    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
    • F
      FZSarasota
      Thanks, I'll grab the new version now...
      • boofredlayB
        boofredlay
        Cheers TIG.
        • medeekM
          medeek
          Awesome plugin. SketchUp probably should have this tool/feature built in but this plugin feels the need and it works great. Much easier than having to copy, scale (-1) and then move into position.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • T
            TBoy
            Mr. TIG
            What about another version of this tool ? Let's call it '1-click Mirror'
            Cursor snaps to nearest selection bounds plane (or if 'Ctrl' or 'Shift' pressed to worlds x, y or z planes at pick point),
            Click and .. that's all. No prompts, no questions. Just 1 click.
            As option:
            Cursor as transparent rectangle for visual presentation of mirror plane.
            In 2d projections cursor is a line presenting a plane perpendicular to view plane.
            New mirrored object is selected after operation and eventually move tool activated for additional positioning.(?)
            Similar to current 3point Mirror mode but plane is predefined by bounds of selection. No additional angles, only pure mirror in local (&/or world) x, y, z.( Even z-mirror is rarely used in my opinion and can be omitted-???)
            May be I can do it by myself, but it will take me few weeks or months, a lot of digging inside incomplete documentation and few hundred SketchUp testing restarts.
            • E
              Einstein
              I don't know why selection is lost when I mirror entities and don't erase original selection. On the video tutorial selection skips to newly-created geometry which is expected behaviour. In my SU after mirroring, nothing is selected. ๐Ÿ˜ž
                If you choose to NOT keep the original object[s], then the selection transfers to the mirrored objects.
                Currently if you choose to keep the original object[s] nothing is selected afterwards.
                I appreciate that in the usage movie the mirrored object[s] remains selected in both cases.
                I had not noticed the change !
                I suspect that it's due to the way newer versions of SketchUp handle references to exploded entities...
                I'll look at the code and see if it's easy to reinstate the original behavior.
                  Here's v10.0
                  https://sketchucation.com/pluginstore?pln=Mirror
                  The original highlighting behavior has been restored.
                  The mirrored-copy now remains highlighted, irrespective of the user's choice to keep/delete the original.
                  Note: after installing the update you need to restart SketchUp to see the changes...
                  • E
                    Einstein
                    Thank you so much!
                      simoncbevans
                      This is a great plugin. It could be even better (for me anyway) with a couple of tweaks. It would be great to be able to set some defaults. For example, I often work in 2D. If you use a single line as a mirror "plane", the default is that faces get reversed. I never want that and would like it to operate the way it does if you select a vertical third plane (bit without having to do so in 2D drawing). Secondly, I almost never want to erase the original object and would like to set that as the default instead of having to confirm it each time.
                      • cottyC
                        cotty
                        403 Forbidden
                        (sketchucation.com)
                        my SketchUp gallery
                          https://sketchucation.com/pluginstore?pln=Mirror v11.0 - re-signed for all SUp version compatibility...
                          • robertWanR
                            robertWan
                            Two clicks rotate the object. There is no mirror reflection. ๐Ÿ˜„
                            Robert
                              The usual usage for this tool is "3-point", which then defines a 'plane', about which a 'mirror' [reflection] occurs.
                              A "2-point" transformation, 'about a line', cannot do what you seem to consider to be a true 'mirror' [reflection] - although technically I suspect that it is - because the object is rotated around the line, but keeps its original orientation otherwise.
                              e.g. If you were to try to do this manually, then you could not expect an arbitrary 2-points to set in train what you wish, because a third point is needed to determine the 'plane' about which the hoped-for mirroring can be done...
                                5400engineering
                                Great extension that I use all the time. I realize this is free so just want to drop a few suggestions to consider if you spend any more time developing this extension:
                                1. A cancel option would be great at the Delete original object prompt, i.e. Yes / No / Cancel. I realize a ctrl-z will undo the mirror, so if it's too much effort/time to add the feature, then I will continue using ctrl-z.
