    1.5k Posts 478 Posters 4.3m Views 478 Watching
      san5475
      這個工具很棒,用了好多年喇
        rdea
        i laready download this plugins and the libfredo buy plugins doesnt show on the extentions toolbar ? i'm using sketchup 2015. can someone help me ?
          What did you do with the files after you downloaded them?
            In the V15 you have Round Corner as
            • Icon
            • Menu Tools / Fredo 6 Collection / Round Corner
              You will have already downloaded twp RBZ archives [probably now in your Downloads folder??].
              These need to be properly installed, one after the other [Lib first is best, but not essential].
              In v2015 the installation is done using [PC=Window >] Preferences > Extensions > Install button [in v2017 this is now found under Window > Extension Manager [dialog button]
              Click that button, find the RBZ and install it...
              After both RBZ files are installed you will need to restart SketchUp to ensure that the Lib methods are fully set up and the tool is available.
              Under the Extensions dialog ensure the LibFredo is enabled, also ensure that the RoundCorner extension is enabled.
              That extension should now have a Tools submenu menu entry and a matching Toolbar available...
              As @Pilou explained above...
              • B
                Banda
                Thank you.It's all I need.
                • V
                  valerostudio
                  First, this plugin is one of the best. Thanks for all of your hard work. Second, any chance that we can expect a parametric option in the future? I would love to be able to turn off the corners, work, than turn back on, similar to how SubD works. Thanks again!!!
                    Ricardo Marquez
                    Es muy util, gracias
                      Denisferragut
                      Hi im new in this, and i dont know where to click and download de plug in...somo help please!
                      • jujuJ
                        juju
                        scroll to the top of the page, click on "Pluginstore", search for it there, select download
                        • L
                          lilywater
                          hope it would be helpful,thanks!
                          • fredo6F
                            NEW RELEASE: RoundCorner v3.2a - 03 Jun 17
                            RoundCorner 3.2a is a maintenance release. It is now certified for SU2017 and also comply with a new publishing model where the Plugin information is on the Extension Store.
                            Home Page of RoundCorner for information and Download.
                            Main post of this thread.
                            • T
                              tyuiop
                              Dur a installer mais très utile, prise en main très rapide, utile pour la conception d'objets pour imprimante 3d.
                              Merci! 😉
                              • fredo6F
                                @tyuiop said:
                                Dur a installer
                                Ou sont les 'points durs' de l'installation ?
                                • H
                                  huu5189
                                  Help me, I can't make round corner from this model
                                  round corner.skp
                                    What part are you trying to round over?
                                      Yes. It'll skin over the opening. Just select that face and hit the Delete key and you should be good to go.
                                      • I
                                        interconnect
                                        That worked. Would never of thought to do that. Thanks!
                                        • I
                                          interconnect
                                          How do I round or bevel the inside edge of a circle? Whenever I do it my model gets filled somehow. I'm sure I must be missing something.
                                          • fredo6F
                                            NEW RELEASE: RoundCorner v3.2b - 24 Jun 17
                                            RoundCorner 3.2b is a maintenance release. It fixes a bug when selecting edges interactively in certain situations (usually with corners of 4 edges and more).
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 74
                                            • 75
                                            • 59 / 75
