    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 130.3k Views 39 Watching
      pipinek
      Greetings,
      Is the current version 2.3 compatible with SU 2016?
      Many thanks
        Sam3D
        Por favor nao consigo instalar, aparece erro! Já fiz todo o processo, meu windows 8!
        Me ajude!!!!!
        Error Loading File C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
        Error: No such file or directory - C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_pb.strings
        C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in readlines' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in module:Max_Coppoletta'
        C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
        C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension'
        C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in <module:JHS_powerbar>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:8:in module:Max_Coppoletta'
        C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:7:in `<top (required)>'
        • deaneauD Offline
          deaneau
          pictures tell more than 1000 words 😉
          • HornOxxH Offline
            HornOxx
            Thank you so much for this great tool collection - I've missed so much !!
            (it works great!)
            never trust a skinny cook
            • onzkiO Offline
              onzki
              @onzki said:
              Hi, Thanks for sharing this amazing plugins, I installed it via Sketchucation Store (Autoinstall)but how come mine seems lacking? Do I need to uninstall old plugins first? Please see attached screenshot. Thanks!
              Funny It's been a year and I have to reply to my own post LOL.. Anyway, for those with similar question like mine here, I finally found where the missing icons are, Euerka! They're under the main menu "HELP->CADFATHER PACK->POWERBARICONS." It took me a year to discover by accident since I don't often scroll down the help menu path.
              These are truly amazing plugins, thanks a lot! 👍
              Screenshot
              [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                ktsbanam
                Extrude tool fails in sketchup 2017
                It does not create surface
                please fix it
                thank
                • CadFatherC Offline
                  CadFather
                  sorry, haven't been around - though the answer was on the first post: "- The menu itself is under the Help section, this is due to traffic and it ties up with things to come." 😉
                  glad you got it working 👍
                  aware of the glitch with extrude and 2017. busy at present, but as soon as i get some time to dive into the code again, i'll post a working update
                    Ciao Max!
                      CadFather
                      Ciao Rich, hope you're good! : )
                        Pherim
                        Great! Looking forward to it!
                          CadFather
                          posted a new update - should be working with 2017 (thanks to TIG).
                          also just to let you know, i hope to be working on a fuller update sometime in the new year.
                          Cheers
                            Pherim
                            Great, thank you!
                              shri
                              this plugin makes my work faster..thanks alot
                              • onzkiO Offline
                                onzki
                                LOL, I was too lazy to read! I miss that one. I'll charge this to my Duh moments.
                                • N Offline
                                  nickweboffer
                                  hi
                                  I have installed and uninstalled several times but the whole powerbar just doesn't show up in my SU 2015. what are my options?
                                  • jujuJ Offline
                                    juju
                                    @nickweboffer said:
                                    hi
                                    did you remember to go to View > Toolbars and check that the toolbar is selected?
                                      Pherim
                                      Hello,
                                      I have a small issue with one of the functions and I wonder if anything can be done about it. It's about the "Equalise Curves" tool, which is very handy in certain situations, but whenever I use it, one end of the curve moves a little. I am only using "Divide by number", not by length, but it happens in both modes. Is it possible to change it so that both ends stay in their original position? Or is there another plugin which can do that? Unlike other tools in this collection, I can't find a corresponding separate plugin for this function. And for example Fredo6's Curvizard can only simplify contours by angle, but not equalise the segments.
                                        CadFather
                                        Hi Pherim, i'll have a look at it, though that might be a while as i'm away
                                          Pherim
                                          Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
                                          Then I get this error in the Ruby Console:
                                          Error; #<ArgumentError; Not enough points - at least 2 required>
                                          C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `add_curve'
                                          C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `main'
                                          C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb;578;in `block in <module;Max_Coppoletta>'
                                          SketchUp;1;in `call'
                                          • V Offline
                                            vzynsky
                                            JHS powerbar 2.4 + su17! What was the problem? 😕
                                            https://scontent.fdad1-1.fna.fbcdn.net/v/t1.0-9/21728301_1450124848414787_6713604283302657052_n.jpg?oh=39fd716e7f701ed415829835d3fb3cf2&oe=5A49F8D4
                                            • 2 / 4
