is on the Extension Store.
                              Home Page of RoundCorner for information and Download.
                              Main post of this thread.
                                tyuiop
                                Dur a installer mais très utile, prise en main très rapide, utile pour la conception d'objets pour imprimante 3d.
                                Merci! 😉
                                • fredo6F Offline
                                  @tyuiop said:
                                  Dur a installer
                                  Ou sont les 'points durs' de l'installation ?
                                  • H Offline
                                    huu5189
                                    Help me, I can't make round corner from this model
                                    round corner.skp
                                      What part are you trying to round over?
                                        Yes. It'll skin over the opening. Just select that face and hit the Delete key and you should be good to go.
                                        • I Offline
                                          interconnect
                                          That worked. Would never of thought to do that. Thanks!
                                          • I Offline
                                            interconnect
                                            How do I round or bevel the inside edge of a circle? Whenever I do it my model gets filled somehow. I'm sure I must be missing something.
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 73
                                            • 74
                                            • 66 / 74
