    1.3k Posts 300 Posters 3.3m Views 298 Watching
      jaaphu
      Great Thanks!
        surfmike
        I'm a big fan of Curviloft.
        However I ran into an issue...
        These contours seem impossible to skin. Maybe it's to many segments (will use it for 3d printing)...
        The left one just seems to stop.
        The right one (with a small added triangle) starts, but doesn't go all the way.
        File added.
        //Mike
        test skinning
          My advice πŸ˜„
          Your curves are not clean! (segments added to extremities, overwrited itselves etc...)
          I redraw above with 4 FSPlines From Bezier Curves by Fredo
          (6 general Points each if you want many patches)
          = no Problem! 😎
          Just be carreful to the snap points! πŸ€“
          Surfaces are made in half second with CurviLoft by Fredo! β˜€
          Free Visualizer as render (till SU 2016) 😎
            surfmike
            I believe I was really careful with those mentined issues...
            However with my file it takes a long time, goes to 90%, then it seems to stop.
            With lightweight curves it works.
            Did you use high resolution aswell (300s)?
            Mike
              Resolution has quasi nothing to do with curviloft!
              it's only matrix of vertices and surface resulting! πŸ˜„
              Problem are more with no natural form curves!
              Corners, interruptions, no fluidity etc...
              If your time result of Curviloft is too long and not reasonable,
              that is that your curves are false for any reasons!
              Redraw above it! (Group the old with a little line beside for an easy selection)
              As like you can redraw above the old curves without effort of selection at the end!
                surfmike
                [attachment=0:syi8gtsw]<!-- ia0 -->GIF_line.gif<!-- ia0 -->[/attachment:syi8gtsw]
                Pilou, thanks for your assistance and informative help.
                In a hurry "resolution" was the word I found for expressing the amount of segments/verticies. πŸ˜„
                However - the amount of segments in a curve is limited to 300(s). While modelling for 3D printing, is there a possibility to override that limitaton?
                //Mike
                  surfmike
                  V
                  Hi.
                  The model consists of two components.
                  I've done all curves with "Classic bezier curve", and all are "infinite curves" following the green/red/blue axis when placing control points.
                  Still I got some kind of "V shape" in the front curved panel, see picture and file (concerning file size I had to remove the mesh).
                  How can I avoid this? I tried to elaborate by changing settings but with no luck.
                  The person solving this will be a Nobel prize prospect... πŸ˜‰
                  Thx!
                  //Mikael
                  Front 1.5 fix SUC.skp
                    If you want make 3D Print maybe export in OBJ or STL and use MeshMixer! (it's free)
                    You will obtain objects more smoothed!
                      surfmike
                      Yes, I will export to STL and use Meshmixer for scaling and hollow purposes, but I think Meshmixer can't handle this kind of artifacts. Also this surface will be a part of a bigger solid.
                      All three curves are perfect beziers ending 90Β° to each other, which preferably wouldn't give this minor V shape.
                      Is there any settings or any way to avoid this "V"?
                      Thx
                      //Mikael
                      • jgbJ
                        jgb
                        From the image posted, it looks like you have another mesh inside this outer mesh that is poking through, and you are trying to fix the outer mesh instead.
                        I can't say for sure as your SKP file is SU-2016 and I am using SU-2015 which cannot load your file. If you can post the file in 2015 format I will look at it closely.
                        jgb
                        • gillesG
                          gilles
                          [a
                          Hi.
                          Thx!
                          //Mikael
                          [attachment=1:ni34c5df]<!-- ia1 -->Front 1.5 fix SUC.skp<!-- ia1 -->[/attachment:ni34c5df][/quote]
                          [attachment=0:ni34c5df]<!-- ia0 -->tangent.gif<!-- ia0 -->[/attachment:ni34c5df][quote="surfmike"][attachment=2:ni34c5df]<!-- ia2 -->Screen Shot 2016-12-16 at 20.44.08.png<!-- ia2 -->[/attachment:ni34c5df]
                          Give me the Nobel (don't forget the$ πŸ’š ).
