    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
    • pbacotP
      I thought your edits would obviate answering whether to erase original each time. I guess COTTY was actually the one to show that. I don't care regarding selection afterwards as I do NOT usually move the object.
        Here's v5.0.
        http://sketchucation.com/pluginstore?pln=Mirror
        It's now an extension and is future-proofed...
          Here's v6.0
          It has some improved security features.
          • mariochaM
            mariocha
            @bob james said:
            ... I would prefer that the new mirrored object be the one selected so I can immediately move it.
            Being a big user of that extension, I often had that thought. So I second that. 😎
            %(#008000)[Mario C.
            • josephkim626J
              josephkim626
              @MARIOCHA
              Just in case you missed it πŸ˜„.
              TIG did mentioned the way to change that behavior in earlier reply.
              • mariochaM
                mariocha
                @josephkim626 said:
                @MARIOCHA
                I had indeed missed it. Thanks.
                Line number to insert code has changed to 337.
                Works fine. πŸ˜„
                %(#008000)[Mario C.
                • josephkim626J
                  josephkim626
                  @mariocha said:
                  @josephkim626 said:
                  @MARIOCHA
                  Works fine. πŸ˜„
                  I assume that you are enjoying that as much as I am! πŸ˜„
                  • mariochaM
                    mariocha
                    Wanted to learn some more Ruby.
                    Added LanguageHandler to it. French included.
                    Tested on Mac and PC.
                    update: Attached the Localized version. This version also selects the mirrored copy at exit.
                    Comments welcome.
                    Mirror.rbz
                    %(#008000)[Mario C.
                    • mariochaM
                      mariocha
                      I tweaked the localized version so that it can show the toolbar icon properly.
                      In Mirror_code.rb: png=File.join(DATA, "Mirror.png")
                      Previously the png file name was linked to the name of the extension. But that name changes upon localisation. I made it so that the link to the png filename is not variable.
                      Mirror_v6.0LH.rbz
                      %(#008000)[Mario C.
                        Stardown
                        Hey TIG. Thanks for this plugin, very useful. I run a small CNC from home for personal improvement, and test different software. To do so I export my sketchup files to dxf. I've noticed that when using your mirror plugin, some geometry (usually curves) exports wrong into 3D dxf... even though they appear to be just fine in SketchUP. Do you know anything about that issue or how to fix it?
                        If you need a sample file to check let me know.
                          Here's v7.0 which is fully compatible with v2017 in all Loading Policies.
                          • mariochaM
                            mariocha
                            Pity that LanguageHandler is not there.
                            It was all done. 😞
                            with fr strings file also. πŸ˜’
                            %(#008000)[Mario C.
                              It was all done. 😞
                              Sorry, but there are time constraints for working on these 'free' extensions...
                              • mariochaM
                                mariocha
                                Ok then,
                                I re-did it. Here is the fr localized version. Signed.
                                Very easy to add any other language.
                                (mirrored entities are selected at the end)
                                I would be honoured if next upgrade could stem from this one. πŸ˜‰
                                Mirror-7.rbz
                                %(#008000)[Mario C.
                                • F
                                  FZSarasota
                                  Coming from the VFX community, the Mirror Object/Face tool is common across all 3D packages (be it Lightwave, Max, Maya, Etc...). I found it bizarre the SU doesn't have this native function (weird). You really miss the "Mirror Tool" when hopping into a packages that don't offer it.
                                  Thank you for you're development time and great little plugin, and, preventing me from loosing my mind, because I'm soooo used to having this tool!
                                  Works great in SU2017, does what it claims (simple and sweet). Wink....
                                  -Terry
                                    Here's v8.0
                                    It sidesteps the glitches some PC users get when they have accented-characters in their user-name.
                                      Here's v9.0 http://sketchucation.com/pluginstore?pln=Mirror It restores compatibility with v8, which was inadvertently lost in the last update.
                                      • F
                                        FZSarasota
                                        Thanks, I'll grab the new version now...
                                        • boofredlayB
                                          boofredlay
                                          Cheers TIG.
                                          • medeekM
                                            medeek
                                            Awesome plugin. SketchUp probably should have this tool/feature built in but this plugin feels the need and it works great. Much easier than having to copy, scale (-1) and then move into position.
                                            Nathaniel P. Wilkerson PE
                                            Medeek Engineering Inc
                                            design.medeek.com
                                            • 11
                                            • 9 / 11
