    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.7k Views 172 Watching
      Anton_S
      Hi, Robin,
      I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
      Regards,
      Anton
      • robintR Offline
        robint
        @anton_s said:
        Hi, Robin,
        Regards,
        Anton
        Hi Anton
        It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
        BTW just seen some example in Sketchucation, blown away with the talent out there
        Hope my little exercises aren' t too dull
        Cheers
        Robin
        As one door closes another one slams in your face
        • gillesG Offline
          gilles
          What am I doing wrong?
          THEO-JANSEN2.skp
            Anton_S
            Hi, gilles,
            You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
            Anton
            • gillesG Offline
              gilles
              Thanks Anton,
              Very nice tool you made there.
              THEO.skp
                Anton_S
                Very clever, gilles!
                I'm sure there is a way to improve performance and stiffness of that thing.
                Anton
                • gillesG Offline
                  gilles
                  Thรฉo Jansen.
                  http://www.strandbeest.com/index.php ๐Ÿ‘
                    The peaceful robots! ๐Ÿ˜Ž
                    • gillesG Offline
                      gilles
                      I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                      Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                      Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                      Just for anybody else having the same troubles.
                      Mac OSX 10.8.5, SU2015.
                        Anton_S
                        Yeah, I'm working on that. Thanks for the report, gilles!
                        • robintR Offline
                          robint
                          [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                          Hi gilles
                          I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                          kinda convoluted
                          Robin
                            Anton_S
                            Announcing 0.9.9!
                            This version comes with mainly an improved dialog and joints.
                            View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                            Anton
                              SketchyPhysicsNutt
                              Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                              MSPhysics 0.9.9
                              tested on win 8.1 and sketchup 2015/2016 working fine.
                              the new plane joint works great on single or two different planes ๐Ÿ‘
                              thx again and merry xmas
                              Tez
                                Anton_S
                                Hello, Tez,
                                Good to hear that it's working now. And merry Christmas to you too!
                                Best regards,
                                Anton
                                  SketchyPhysicsNutt
                                  Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
                                  in Sketchyphysics i just tick the OnTouch panel and use
                                  playSound('Sound1')
                                  what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
                                  its no bug ..just me don't understand MS scripts yet.
                                  Tez
                                  • robintR Offline
                                    robint
                                    Hi Anton, installed 0.9.9 and restarted SU
                                    but its screwed up my model?
                                    It falls downwards and I cant get the static floor to work as before, also the script stopped working
                                    Did I do a corrupt installation?
                                    Should I have deleted 0.9.8 first - you didnt say?
                                    I assumed it would overwrite and update itself
                                    Where to go? delete and start fresh installation or go back to 0.9.8?
                                    What to do? ๐Ÿ˜ณ
                                    Robin
                                    falling block7.skp
                                      Anton_S
                                      Tez,
                                      In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
                                      onTouch { |toucher, position, normal, force, speed|
                                        simulation.play_sound("Sound1")
                                      You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
                                      Anton
                                        Anton_S
                                        Robin,
                                        I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
                                        Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
                                        If you want to revert to on original version, you may always refer to the instructions on the homepage.
                                        Anton
                                        • robintR Offline
                                          robint
                                          Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
                                          Cheers
                                          Robin
                                          • robintR Offline
                                            robint
                                            I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                                            Overwriting existing files looks unwise and it was severely screwed up
                                            I would advise users
                                            Cheers
                                            Robin
                                            PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                                            falling block8.skp
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 46
                                            • 47
                                            • 34 / 47
