    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.3k Views 172 Watching
      Anton_S
      Hello, Tez,
      Good to hear that it's working now. And merry Christmas to you too!
      Best regards,
      Anton
        SketchyPhysicsNutt
        Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
        in Sketchyphysics i just tick the OnTouch panel and use
        playSound('Sound1')
        what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
        its no bug ..just me don't understand MS scripts yet.
        Tez
        • robintR Offline
          robint
          Hi Anton, installed 0.9.9 and restarted SU
          but its screwed up my model?
          It falls downwards and I cant get the static floor to work as before, also the script stopped working
          Did I do a corrupt installation?
          Should I have deleted 0.9.8 first - you didnt say?
          I assumed it would overwrite and update itself
          Where to go? delete and start fresh installation or go back to 0.9.8?
          What to do? 😳
          Robin
          falling block7.skp
          As one door closes another one slams in your face
            Anton_S
            Tez,
            In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
            onTouch { |toucher, position, normal, force, speed|
              simulation.play_sound("Sound1")
            You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
            Anton
              Anton_S
              Robin,
              I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
              Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
              If you want to revert to on original version, you may always refer to the instructions on the homepage.
              Anton
              • robintR Offline
                robint
                Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
                Cheers
                Robin
                • robintR Offline
                  robint
                  I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                  Overwriting existing files looks unwise and it was severely screwed up
                  I would advise users
                  Cheers
                  Robin
                  PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                  falling block8.skp
                  • F Offline
                    faust07
                    Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
                    Merry Christmas to all friends of SketchUp, physics and animation.
                    • robintR Offline
                      robint
                      Hi MSP's
                      Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
                      I thought I might add display of distance to first landing (just like a real gun spotter?
                      mortar.skp
                        SketchyPhysicsNutt
                        Hi robint your original model falling block8 and script anton
                        helped u with i found very interesting thx.
                        I set block material to gold / elasticity to 2.00 and got a
                        bouncing ball i like the affect max elasticity gives u.
                        Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
                        http://s24.postimg.org/41779b5dx/bounce.gif
                        Tez
                        • robintR Offline
                          robint
                          Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
                          I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
                          cheers, have fun
                          Robin
                            SketchyPhysicsNutt
                            Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet πŸ˜„
                            Antons original script has come in handy with my trebuchet/catapult models and projectiles
                            THX Robin happy new year
                            Tez
                            • robintR Offline
                              robint
                              Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
                              only way I found was to use the rotate tool before hitting go
                              not very elegant
                              perhaps someone else will pitch in
                              Cheers
                              Robin
                              • robintR Offline
                                robint
                                Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
                                I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
                                Robin
                                  PituPhysics
                                  Robin
                                  Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
                                  Try this:
                                  mortar 2.skp
                                    SketchyPhysicsNutt
                                    Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
                                    thx
                                    Tez
                                    • robintR Offline
                                      robint
                                      Hi PP
                                      some good stuff there, doesnt make the sound?
                                      take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
                                      Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
                                      Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
                                      What am I doing wrong?
                                      Robin
                                      mortar 3.skp
                                        PituPhysics
                                        I made more models to be more opportunities.
                                        1.) Frozen: mortar 4.1.skp
                                        2.) Hide: mortar 4.2.skp
                                        3.) Simulation pause: mortar 4.3.skp
                                        And magnet test:magnet.skp
                                        • robintR Offline
                                          robint
                                          Hi PP
                                          tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
                                          Robin
                                          • robintR Offline
                                            robint
                                            Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
                                            Universal gravitation equation
                                            F = GMm/R2
                                            where
                                            F is the force of attraction between two objects in newtons (N)
                                            G is the Universal Gravitational Constant = 6.674*10βˆ’11 N-m2/kg2
                                            M and m are the masses of the two objects in kilograms (kg)
                                            R is the separation in meters (m) between the objects, as measured from their centers of mass
                                            notice how the ball is attracted to the target even though the target has no magnetic force
                                            for example
                                            Robin
                                            my magnetic balls 1.skp
                                            • 46
                                            • 47
                                            • 2 / 47