                            Sorry i have forgotten the $$$ ! πŸ’š
                            http://www.letelegramme.fr/images/2015/10/19/la-medaille-du-prix-nobel-de-la-paix-d-aristide-briand-a-ete_2579693_345x330p.jpg?v=1
                              surfmike
                              Thanks, a SU2015 file is attached.
                              @gilles said:
                              [a
                              I had exactly the same idea in mind, but it ended up with two "V's" with a flat surface inbetween... 😞
                              If you look real close in your animation/file you will see the shadow in the upper area telling there's still a "V", right?
                              In SU when using "soft" and "smooth" it all looks good, but when aiming towards 3D printing soft/smooth just hiding artefacts.
                              I placed a surface in the middle of the "problem area" to show it more clearly, see attached pics.
                              Thanks all!
                              //Mikael
                              Front 1.5 fix SUC (SU2015).skp
                              • jgbJ
                                jgb
                                I looked at your model; that's all I could do, is look at it.
                                One half of the model is composed of almost 2,000 UNCONNECTED very short edges. I could not even weld them into a curve. How you got a surface from them is a bit of a mystery.
                                However, the "V" you got is no mystery, as this happens to me where I flip a curved surface to form a mirrored other half. It also happens every time I create a large complex surface in several parts. I have to then massage the joins smooth.
                                The finite lines that form the curve at the "join" are not perfectly aligned in parallel to each other, and when you do the flip there is a small angle to the curve at the join, that appears as a ridge or "V" to the visual rendering. That angle at the "V" is a bit larger than the angles between the lines elsewhere on the curve, and as a result look larger.
                                To correct that, there are a few ways to do it.
                                If it was only for a visualization, then making the join lines between the 2 halves smooth and soft should make the join look smooth.
                                But you want to 3D Print this, so that probably will do nothing for the physical printed part. The "V" will form a bit of a ridge.
                                What you need to do is delete the surface triangles that form the join line, leaving a gap. But delete the end lines last. Why? Later down.
                                Explode both halves, then draw a line at the top and bottom corners, joining the 2 halves. You now have a valid curved perimeter for Curviloft to fill.
                                Explode the Curviloft group, and the "V" should disappear.
                                If the join is now too flat, then undo the Curviloft surface and the 2 lines you drew. Then undo the deletion of the 2 end lines that formed the "V". (That's why!)
                                Draw a line mid angled to the original lines and a line joining the 2 halves, then Curviloft that perimeter. This flattens the "V" but not quite flat, so the 3D printed part should not have a ridge.
                                Sorry, but I do not have the time to draw and annotate the fix. 😞
                                jgb
                                  surfmike
                                  JGB,
                                  Thanks for helping out, I fully understand your instructions. πŸ˜„
                                  However, when I color the line by axis it shows beziers with parallell red end lines (7,2mm on above, 0,045mm in the below line) in each half.
                                  Maybe 0,045mm is too short to be recognized correctly, but in the final skinning group there's parallell lines alright even though 0,045mm became 1,06mm (see attached pic).
                                  But the issue is that inbetween those perfectly parallell lines the skin gets a "V" shape... (???)
                                  //Mikael
                                  P.S The unconnected edges was a unpleasant result of copy/paste 300s beziers from SU2016 to 2015. D.S
                                  • gillesG
                                    gilles
                                    @surfmike said:
                                    JGB,
                                    //Mikael
                                    [attachment=0:vpj5k8ov]<!-- ia0 -->red_line.png<!-- ia0 -->[/attachment:vpj5k8ov]
                                    You don't need to copy/paste from SU2016 to 2015, just Save as and choose the SU version.
                                    Also when you work at this scale make a component, copy/paste this component, scale the copy X100 or X1000 and work with the copy, 0,045mm is far from the tolerance of SU to create faces.
                                    • jgbJ
                                      jgb
                                      Yes, that is a problem. I noticed it but forgot to say so in my reply. SU really does not like very short lines.
