    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.3k Views 172 Watching
      Anton_S
      Hi, Robin,
      The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
      I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
      Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
      Anton
      • robintR Offline
        robint
        Hi Anton
        I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
        cheers Robin
        As one door closes another one slams in your face
        • robintR Offline
          robint
          @anton_s said:
          Hi, Robin,
          Anton
          Yes indeed, improved action, I missed the friction box
          Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
          spring stiff 1 (what does this do?)
          Accel 1, damp 1.5 (gives critical damping approx)
          changing sample rate from 1/60 to 1/240 changes the whole model performance
          iterations 16 - improves stability
          the plane has a mass of 0.01kg, lowest i could get without instability
          So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
          What do you think? Anything I can do to help (ruby dummy just now)
          Cheers
          Robin) ๐Ÿ˜›
          V 2
            Anton_S
            Hi, Robin,
            I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
            Regards,
            Anton
            • robintR Offline
              robint
              @anton_s said:
              Hi, Robin,
              Regards,
              Anton
              Hi Anton
              It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
              BTW just seen some example in Sketchucation, blown away with the talent out there
              Hope my little exercises aren' t too dull
              Cheers
              Robin
              • gillesG Offline
                gilles
                What am I doing wrong?
                THEO-JANSEN2.skp
                  Anton_S
                  Hi, gilles,
                  You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                  Anton
                  • gillesG Offline
                    gilles
                    Thanks Anton,
                    Very nice tool you made there.
                    THEO.skp
                      Anton_S
                      Very clever, gilles!
                      I'm sure there is a way to improve performance and stiffness of that thing.
                      Anton
                      • gillesG Offline
                        gilles
                        Thรฉo Jansen.
                        http://www.strandbeest.com/index.php ๐Ÿ‘
                          The peaceful robots! ๐Ÿ˜Ž
                          • gillesG Offline
                            gilles
                            I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                            Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                            Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                            Just for anybody else having the same troubles.
                            Mac OSX 10.8.5, SU2015.
                              Anton_S
                              Yeah, I'm working on that. Thanks for the report, gilles!
                              • robintR Offline
                                robint
                                [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                                Hi gilles
                                I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                                kinda convoluted
                                Robin
                                  Anton_S
                                  Announcing 0.9.9!
                                  This version comes with mainly an improved dialog and joints.
                                  View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                  Anton
                                    SketchyPhysicsNutt
                                    Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                                    MSPhysics 0.9.9
                                    tested on win 8.1 and sketchup 2015/2016 working fine.
                                    the new plane joint works great on single or two different planes ๐Ÿ‘
                                    thx again and merry xmas
                                    Tez
                                      Anton_S
                                      Hello, Tez,
                                      Good to hear that it's working now. And merry Christmas to you too!
                                      Best regards,
                                      Anton
                                        SketchyPhysicsNutt
                                        Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
                                        in Sketchyphysics i just tick the OnTouch panel and use
                                        playSound('Sound1')
                                        what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
                                        its no bug ..just me don't understand MS scripts yet.
                                        Tez
                                        • robintR Offline
                                          robint
                                          Hi Anton, installed 0.9.9 and restarted SU
                                          but its screwed up my model?
                                          It falls downwards and I cant get the static floor to work as before, also the script stopped working
                                          Did I do a corrupt installation?
                                          Should I have deleted 0.9.8 first - you didnt say?
                                          I assumed it would overwrite and update itself
                                          Where to go? delete and start fresh installation or go back to 0.9.8?
                                          What to do? ๐Ÿ˜ณ
                                          Robin
                                          falling block7.skp
                                            Anton_S
                                            Tez,
                                            In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
                                            onTouch { |toucher, position, normal, force, speed|
                                              simulation.play_sound("Sound1")
                                            You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
                                            Anton
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
