    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 134.3k Views 39 Watching
    • KrisidiousK
      Krisidious
      I missed it... Glorious.
      By: Kristoff Rand
      • onzkiO
        onzki
        Hi, Thanks for sharing this amazing plugins, I installed it via Sketchucation Store (Autoinstall)but how come mine seems lacking? Do I need to uninstall old plugins first? Please see attached screenshot. Thanks!
        [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
        • P
          pipinek
          Greetings,
          Is the current version 2.3 compatible with SU 2016?
          Many thanks
            Sam3D
            Por favor nao consigo instalar, aparece erro! Já fiz todo o processo, meu windows 8!
            Me ajude!!!!!
            Error Loading File C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
            Error: No such file or directory - C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_pb.strings
            C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in readlines' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in module:Max_Coppoletta'
            C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
            C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension'
            C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in <module:JHS_powerbar>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:8:in module:Max_Coppoletta'
            C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:7:in `<top (required)>'
            • deaneauD
              deaneau
              pictures tell more than 1000 words 😉
              • HornOxxH
                HornOxx
                Thank you so much for this great tool collection - I've missed so much !!
                (it works great!)
                never trust a skinny cook
                • onzkiO
                  onzki
                  Funny It's been a year and I have to reply to my own post LOL.. Anyway, for those with similar question like mine here, I finally found where the missing icons are, Euerka! They're under the main menu "HELP->CADFATHER PACK->POWERBARICONS." It took me a year to discover by accident since I don't often scroll down the help menu path.
                  These are truly amazing plugins, thanks a lot! 👍
                  Screenshot
                  • K
                    ktsbanam
                    Extrude tool fails in sketchup 2017
                    It does not create surface
                    please fix it
                    thank
                    • CadFatherC
                      CadFather
                      sorry, haven't been around - though the answer was on the first post: "- The menu itself is under the Help section, this is due to traffic and it ties up with things to come." 😉
                      glad you got it working 👍
                      aware of the glitch with extrude and 2017. busy at present, but as soon as i get some time to dive into the code again, i'll post a working update
                        Ciao Max!
                        • CadFatherC
                          CadFather
                          Ciao Rich, hope you're good! : )
                          • P
                            Pherim
                            Great! Looking forward to it!
                            • CadFatherC
                              CadFather
                              posted a new update - should be working with 2017 (thanks to TIG).
                              also just to let you know, i hope to be working on a fuller update sometime in the new year.
                              Cheers
                              • P
                                Pherim
                                Great, thank you!
                                  shri
                                  this plugin makes my work faster..thanks alot
                                  • onzkiO
                                    onzki
                                    LOL, I was too lazy to read! I miss that one. I'll charge this to my Duh moments.
                                    • N
                                      nickweboffer
                                      hi
                                      I have installed and uninstalled several times but the whole powerbar just doesn't show up in my SU 2015. what are my options?
                                      • jujuJ
                                        juju
                                        @nickweboffer said:
                                        hi
                                        did you remember to go to View > Toolbars and check that the toolbar is selected?
                                        • P
                                          Pherim
                                          Hello,
                                          I have a small issue with one of the functions and I wonder if anything can be done about it. It's about the "Equalise Curves" tool, which is very handy in certain situations, but whenever I use it, one end of the curve moves a little. I am only using "Divide by number", not by length, but it happens in both modes. Is it possible to change it so that both ends stay in their original position? Or is there another plugin which can do that? Unlike other tools in this collection, I can't find a corresponding separate plugin for this function. And for example Fredo6's Curvizard can only simplify contours by angle, but not equalise the segments.
                                          • CadFatherC
                                            CadFather
                                            Hi Pherim, i'll have a look at it, though that might be a while as i'm away
                                            • 2 / 4
