    Vertex tools
    53 Posts 16 Posters 12.9k Views 16 Watching
    • JQLJ
      JQL
      @rich o brien said:
      Fo shizzle...
      There's also something brewing called ReMeshR....
      [attachment=1:jarulvus]<!-- ia1 -->Image 1.png<!-- ia1 -->[/attachment:jarulvus]
      [attachment=0:jarulvus]<!-- ia0 -->Image 2.png<!-- ia0 -->[/attachment:jarulvus]
      ๐Ÿ˜›
      So there is sound on that silence!
      www.casca.pt
      Visit us on facebook!
        Quietly moving forward.
        WrapR goes to open beta soon.
        • JQLJ
          JQL
          The sooner it's on sale the sooner I'll get to brag again about multigroups, atlases and UDIM... ๐Ÿ˜„
          www.casca.pt
          • O
            optimaforever
            Can't wait for VT2 and SubD2 (opensubdivs?)
              Indeed ๐Ÿ˜„
              • Collage ArchitectureC
                Can we play with Wrap-R before Christmas?
                I love Sketchup
                • pbacotP
                  @jql said:
                  @rich o brien said:
                  That said VT is still the best extension ever made ๐Ÿ‘ IMHO
                  That is clearly wrong, the best one is Edgetools2 splitface tool along with SectionCutFace
                  Why two together?
                  Split face tool should be in SU. Actually maybe both these should have been. However SFT does fail to take sometimes with inferences. Need multiples and repeat action to be overwhelmingly great... Should be standalone tool.
                    sofie9536
                    I change my computer, do I need a new license?
                      No, the license is per-user. ๐Ÿ˜„
                        Does exist Function "Recall (Last) Selection" ?
                        Because after apply some deformations and click on the empty space
                        seems selection is losted being always inside Vertex tools! ๐Ÿ˜ฎ
                        If not, very painful in case of numerous or/and complex selection!
                          rv1974
                          Some humble features requests:
                          1. Is it possible to enable snapping on gizmo manipulating;
                          2. Ability to lock (vertices) selection.
                            rv1974
                            I have some issues with scaling along local axes. It simply not 100% precise.
                            Please see attached. I tried to flatten to 0.00 but had no luck.
                            Another problem- I can't wind a way to input values (while scaling) with keyboard,
                            mouse(=pain) only. Do I miss something?
                            Edit: After a brief research I found that Fredo6 Scale and S4u scale can flatten to zero in any direction.
                              Clicking in empty model space clears the selection as intended - mimicking native SketchUp selection.
                              Next release will have snapping at origin. And other gizmo improvements.
                              Not in the currently released version. But it's on my list for the new release.
                              • JQLJ
                                JQL
                                And inferences? Like we discussed before?
                                That would be stellar!
                                www.casca.pt
                                • C
                                  cuttingedge
                                  Vertex tools remain one of my most used plugin. It changed the way I looked at SU.
                                  Iโ€™d just like to bring up my request if I may the following features for vertex tools next release.
                                  1. The ability to soft select โ€œconnected verticesโ€ only and not all vertices within
                                    the radius.
                                  1. To be able to offset or inset quad faces. Same as native offset but split to quads. I dot know if it should come thru QFT or other plugins. But this will be great addition
                                    offset/ inset
                                  3.To be able to merge vertices with snapping. Should be able to select which
                                  vertices move and which one stay. (Maybe locking a vertex will make it stay)
                                  1. To be able to lock selected vertices. In this way well have better control of
                                    Vertices that you want to edit . This could be an option if issue no1 is hard to do.
                                  Well, as it is now is very useful. Just want to present this for the author's consideration..
                                    rv1974
                                    ^^! to deselect softly pre-selected ones would be great indeed!
                                      I need to look through my notes on inferences with the gizmo. I recall having conversation about this.
                                        Great feature suggestions! I've logged them all for review.
                                        Do keep them coming! ๐Ÿ˜„
                                        How would this be different from the existing merge tool?
                                        • C
                                          cuttingedge
                                          The current merge tool collapses the selection into a single point which is the average position of the selection.
                                          When you want one vertex to be joined to one fixed vertex and snaps it into place. If we can do that, It will be great! (Snapping can be toggled on and off and radius be pre- set)
                                          • JQLJ
                                            JQL
                                            You're talking about the gizmo inferences?
                                            I hope so...
                                            www.casca.pt
                                            • 2 / 3