                                2. Any way to use the native / (divide) command after the mirror? I often draw a screw or bolt at a location, then mirror it about a plane, then want to add evenly spaced ones in between. currently I just copy the original item onto the mirrored item, then use the / command, then delete the copied one but if possibly immediately after using mirror that would be a time saver.
                                Again, thanks for such a great extension.
                                Paul D
                                5400 Engineering
                                • H
                                  Ho02
                                  I am Ho Young and I am a 3D background designer in Korea. I work with sketchups and sell my 3D modeling to cartoonists.
                                  I joined this site for free. I want to use 'TIG' plugins in my working in sketchup.
                                  I want to use TIG plugins which name is MIRROR, FRACTURE, WELD, etc. Can I also use TIG plugins not mentioned?
                                  I downloaded the plugin for free from this site. Do I have to pay you a plugin fee?
                                  I never sell your plugins. just I want to use your plugins to create 3D modeling and sell my 3D modeling to cartoon's background. Can I use it?
                                  Thank you for making such a great plugin. Thank you very very much. You are really genius. ๐Ÿ˜„
                                  I am not good at English and thank you for reading. ๐Ÿ˜„
                                    @Ho02
                                    To clarify things.
                                    Most Plugins and Extensions at SketchUcation are free to download and use.
                                    If you find they are useful, then you can always make a voluntary donation via PayPal, using the button associated with the tool's entry.
                                    The choice to pay something is yours.
                                    If you use these Plugins commercially [as you seem to be] then you might feel some compunction to give back something in return, but it is not compulsory.
                                    So if some Plugins save you considerable time and effort, then making a donation of a very small proportion of what you earn would seem fair?
                                    Rather than distribute copies of these yourself, I recommend that you point others to the SketchUcation PluginStore, so that they can get them direct.
                                    You should never sell things which can be got for free.
                                    A few Extensions are available to buy through the Shop.
                                    Obviously you pay for these and should not distribute them to others.
                                    ์ผ์„ ๋ช…ํ™•ํžˆํ•˜๊ธฐ ์œ„ํ•ด.
                                    SketchUcation์˜ ๋Œ€๋ถ€๋ถ„์˜ ํ”Œ๋Ÿฌ๊ทธ์ธ ๋ฐ ํ™•์žฅ ํ”„๋กœ๊ทธ๋žจ์€ ๋ฌด๋ฃŒ๋กœ ๋‹ค์šด๋กœ๋“œํ•˜์—ฌ ์‚ฌ์šฉํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค.
                                    ๊ทธ๋“ค์ด ์œ ์šฉํ•˜๋‹ค๊ณ  ์ƒ๊ฐ๋˜๋ฉด, ๋‹น์‹ ์€ ํ•ญ์ƒ ๋„๊ตฌ์˜ ํ•ญ๋ชฉ๊ณผ ๊ด€๋ จ๋œ ๋ฒ„ํŠผ์„ ์‚ฌ์šฉํ•˜์—ฌ ํŽ˜์ดํŒ”์„ ํ†ตํ•ด ์ž๋ฐœ์ ์ธ ๊ธฐ๋ถ€๋ฅผ ํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค.
                                    ๋ฌด์–ธ๊ฐ€๋ฅผ ์ง€๋ถˆํ•˜๋Š” ์„ ํƒ์€ ๋‹น์‹ ์ž…๋‹ˆ๋‹ค.
                                    ๋งŒ์•ฝ ๋‹น์‹ ์ด์ด ํ”Œ๋Ÿฌ๊ทธ์ธ์„ ์ƒ์—…์ ์œผ๋กœ ์‚ฌ์šฉํ•œ๋‹ค๋ฉด (๋‹น์‹ ์ด์žˆ๋Š” ๊ฒƒ์ฒ˜๋Ÿผ) ๋Œ€๊ฐ€๋กœ ๋ฌด์–ธ๊ฐ€๋ฅผ ๋Œ๋ ค์ฃผ๋Š” ์•ฝ๊ฐ„์˜ ์ง•๊ณ„๋ฅผ ๋А๋‚„ ์ˆ˜ ์žˆ์ง€๋งŒ, ๊ฐ•์ œ์  ์ธ ๊ฒƒ์€ ์•„๋‹™๋‹ˆ๋‹ค.
