    1.5k Posts 476 Posters 4.0m Views 476 Watching
      Ricardo Marquez
      Es muy util, gracias
        Denisferragut
        Hi im new in this, and i dont know where to click and download de plug in...somo help please!
        • jujuJ Offline
          juju
          scroll to the top of the page, click on "Pluginstore", search for it there, select download
            lilywater
            hope it would be helpful,thanks!
            • fredo6F Offline
              NEW RELEASE: RoundCorner v3.2a - 03 Jun 17
              RoundCorner 3.2a is a maintenance release. It is now certified for SU2017 and also comply with a new publishing model where the Plugin information is on the Extension Store.
              Home Page of RoundCorner for information and Download.
              Main post of this thread.
                tyuiop
                Dur a installer mais très utile, prise en main très rapide, utile pour la conception d'objets pour imprimante 3d.
                Merci! 😉
                • fredo6F Offline
                  @tyuiop said:
                  Dur a installer
                  Ou sont les 'points durs' de l'installation ?
                  • H Offline
                    huu5189
                    Help me, I can't make round corner from this model
                    round corner.skp
                      What part are you trying to round over?
                        Yes. It'll skin over the opening. Just select that face and hit the Delete key and you should be good to go.
                        • I Offline
                          interconnect
                          That worked. Would never of thought to do that. Thanks!
                          • I Offline
                            interconnect
                            How do I round or bevel the inside edge of a circle? Whenever I do it my model gets filled somehow. I'm sure I must be missing something.
                            • fredo6F Offline
                              NEW RELEASE: RoundCorner v3.2b - 24 Jun 17
                              RoundCorner 3.2b is a maintenance release. It fixes a bug when selecting edges interactively in certain situations (usually with corners of 4 edges and more).
                                secretling0617
                                非常感謝分享~~
                                  tramspotters
                                  Great plugin, but unfortunately on a Macbook with Retina display the toolbar is really tiny. Is it possible to consider this in the next update?
                                    barakuda
                                    RoundCorner is great tool. I used it in SU8 to perform small modifications of terrain (squares 5mx5m).
                                    I have tested versions 2.3 and 3.2b (current). To compare.
                                    With v2.3 I have found problem when I try to select edges and junctions idividualy. The arro color often changes from blue or from orange to red. This is not what I want. Because the SU8 reacts slowly, often happened to me often that the selection which I did was removed because the red arrow was there. I mean, it was not visible, but the SU thinks like it is there because the SU runs slowly when it must work with a lot of entities. Hence for this selection I found the red arrow completely useless. I please, you either remove it from your program or give option to disable the function of complete selection of edges using red arrow. For me this is discomfort and frustrationg when I can not disable it.
                                    In v3.2b. The selection of individual edges is more easy than in v2.3. Less work. But the SU8 have crashed after a minute of work. So I have to uninstall the 3.2b and I hope in the next version you will fix the problem.
                                    Thank you for your tool
                                      barakuda
                                      Once again testing 3.2b
                                      and this error occured:
                                      Ruby Error - Round Corner - 03-Jul-17 13_10_04.txt
                                      Date: 03-Jul-17 13:10:04
                                      An error occurred in Round Corner
                                      Error
                                      Cannot convert argument to Sketchup::Point3d
                                      (eval): 1878 -- add_edges
                                      (eval): 1878 -- robot_protected
                                      (eval): 1874 -- each
                                      (eval): 1874 -- robot_protected
                                      (eval): 1854 -- robot
                                      (eval): 1848 -- robot_top_execute
                                      (eval): 332 -- call
                                      (eval): 332 -- step_geometry
                                      (eval): 293 -- yield?
                                      (eval): 605 -- call
                                      Please contact me if you want to solve this bug.
                                      • fredo6F Offline
                                        It would help if you post the model, because the bug is probably related to the model. Again, RoundCorner cannot handle all cases, especially in complex models.
                                        Does it happen with a simple cube?
                                        Regarding the Red arrow, which is to pick the edges of a face, I don't understand your problem.
                                        If Sketchup is so slow, then you have a more general problem. In SU8, I would suggest you have a look at the settings in Window > Preferences > OpenGL and try to change the "Capabilities". This may be the source of bad performance.
                                        • fredo6F Offline
                                          I think I have to do it, as I don't expect this will be fixed by sketchup any time soon.
                                          For the palette, I can probably grow it.
                                          Could you tell me if the red and green lines (displayed when you select edges) needs also to be thicker?
                                          There is now a discussion on the subject.
                                            ScetcheeDave
                                            Hi Fredo, great Extn. Im very beginner. Im getting a failure (me?). This object is 22mm diameter - hopefully the images speak clearer than I can. Im trying to round off edges highlighted in image below but to do so results in fill in or some other failure see other 😞 .jpg. Any ideas?
                                            You can see in the image with green ticks it worked on a couple of edges. It works if I only select 1 or a couple of edges.
                                            http://i.imgur.com/TInPQr5.jpg
                                            http://i.imgur.com/xRMKbnL.jpg
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 74
                                            • 75
                                            • 59 / 75