                                      To get around this scale up the whole object 10 times and do the required functions on that, then scale back to 10% to return to original scale.
                                      SU can display short lines, but has some difficulty working with them.
                                      As Gilles said, save the SU-16 version as SU-15 and re-post it so I can look at it again.
                                      jgb
                                        surfmike
                                        Here's a "Save as..." version for SU2015.
                                        Thx!
                                        Front 1.5 fix SUC (SU2015) v1.1.skp
                                        • jgbJ
                                          jgb
                                          OK, Got it.
                                          I've been playing with it for well over an hour. I needed to implement a few tricks I've learned with Curviloft over the years when it just won't skin what I see as a clean perimeter. I managed to skin all the curves and yes, I do see the "V" ridge and it is why I said above. I did a partial re-skinning of the main join of the 2 components, and that does eliminate the "V", but it is a laborious job and I simply do not have the time to finish it, so here is what I did......
                                          1 - I separated the 2 halves so they do not interfere visually as I did the fix. Move just one comp on the red axis, so later it is easy to rejoin them.
                                          2 - I tried skinning the main complex curve, but the perimeter was not true. So trick #1 is to explode the curves and delete the edges at the corners, but leaving 1 edge as a rejoin reference endpoint. I then rejoined the end points for an intact curve that Curviloft will accept. 4 corners - 8 lines deleted and redrawn.
                                          3 - Curviloft skinned the side and top easily, but hung twice on the front curve.
                                          4 - Trick #2 - when Curviloft craps out on a "perfect" perimeter, it is most often due to a very complex curve (and this IS a very complex curve) or where the curve is also part of an adjacent curve, I move/copy the perimeter away from the total object. I make sure the corners are clean, 2 lines only connected at endpoints. Curviloft skinned this. It took almost 10 minutes; I thought it hung again. When I brought the skins back together, sure enough, the "V" was there.
                                          5 - I then softened and smoothed the join line and the "V" was less noticeable, but that was a visual fix only. A 3D printed part would have a ridge.
                                          6 - I deleted the 2 faces and lines at the join from bottom to only about 1/2 way up as this was taking a long time to do. I had to do it with perspective off because the lines were so close to each other.
                                          7 - I then drew a line ON RED AXIS from each horizontal line to the length of the gap. I then made an endpoint to endpoint line up the curve, softend and smoothed all lines, and effectively recreated the part of the surface deleted in #6 but it was now flat in respect to its mirrored half.
                                          The "V" is essentially gone, as the join is flat.
                                          ![The "V" ridge is fixed 1/2 way up](/uploads/imported_attachments/hqZS_AutoSave_Front1.5fixSUCSU2015v1.jpg "The "V" ridge is fixed 1/2 way up")
                                          What you see is SU interpreting the surface as it reflects the 2 halves.
                                          That file is too big (18.5mb) to be attached for your reference. Even just the curved part is too big.
                                          A cupola pointers......
                                          The curves are way too fine, resulting in an unwieldy Curviloft surface. This skin has over 135000 entities alone. That is big. I know you want to 3D print a very smooth surface but take into account the resolution of the printer, and draw accordingly. The main problem you will face (NPI) is that Curviloft will almost double or even quadruple the line count from a perimeter because the endpoints of the opposing parts of a perimeter do not exactly align with each other.
                                          If you need to join 2 curved surfaces at a common edge, try to make the faces at the edge meet the other side as close to straight as possible, or you will need to massage that join line to make it smooth. That is a tedious task, one I have to do all too often.
                                          I hope this helps!
                                          jgb
                                          • G
                                            galrot
                                            I have sketchup 2016 and I tried to install this plugin and the latest libfredo-plugin through the Sketchucation extension. As far as I can see both got installed, but I am unable to find the toolbar or any way to access the Curviloft plugin to actually use it. Could anyone help me?
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 65
                                            • 66
                                            • 55 / 66