                                    ๋”ฐ๋ผ์„œ ์ผ๋ถ€ ํ”Œ๋Ÿฌ๊ทธ์ธ์œผ๋กœ ์ƒ๋‹นํ•œ ์‹œ๊ฐ„๊ณผ ๋…ธ๋ ฅ์„ ์ ˆ์•ฝํ•œ๋‹ค๋ฉด ์ˆ˜์ž…์˜ ์ผ๋ถ€๋ฅผ ๊ธฐ๋ถ€ํ•˜๋Š” ๊ฒƒ์ด ๊ณต์ • ํ•ด ๋ณด์ผ ๊ฒƒ์ž…๋‹ˆ๊นŒ?
                                    ์ด๋Ÿฌํ•œ ๋ณต์‚ฌ๋ณธ์„ ์ง์ ‘ ๋ฐฐํฌํ•˜๋Š” ๋Œ€์‹  ๋‹ค๋ฅธ ์‚ฌ๋žŒ์ด SketchUcation PluginStore๋ฅผ ๊ฐ€๋ฆฌ ํ‚ค๋„๋กํ•˜์—ฌ ์ง์ ‘ ๊ฐ€์ ธ์˜ฌ ์ˆ˜ ์žˆ๋„๋กํ•˜๋Š” ๊ฒƒ์ด ์ข‹์Šต๋‹ˆ๋‹ค.
                                    ๋ฌด๋ฃŒ๋กœ ์–ป์„ ์ˆ˜์žˆ๋Š” ๋ฌผ๊ฑด์„ ์ ˆ๋Œ€ ํŒ”์ง€ ๋งˆ์‹ญ์‹œ์˜ค.
                                    ์ƒ์ ์„ ํ†ตํ•ด ๊ตฌ์ž…ํ•  ์ˆ˜์žˆ๋Š” ๋ช‡ ๊ฐ€์ง€ ํ™•์žฅ ํ”„๋กœ๊ทธ๋žจ์ด ์žˆ์Šต๋‹ˆ๋‹ค.
                                    ๋ถ„๋ช…ํžˆ ๋‹น์‹ ์€ ์ด๊ฒƒ์— ๋Œ€ํ•ด ์ง€๋ถˆํ•˜๊ณ  ๋‹ค๋ฅธ ์‚ฌ๋žŒ๋“ค์—๊ฒŒ ๋ฐฐํฌํ•ด์„œ๋Š” ์•ˆ๋ฉ๋‹ˆ๋‹ค.
                                    • K
                                      kaas
                                      Anyone else has experienced crashes using the mirror plugin in V2020?
                                      Mirroring nested groups and/or components several times have caused a crash of SU (bugsplat screen). Sometimes it goes ok, sometimes not.
                                      Saving the file now before using the command. Pre 20 never had to do that.
                                        I've tested it quite a bit in v2020, and do not see any BugSplats...
                                        Anything specific in your case ?
                                        e.g. scaled instances, Outliner open etc ??
                                        • K
                                          kaas
                                          Strange, nothing specific (to me) although;
                                          • outliner is always open - was never a problem pre v20
                                          • the top part in the hierarchy is a component with axis at the origin
                                          • nested in this main component are many groups.
                                          Will keep an eye open next week for crashes and see if I notice a pattern.
                                          • B
                                            bik
                                            Same crash for me with Sketchup 2020...
                                            Sometimes crash, sometimes not. Strange.
                                            Thank you for your work.
                                            • 11
                                            • 10 / 11
