    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
    • mariochaM
      mariocha
      I tweaked the localized version so that it can show the toolbar icon properly.
      In Mirror_code.rb: png=File.join(DATA, "Mirror.png")
      Previously the png file name was linked to the name of the extension. But that name changes upon localisation. I made it so that the link to the png filename is not variable.
      Mirror_v6.0LH.rbz
      %(#008000)[Mario C.
        Stardown
        Hey TIG. Thanks for this plugin, very useful. I run a small CNC from home for personal improvement, and test different software. To do so I export my sketchup files to dxf. I've noticed that when using your mirror plugin, some geometry (usually curves) exports wrong into 3D dxf... even though they appear to be just fine in SketchUP. Do you know anything about that issue or how to fix it?
        If you need a sample file to check let me know.
          Here's v7.0 which is fully compatible with v2017 in all Loading Policies.
          http://sketchucation.com/pluginstore?pln=Mirror
          • mariochaM
            mariocha
            Pity that LanguageHandler is not there.
            It was all done. 😞
            with fr strings file also. πŸ˜’
            %(#008000)[Mario C.
              It was all done. 😞
              Sorry, but there are time constraints for working on these 'free' extensions...
              • mariochaM
                mariocha
                Ok then,
                I re-did it. Here is the fr localized version. Signed.
                Very easy to add any other language.
                (mirrored entities are selected at the end)
                I would be honoured if next upgrade could stem from this one. πŸ˜‰
                Mirror-7.rbz
                %(#008000)[Mario C.
                • F
                  FZSarasota
                  Coming from the VFX community, the Mirror Object/Face tool is common across all 3D packages (be it Lightwave, Max, Maya, Etc...). I found it bizarre the SU doesn't have this native function (weird). You really miss the "Mirror Tool" when hopping into a packages that don't offer it.
                  Thank you for you're development time and great little plugin, and, preventing me from loosing my mind, because I'm soooo used to having this tool!
                  Works great in SU2017, does what it claims (simple and sweet). Wink....
                  -Terry
                    Here's v8.0
                    It sidesteps the glitches some PC users get when they have accented-characters in their user-name.
                      Here's v9.0 http://sketchucation.com/pluginstore?pln=Mirror It restores compatibility with v8, which was inadvertently lost in the last update.
                      • F
                        FZSarasota
                        Thanks, I'll grab the new version now...
                        • boofredlayB
                          boofredlay
                          Cheers TIG.
                          • medeekM
                            medeek
                            Awesome plugin. SketchUp probably should have this tool/feature built in but this plugin feels the need and it works great. Much easier than having to copy, scale (-1) and then move into position.
                            Nathaniel P. Wilkerson PE
                            Medeek Engineering Inc
                            design.medeek.com
                            • T
                              TBoy
                              Mr. TIG
                              What about another version of this tool ? Let's call it '1-click Mirror'
                              Cursor snaps to nearest selection bounds plane (or if 'Ctrl' or 'Shift' pressed to worlds x, y or z planes at pick point),
                              Click and .. that's all. No prompts, no questions. Just 1 click.
                              As option:
                              Cursor as transparent rectangle for visual presentation of mirror plane.
                              In 2d projections cursor is a line presenting a plane perpendicular to view plane.
                              New mirrored object is selected after operation and eventually move tool activated for additional positioning.(?)
                              Similar to current 3point Mirror mode but plane is predefined by bounds of selection. No additional angles, only pure mirror in local (&/or world) x, y, z.( Even z-mirror is rarely used in my opinion and can be omitted-???)
                              May be I can do it by myself, but it will take me few weeks or months, a lot of digging inside incomplete documentation and few hundred SketchUp testing restarts.
                              • E
                                Einstein
                                I don't know why selection is lost when I mirror entities and don't erase original selection. On the video tutorial selection skips to newly-created geometry which is expected behaviour. In my SU after mirroring, nothing is selected. 😞
                                  If you choose to NOT keep the original object[s], then the selection transfers to the mirrored objects.
                                  Currently if you choose to keep the original object[s] nothing is selected afterwards.
                                  I appreciate that in the usage movie the mirrored object[s] remains selected in both cases.
                                  I had not noticed the change !
                                  I suspect that it's due to the way newer versions of SketchUp handle references to exploded entities...
                                  I'll look at the code and see if it's easy to reinstate the original behavior.
                                    Here's v10.0
                                    https://sketchucation.com/pluginstore?pln=Mirror
                                    The original highlighting behavior has been restored.
                                    The mirrored-copy now remains highlighted, irrespective of the user's choice to keep/delete the original.
                                    Note: after installing the update you need to restart SketchUp to see the changes...
                                    • E
                                      Einstein
                                      Thank you so much!
                                        simoncbevans
                                        This is a great plugin. It could be even better (for me anyway) with a couple of tweaks. It would be great to be able to set some defaults. For example, I often work in 2D. If you use a single line as a mirror "plane", the default is that faces get reversed. I never want that and would like it to operate the way it does if you select a vertical third plane (bit without having to do so in 2D drawing). Secondly, I almost never want to erase the original object and would like to set that as the default instead of having to confirm it each time.
                                        • cottyC
                                          cotty
                                          403 Forbidden
                                          (sketchucation.com)
                                          my SketchUp gallery
                                            https://sketchucation.com/pluginstore?pln=Mirror v11.0 - re-signed for all SUp version compatibility...
                                            • 11
                                            • 10 / 11
