    Vertex tools
    53 Posts 16 Posters 12.9k Views 16 Watching
    • JQLJ
      JQL
      @rich o brien said:
      That said VT is still the best extension ever made ๐Ÿ‘ IMHO
      That is clearly wrong, the best one is Edgetools2 splitface tool along with SectionCutFace
      www.casca.pt
      Visit us on facebook!
      • BoxB
        Not that I care, but in the interests of accuracy, you need two tools to beat Rich's one.
          Fo shizzle...
          There's also something brewing called ReMeshR....
          ๐Ÿ˜›
          • JQLJ
            JQL
            Let's say I can't decide which one of them is the best, I'd put them both above everything else basically. ๐Ÿ˜„
            www.casca.pt
            • JQLJ
              JQL
              @rich o brien said:
              Fo shizzle...
              [attachment=1:jarulvus]<!-- ia1 -->Image 1.png<!-- ia1 -->[/attachment:jarulvus]
              [attachment=0:jarulvus]<!-- ia0 -->Image 2.png<!-- ia0 -->[/attachment:jarulvus]
              ๐Ÿ˜›
              So there is sound on that silence!
              www.casca.pt
                Quietly moving forward.
                WrapR goes to open beta soon.
                • JQLJ
                  JQL
                  The sooner it's on sale the sooner I'll get to brag again about multigroups, atlases and UDIM... ๐Ÿ˜„
                  www.casca.pt
                  • O
                    optimaforever
                    Can't wait for VT2 and SubD2 (opensubdivs?)
                      Indeed ๐Ÿ˜„
                      • Collage ArchitectureC
                        Can we play with Wrap-R before Christmas?
                        I love Sketchup
                        • pbacotP
                          Why two together?
                          Split face tool should be in SU. Actually maybe both these should have been. However SFT does fail to take sometimes with inferences. Need multiples and repeat action to be overwhelmingly great... Should be standalone tool.
                            sofie9536
                            I change my computer, do I need a new license?
                              No, the license is per-user. ๐Ÿ˜„
                                Does exist Function "Recall (Last) Selection" ?
                                Because after apply some deformations and click on the empty space
                                seems selection is losted being always inside Vertex tools! ๐Ÿ˜ฎ
                                If not, very painful in case of numerous or/and complex selection!
                                  rv1974
                                  Some humble features requests:
                                  1. Is it possible to enable snapping on gizmo manipulating;
                                  2. Ability to lock (vertices) selection.
                                    rv1974
                                    I have some issues with scaling along local axes. It simply not 100% precise.
                                    Please see attached. I tried to flatten to 0.00 but had no luck.
                                    Another problem- I can't wind a way to input values (while scaling) with keyboard,
                                    mouse(=pain) only. Do I miss something?
                                    Edit: After a brief research I found that Fredo6 Scale and S4u scale can flatten to zero in any direction.
                                      Clicking in empty model space clears the selection as intended - mimicking native SketchUp selection.
                                      Next release will have snapping at origin. And other gizmo improvements.
                                      Not in the currently released version. But it's on my list for the new release.
                                      • JQLJ
                                        JQL
                                        And inferences? Like we discussed before?
                                        That would be stellar!
                                        www.casca.pt
                                        • C
                                          cuttingedge
                                          Vertex tools remain one of my most used plugin. It changed the way I looked at SU.
                                          Iโ€™d just like to bring up my request if I may the following features for vertex tools next release.
                                          1. The ability to soft select โ€œconnected verticesโ€ only and not all vertices within
                                            the radius.
                                          1. To be able to offset or inset quad faces. Same as native offset but split to quads. I dot know if it should come thru QFT or other plugins. But this will be great addition
                                            offset/ inset
                                          3.To be able to merge vertices with snapping. Should be able to select which
                                          vertices move and which one stay. (Maybe locking a vertex will make it stay)
                                          1. To be able to lock selected vertices. In this way well have better control of
                                            Vertices that you want to edit . This could be an option if issue no1 is hard to do.
                                          Well, as it is now is very useful. Just want to present this for the author's consideration..
                                            rv1974
                                            ^^! to deselect softly pre-selected ones would be great indeed!
                                            • 2 / 3
