    2017 is here
    82 Posts 31 Posters 13.1k Views 31 Watching
    • N
      numerobis
      @dave r said:
      What do you mean? And why won't you just try it and see for yourself?
      Ok, i installed it now and i have to say that it doesn't feel faster than v2015. And it seems that the degradation kicks in earlier now compared to v2015, which is quite annoying and less usable (recovery time). With the degradation it is of course faster than the non degraded model in v2015 (e.g. ~16-25fps vs 10-11fps in v2015). But when i take a model that already degrades in v2015, so that i compare degraded vs degraded then they are both the same. No measurable difference.
      It would be good if it would be possible to disable the auto degradation as it is in 3DSmax.
      All tests without shadows and AA, i7 5960X@4.5GHz | GTX 970, 372.70, 2560x1440px | Win7
      • V
        vico44
        Wow Faster API!
        I work on a small plugin http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=66103
        For Big Model SU2016 just can't do it (to much component definition...)
        And SU2017 just do it in few seconds...
        • jgbJ
          jgb
          So I started to get a hardon 😍 (almost as big as Fredos Animator, soon to be installed!!) and I noticed on the downloads list there is NO Windows 32 bit versions (MAKE in particular). 😲
          Is this true, no 32bit versions? πŸ‘Ώ
          So am I stuck with SU-2016 forever till I win a lottery and can afford a system upgrade? 😒
          jgb
          • JQLJ
            JQL
            Yes you are... no 32bit versions, sorry...
            www.casca.pt
            Visit us on facebook!
            • ntxdaveN
              ntxdave
              I think I am seeing some performance improvement but cannot confirm that yet. One thing that I notice is that if I load a rather large model, when I orbit it all works well but as soon as I try to do anything (add a new component or some other edit, including just updating the toolbar) the lag in painting the screen and its textures shows up again. Seems like it does resolve it quicker but still see the lag.
              I do see some value to the perpendicular inference but have not figured out completely how to use it yet. If I have a face that is on an angle and I want to draw another object parallel to that face, it seems like the perpendicular inference would do the trick but the only way I have been able to use it is when I draw a line. Maybe someone will come up with a more detail tutorial or instructions about how to use it more extensively.
              Press F1...thank me later
                danb
                Dear Sketchup team, it's good to know you are own these forums. So far everything that I have seen in 2017 is great bar one exception which I feel is a backward step. In 2017 the edge lines seem to be a lot thicker, is this to do with the hi res dpi setting? I am running across a laptop screen and a main dell monitor and the lines are far more distracting than they were previously.
                Do you think that you may be able to release an update where you can turn this setting off or make the edge lines thinner.
                I hope that you can.
                many thanks in advance
                Dan
                Sketchup 2016 & 2017 Pro
                OSX 10.12.1
                Macbook Pro
                Sketchup Pro 2019/20
                OSX 10.15.3
                Macbook Pro
                • V
                  ValmontR
                  WOOHOO!!! Just noticed that with SU 2017 Macintosh preview desktop preview icons are back again!
                  Cheers,
                  ralph
                  • jujuJ
                    juju
                    Dan
                    OSX 10.12.1
                    Macbook Pro
                    have you tried playing with the settings in the Styles menu?
                      danb
                      Juju
                      Yep, there doesn't seem to be a control for this other than turning edges on or off, I have compared 2016 and 2017 on the same monitors and the edges are definitely thicker and the visuals feel more cartoony and clunky, particularly if you are putting smaller items such as plug points and props into your model. It would be great if the Sketchup team could implement an edge thickness setting similar to the section cut thickness.........please!
                      best regards
                      Dan
                      Other than that I am jumping star
                      OSX 10.15.3
                      Macbook Pro
                        danb
                        Hmmm...seem to have hit send too quickly (Jumping Star??)
                        I meant to say jumping right in and the improvements particularly in layout with dimensions look great
                        OSX 10.15.3
                        Macbook Pro
                        • jujuJ
                          juju
                          To be clear, you have toyed with the settings in the screen grab below? This was taken from a default SU 2017 arch design (mm) template file being opened.
                            danb
                            Yup, profiles is set to off and edges are on, there is a thread here that I found.... hopefully the engineers will take this on board but if anyone has any workarounds that would be great
                            Site Not Found - Discourse
                            (forums.sketchup.com)
                            thanks
                            Dan
                            OSX 10.15.3
                            Macbook Pro
                            • pmolsonP
                              pmolson
                              I am a big fan of this release. I was up and running in minutes, no problems, and better performance. Whats not to like? Is it perfect in all ways to all users? Of course not. How could it be?
                              I am always amazed (although I guess i should not be) at the attitude of some commenters on these releases. They seem actually angry at the product as if it should meet there every need, or that it somehow owes them something. It is very apparent to me that the people behind this product are thoughtful and are trying to improve the product in a meaningful way. I am more than happy to be patient while this product evolves.
                              I noticed something this morning when zooming in on a line intersection. I was able to keep zooming in with no clipping all the way to the point that the intersection literally filled my screen. I have never been able to do that in previous releases. In the past, I always experienced clipping which stopped me from getting as close as I would like. Is this a conscious fix or a lucky by product i wonder?
                                If you were in Orthographic you can zoom without clipping. It's when it's perspective and the model size exceeds the clipping range that you'll get clipping occurring.
                                You can get clipping in Orthographic too. If the perspective camera doesn't see the extent of the model and then you switch to Ortho.
                                Clipping is part and parcel with any 3D app. It's why some users have requested a way to set the start and end point of camera clipping.
                                • soloS
                                  Anyone seen this error?
                                    Is PlusSpec installed?
                                    • pmolsonP
                                      pmolson
                                      Hi Rich,
                                      yup, I get why it does it and have always switched between ortho and perspective and all the other tricks to minimize the clipping. I just noticed this morning that on a model that I would experience more severe clipping when working in 2016 was noticeably less in 2017...I could be imagining things, but it literally made me go...huh! the first time a zoomed in close and was able to keep zooming in...
                                      • soloS
                                        Not sure if you are asking me, if so then No, I do not have a plusspec license nor is it installed.
                                          Yeah, sorry I was asking you. I had that error on PlusSpec a versions back.
                                          • I
                                            igacici
                                            I need to ask if someone might help me find what might be a problem... I tried several times to install new Sketchup 2017 on my notebook and it every time fails to install prerequisites with following error message
                                            "Component Universal CRT (Hotfix KB2999226) has failed to install with the following error message:
                                            "The installer for the Universal CRT (Hotfix KB2999265) timed out after 10 minutes. Please restart your computer and try the SketchUp installer again. If this does not fix the problem, use Windows Update to install the latest updates and try again. (Trimble Code 6)"
                                            The following components were not installed:
                                            • Microsoft .NET Framework 4.5.2 (x86 and x64)
                                            The following components failed to install:
                                            • Universal CRT (Hotfix KB2999226)
                                            See the setup log file located at 'C:\Users\muhammed\AppData\Local\Temp\VSDBA10.tmp\install.log' for more information."
                                            • 4 / 5
