    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 203.0k Views 75 Watching
      sherwood111
      TIG, Thanks for your reply and all that You do.
      Yep, I'm finding that I have to utilize a
      similar workflow as a workaround with other
      plugins too ... (in my transition to 2017).
      [slightly off subject]
      In general, I also get the annoying extension
      manager popup every session :
      "There are 'x' extensions ready to be updated"
      However, they won't update for various reasons.
      Onward and upward, as they say. πŸ˜„
      • T
        tylovset
        Hi TIG, sherwood111
        To make it work in su2017, simply comment out the line 'gp.explode' two places in the file.
        The code is referring to entities from a group after an explode, which is not allowed...
        Alternatively, move the lines mentioned down, e.g. before 'if sof==0###v3.0', to get rid of the group when no longer referred to. There are also other groups left in the model created, not sure if that is intentional.
        Just a small contribution to thank for a fantastic plugin, has been most valuable!
        -tyge
          Here's v4.0
          There are some minor tweaks and it has been adjusted for full certification in v2016/2017 and also full compatibility with v2017's id changes etc.
          http://sketchucation.com/pluginstore?pln=Roof
            sherwood111
            Excellent ..
            Yes, it is a fantastic and valuable plugin (installed and working in 2017).
            tylovset, Thank You for your time and input . . .
            TIG, Thank You for the plugin, your time and update.
            Very Much Appreciated !
            • utilerU
              utiler
              Thanks for doing this, TIG. very much appreciated; as always.....
              Just Curious...
              • pbacotP
                Thanks TIG!!!!
                  seasdes
                  20170125_122415.jpgHello TIG
                  I have installed V4.0 into SU2017.
                  I drew a simple rectanglular face and tried to create a hipped roof. However, I get the attached error message. Any ideas as to what I am doing wrong?
                  Using Sketchup Pro 2019
                  • facerF
                    facer
                    SketchUp 2016 W10 32 bit
                    I get the same error message in SketchUp 2016 Roof v4.0
                    Tried also for version Roof v3.7 and got the same error message
                      This limitation is set out in the Help...
                      Your selected flat face cannot be at z=0 [i.e. on the ground].
                      Also it's best if the seed-face is looking upwards !
                      Yours is facing down AND at z=0
                      Try again, avoiding those limitations, i.e move the face up off the ground and reverse it so it's upwards... and it should then work [unless of course your face has such a complicated outline that it is just not possible to add a single-pitch hipped roof over it... but that's another issue]...
                        It works as expected for me. Thanks TIG!
                          seasdes
                          Thanks so much TIG.
                          I assume that the help file for V3 is still current 😳
                            The change was to make it compatible with v2017.
                            Its usage is unchanged...
                            • T
                              tspco
                              Tonight I saw an update for Tig's Roof plugin, I installed it, and it worked a couple of times. then I get this, Maybe I did something wrong, I don't know for sure.
                              SU make 2017, /Twilight Render Hobby
                              Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                This is a known limitation.
                                Please read the recent posts...
                                The seed-face used for a hipped roof must NOT be at z=0 [when do you see a roof on the ground ?], and it should also be oriented to face upwards.
                                Your test examples seem to involve a rectangle drawn directly onto the ground and it is facing downwards too !
                                Extrude that face upwards into a 'box', select its top face, and now a hipped roof should form OK...
                                • T
                                  tspco
                                  That makes sense, when I mentioned it worked, I was in another project and drew the roof on the floor (above 0Z) of that model, just experimenting with the update.
                                  • T
                                    tylovset
                                    TIG,
                                    I made a shape where I can create a Mansard roof, but it says it cannot make a Hipped roof.
                                    I mention this because the algorithms seems similar. In fact, I can set "Height of Lower Roof" to only 1cm and it looks like a regular Hipped Roof. However, setting the height to 0 fails like Hipped roof.
                                    Could it be a bug? Here's the file: https://1drv.ms/u/s!AnwI6G-MJcza1X_aCfVxdSqVB69t
                                      The code for both roof-types is very similar, so I can't see why the hipped one fails.
                                      However, it was easily fixed: I deleted the top face and drew over a single edge, so that SketchUp added back the face - as explained in the error-message sometimes a face's edge-order/loop-direction becomes confused in the SKP's data-base.
                                      That replacement face then made a hipped roof without any difficulty...
                                      • mariochaM
                                        mariocha
                                        Anyone else having this bug with Gable Roof when using ^Height ?
                                        Error: #<NoMethodError: undefined methodlength' for nil:NilClass>
                                        C:/Users/---------/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Roof.rb:1725:in dialog_gable' C:/Users---------/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Roof.rb:2376:in gable'
                                        C:/Users/--------/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Roof.rb:3919:in onLButtonDown'
                                        %(#008000)[Mario C.
                                          Have you tried ^55" ?
                                          EDIT: Forget that.
                                          It's nothing to do with it per se, although it only manifests itself using ^Height...
                                          There's a weird typo in the gable making code which I need to resolve...
                                          Watch this space...
                                            Here's v5.0 https://sketchucation.com/pluginstore?pln=Roof It fixes a typo in the Gable by ^Height code which caused a failure.
                                            this was a long standing typo, which has taken several years to find and be reported on !
                                            The code is also re-signed for v2018 compatibility...
                                            • 6 / 9
